OK,
Looking to buy an FJ Cruiser. I have one concern: Gas prices. I know it'll be better than my Tundra, but is everyone running 91 octane? or can you run 87? around here, its a $.20 difference. If it's 91 it's not a deal breaker, but I am curious.
If you dont run the recommended 91, it will lack power and not achieve the best fuel economy. This engine is designed to run on 91 for a reason. Its all about combustion chamber design and emissions, while trying to squeeze the most power and MPG per gallon.
The use os anything lower may not hurt it, but you wont be at your full potential.
25 yrs with TOYOTA
I just got the FJ, the second tank I used the blend, mid grade whatever Octane it is. The most recent tank I used the cheap stuff and actually got a little better mileage. There seems to be more difference from one brand of gasoline to the other. The best mileage to this point has been Chevron 87 Octane, seems plenty peppy. If I were competing perhaps I would use the higher grades, I want reliable, don't need a rocket, I sorta drive like an Old Woman anyway. For my use I just can't see how the 91 octane and up is going to make that big of difference. I guess the other reality is, I'm kinda Cheap, the less money I can give to Big Oil the Better. However let me qualify Cheap is relative, I will use Mobil 1 Oil in the FJ when it comes time for that first Oil Change. The Tundra has 97K on it and runs like a scalded cat, it also burns 87 octane and things are lubed by Mobil 1. Someone is going to have do a spreadsheet for me to really show the added value of burning the higher octane. Just my $.02 Worth, A Pleasant VooDooBlue Evening to All
Chet
Toyotas, Slow Birds, Pointing Dogs and SxS Shotguns, It doesn't get any Better!
After a few months, I quit using the 91 and went to regular 87. I've never noticed any real difference. No knocking or pinging, and acceleration is fine.
I got my '07 in August and the dealer told me then, and repeated it several times on subsequent visits, that 87 was recommended by all the dealerships.
Over the past 12500 km, I've burned only 2 tanks of #1 gas, and got no better mileage than with the normal 87 I use. I'm learning to keep my foot out of it, to keep my revs below 2500, and for 8 months it's been a carefree experience.
PB
PB
Not ALL dealerships recommend 87
Mine does not
Toyota spent $$$$$ in R&D and must know something, even if we dont understand why, that it should have 91+.
It is stated in the New Car feature that ALL dealerships have.
Its also in your owners manual. Page 206 & 316
You may not notice a difference and I personally dont think its going to hurt anything, but your not getting the full potential out of that engine without it.
25 yrs with TOYOTA
this is an old and extensively covered topic go look back in the threads about 6 months and you will find all the info you need (and then some). Long and the short, nothing gained by running prem. I haven't run prem for about 10000 miles, no difference. Sorry Musta....whatever you called yourself, prem doesn't matter on this truck. Other cars do need it, just not this one.
I disagree, but thats what makes TS so great. We can both be right In our own worlds.
Toyota does alot of R&D and says it needs it for a reason.
I wont beat on this, your right. It has been covered before.
Enjoy the cheaper 87. I HAVE to run 91.
Have a good weekend
25 yrs with TOYOTA
Thanx for the responses.
I did indeed buy an FJ, I love it. I have yet to gas it up. it came w/a full tank courtesy of the dealer. I'm pretty sure I'm gonna run 87, and will only upgrade if it pings/knocks.
Thanx again for the input.
MODS: (TRD Urban package) - tint, stereo, jack-in-the box antennae ball, and my middle finger.
... Find any spelling errors? Take it up with admin.
...... btw If I offend anyone, get over it. I know I will.
......... Panties are optional.
~ been there, done that, got the panties ~
