Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Forced Induction Systems
Forced Induction Systems Detailed discussions regarding cold-air intake systens, superchargers, turbo chargers, and other induction systems for your vehicle.
This is a discussion thread titled "Tundra Exhaust Mod", within the Forced Induction Systems forum, part of the Technical & Vehicle Assistance Forums category.
  #16 (permalink)
Old 09-16-2007, 09:30 PM
07Sport's Avatar
Dealer : Superior Toyota Scion
Last Online: 12-17-2008 03:08 PM
07Sport is on a distinguished road.
Send a message via AIM to 07Sport 07Sport's Photo Albums
Default Re: Tundra Exhaust Mod
I went with 2.25 in/out and have had no such ill effects. Mileage hasnt changed either.
5.7L V8 2wd
RC/SB
Mods: Tint, Flowmaster exhaust, Sport sill plates, Sport pedals, Chrome handles, Alpine speakers
  #17 (permalink)
Old 09-18-2007, 09:54 PM
Dealer : Jackson's Toyota
Last Online: Today 11:40 AM
Bertsonsracing is on a distinguished road.
Bertsonsracing's Photo Albums
Well... i put the stock exhaust back on and now it seems like a totally new truck! All the power is back, it's quicker than ever and gives me great gaz mileage. Unfortunately not it doesn't rumble anymore and looks stock. So... if I had my setup reworked with 2.25" pipes I should not loose any gaz mileage and maintain all of the power? Does the size of the piping matter after the mufflers or only before?
thanks
  #18 (permalink)
Old 09-19-2007, 05:25 PM
Rapid Dog's Avatar
Last Online: 05-06-2008 01:20 PM
Rapid Dog is on a distinguished road.
Rapid Dog's Photo Albums
Hmmm. My '07 DC 5.7 with 3500 miles has a Flowmaster exhaust installed.
Best average mileage per the computer is 15-16mpg max.
the previous owner installed the FM, which I wouldn't have done, but it makes me wonder if it's affecting mileage.
I've only commuted at freeway speeds and barely gas it at all.
Wonder what's up...?
BTW, I'm using 76 regular...darned if I can find anything in the manula that says anything about using anyhing less than 87 octane (regular)......
  #19 (permalink)
Old 09-19-2007, 06:22 PM
remotemonkey's Avatar
Dealer : Serra Toyota Scion
- Other - Red '91 s/c NSX,
2007 Toyota Tundra DC, 4x4 sr5
Last Online: 12-04-2008 03:53 PM
remotemonkey is on a distinguished road.
remotemonkey's Photo Albums
it says specifically to use no less then 87 in the manual as well as the toyota website.
5.7L DOHC 32V i-FORCE V8 with Dual Independent Variable Valve Timing with Intelligence (VVT-i)
381 Horsepower @ 5600 rpm
401 Torque @ 3600 rpm (lb.-ft.)
Aluminum block with aluminum heads. Acoustically Controlled Induction System (ACIS) - dual stage intake manifold
Compression ratio: 10.2:1
Tow hitch receiver, 7-pin connector, trailer brake control prewire, supplemental transmission cooler, TOW/HAUL mode, transmission temperature gauge, 4.300 rear axle ratio (4.100 rear axle ratio on 4.7L models)
Emissions: ULEV II
Recommended fuel: 87 octane or higher
Toyota Tundra - 2007 Performance & Specifications
  #20 (permalink)
Old 09-19-2007, 09:41 PM
Isn't "76" the name of the Gas Station Rapid Dog is refuelling at? as opposed to the octane rating?
Just saying...
Remote Dog, you are equally right in your statement and thanks for the details!
  #21 (permalink)
Old 09-19-2007, 09:45 PM
Just saying...
i never thought of that, in michigan we dont really have that chain of gas stations, but i know what your talking about anyway. so that might be the case. sorry for the misunderstanding if that is the case.
  #22 (permalink)
Old 09-19-2007, 10:32 PM
thumbster's Avatar
Moderator
Dealer : Capitol Toyota
2005 Toyota Corolla,
2007 Toyota Tundra 5.7 RC SB SR5 Sport
Last Online: Today 02:17 PM
thumbster will become famous soon enough.
thumbster's Photo Albums
thanks
The piping before the muffler is a bit more critical in terms of size than the exiting diameter out of the muffler. Smaller piping will increase gas velocity and enable the gas to remain hotter further down the exhaust system. Most of the cooling occures in the muffler. Cooler exhaust gas is denser and is therefor harder to push through and will increase backpressure - this is the main reason why larger diameter piping can reduce low end torque output.
In choosing your pipe diameter you have to ask yourself what's more important, low end torque or high rpm power. My findings are that 2 1/4 inch mandrel bent piping is best for overall everyday performance and mileage for the 5.7. If you have a muffler shop bend up a system out of 2 1/2 inch pipe, you will have no better performance potential than 2 1/4 inch pipe due to the pressure bending method they use. Also the catalytic converters in the tundra neck down to at least 2 1/4 inches, so your overall power potential is already reduced negating any worthwhile gains possible with 2 1/2 inch piping.
  #23 (permalink)
Old 09-19-2007, 10:54 PM
Dealer : Team Toyota
2007 Toyota Tundra SR5 Dbl. Cab Blue
Last Online: 11-19-2008 04:22 AM
blackbeauty is on a distinguished road.
blackbeauty's Photo Albums
thanks
If you look at the stock exhaust, the front pipes are smaller in size than the tailpipe, even on the TRD Dual, so it would seem best to stick with that pattern I'm guessing. Maybe 2 1/8" front pipes from the the flange back to the muffler for your set-up would work better.
  #24 (permalink)
Old 09-20-2007, 02:27 PM
Dealer : Toyota Scion of Winter Haven
Last Online: 12-17-2008 02:01 AM
SapperTundra is on a distinguished road.
SapperTundra's Photo Albums
What about this magnaflow y pipe with a single 3"i/o cherry bomb or one of the flowmaster y pipes with a cherry bomb
07 Silver Tundra DC 5.7L-Custom Exhaust-Limo Tint-Headlight Mod(Black)-24" Boss
330s
Laremy
  #25 (permalink)
Old 09-25-2007, 09:31 PM
07Sport,
What did you do exactly, cut your exhaust off right in front of the stock muffler and have the Flowmaster adapted and welded directly on to the two front pipes and then added two 2 1/4" tailpipes?
  #26 (permalink)
Old 09-25-2007, 09:43 PM
07Sport's Avatar
Indeed sir you are correct.
5.7L V8 2wd
RC/SB
  #27 (permalink)
Old 09-26-2007, 01:03 PM
Last Online: 01-03-2009 12:57 PM
Big Steve 63 is on a distinguished road.
Big Steve 63's Photo Albums
[quote=Bertsonsracing;766811]By very bad gaz mileage I mean close to 13.5 MPG avg city and HWY. It is not rare for me to get between 9 and 11 mpg when towing my race car on a 19 ft. car hauler.
I see you are in Ontario, are you converting to a Canadian gallon, (4.54 liters) or a USA gallon (3.8 Liters) to get your fuel mileage? Or is this info from the trip computer on the dash?
Bookmarks
