Forced Induction SystemsDetailed discussions regarding cold-air intake systens, superchargers, turbo chargers, and other induction systems for your vehicle.
This is a discussion thread titled "2007 tundra cold air intake?", within the Forced Induction Systems forum, part of the Technical & Vehicle Assistance Forums category.
Correct me if I am wrong, please. When I got my Tundra I planned to purchase a cold air intake until someone in this forum told me about that extra emissions filter in the air box. Looking into the air box I can see that the intake comes off the wheel well. So unless I am wrong the stock configuration is a cold air intake. Now my plan is to invest in a better air filter from K&N when they decide to get off their rears and put out some products for the 07 Tundra. Maybe I am just naieve on the subject but I dont see the logic in investing $300 into something that is already there. PLease advise.
You're correct in that the stock intake is already a cool air intake, because it pulls air from the fender. The money in the aftermarket intakes is usually for flow optimization which reduces pumping losses. The air flow in the stock intake has more impedance than an aftermarket intake and filter. Some of this impedance can be removed by an aftermarket filter, but the air flow still has to make a couple more 90 degree turns before it gets to the engine. The Airaid I have, for example, draws air radially through an oval filter and straight to the throttle body, where the stock intake has to pull air through the hole in the fender, up through the filter and turn in to the intake tube to the throttle body. In the case of the Tundra, they did a good job designing the stock intake due to its large volume and close proximity to the engine.
I'm starting to think I may just re-install the stock airbox and install and aftermarket filter. That, or spring for the Volant...
__________________ 2007 Tundra DC Limited - Slate Metallic 5.7L 4WD
Red Rock Leather -- Navigation -- TRD Exhaust -- TRD Sway Bar -- Volant Intake -- JBA Headers -- ReadyLift 2.5" front spacer/1" rear blocks -- Pro Comp front coilovers with TRD package springs and Bilstein shocks -- Pro Comp 6066 wheels with BFG A/T KO 305/55R20 -- Bushwhacker Pocket Fender Flares (Color Keyed)
The difference with the aftermarket intake is the intake tube size. It may seem very similar to the stock but it flows better. The filter has alot to do with it as well. Changing just the filter may help some but a true CAI is designed to be used with its own filter. Run the 1/4 mile all you want but the proof is on the dyno.
__________________ '07 TUNDRA, 5.7L, TSS PACKAGE, WHITE W/ PEANUT BUTTER INT, DC, 20" CHROME, SIRIUS SAT, VOLANT COLD AIR INTAKE.
Maybe the CAI improved the top end but took out a little power at lower rpms, so in the end they came out even? Were you fender to fender all the way, or did the stock truck sneak quicker off the line and the CAI just catch up through the traps?
Back in the TBI Chev era, you could put a 454 TBI on a 350 and although the top end was much better, the larger plate definitely softened the low end torque, both properly tuned. It was pronounced enough that the truck with the bigger plate lost off the line what it gained on top. The quarter mile time was almost the same.
It was fender to fender untill the very end when he started and I started to get an edge. His truck was starting to pull, but it was a very slow pull and would probably take 1/2 mile or more to get a full truck length.
Dyno smyno. You can look at the numbers and claims all you want, but seeing it in person???? It's not the type of drastic change you would expect. Might look good on paper, but that's about it.
We took it off tonight and he is returning it.
__________________ 2007 5.7L SR5 Double Cab TSS Package. Black Leather Int, JBL Sound System with Bluetooth. Bone stock otherwise for now.
I just ordered mine tonite. I sure hope your wrong about that. Hopefully I will see better gains in combination with my JBA exhaust. If not, I too will be returning it and getting my $350 back!
Searching for an answer to your Tundra or other Toyota question? search HERE! or HERE!
Got a question about TS.com site policy? click HERE!
What is Rep Power? read more HERE!
I just ordered the Volant intake. I'll let you know how it performs. 27 est. HP!
Let us know how the install goes. I ordered the kit for my 2006 4Runner SE and there were a few fitment issues. Hopefully Volant has adressed those issues and it won't carry over to the kits for the Tundras.
i too have a volant on the way and if it turns out to be a pos ill send it right back too. not gonna pay 350+ for a part that does jack or sh*t. supposed to have it by midweek next week. well see.
cheers
my garage? jeeps...too many freakin jeeps.
I got an offer to try the same thing with a aFe instead of the Volant on my truck and run them against my buddy's Volant. However, my buddy removed his Volant and is sending it back. Both trucks have stock exhaust, so maybe the exhaust combination might produce a bit more and be what your looking for.
I'm considering running the aFe on mine and see how it performs on the drag. Since I won't have the Volant to compare it with, I figured I would run the truck stock first, then with the aFe installed if it's not to hard an install and see if it runs better than the Volant. The Volant was not that hard an install.
The gentleman making this offer to me is stating the Volant had a paper filter for maximum protection and primarily built for Diesel trucks. Maybe he will chime in on this discussion. I'm still skeptical though.
I am a beliver in performance that is exhaust based and plan on doing this to mine soon, but these cold air intakes are a bit dicey in my opinion.
Also, the Volant was not that noisy. You could tell it was there, but nothing drastic. I heard the aFe's are very noisy, but again, just second hand info.
...Also, the Volant was not that noisy. You could tell it was there, but nothing drastic. I heard the aFe's are very noisy, but again, just second hand info.
You're talking about the Volant for the 5.7 Tundra, right?
