Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Forced Induction Systems
Forced Induction Systems Detailed discussions regarding cold-air intake systens, superchargers, turbo chargers, and other induction systems for your vehicle.
This is a discussion thread titled "Crcked Exhaust Manifold", within the Forced Induction Systems forum, part of the Technical & Vehicle Assistance Forums category.
  #16 (permalink)
Old 10-22-2007, 06:37 PM
RitcheyRch's Avatar
Fellow Tundra Owner
Dealer : Frontier Toyota
2002 Toyota Tundra
RitcheyRch's Photo Albums
Last Online: Yesterday 08:55 PM
RitcheyRch is on a distinguished road.
Send a message via AIM to RitcheyRch
Default Re: Crcked Exhaust Manifold
Excellent news
Originally Posted by 2002toytundra View Post
Just got my manifolds changed, the O2 sensor was out and they did both sensors and the manifolds. They said the manifolds were prone to failure and that causes the O2 failures. I was told that new updated design manifolds were put on under the extended O2 warranty (7yrs or 90K miles)
  #17 (permalink)
Old 10-23-2007, 07:16 PM
Dealer : Laurel Toyota
mikejoann's Photo Albums
Last Online: 08-14-2008 04:30 PM
mikejoann is on a distinguished road.
I also have a 2000 V8 with 122k miles and noisy valves. It started at around 80k miles. I can hear it mostly while accelerating with the windows open, but it isn't noticeable while cruising. My mechanic checked it out and said it was the exhaust manifold gaskets. He said it is expensive to fix and recommended I don't bother to spend the money unless it gets unbearable. It hasn't gotten much worse since it started and I haven't had any problem yet.
Mike
2000 Tundra Limited 4x4 Access Cab
  #18 (permalink)
Old 10-23-2007, 10:34 PM
apimpdad's Avatar
2002 Toyota Tundra
My eBay apimpdad's Photo Albums
Last Online: Yesterday 09:52 PM
apimpdad is on a distinguished road.
Send a message via AIM to apimpdad
mine ticks pretty bad, it has done it since the day i bought it. its not really annoying but knowing that i can have it replaced under warranty up to 80k miles is good in case it does get worse.
2002 Tundra-SAS-Dana 50-Sterling 10.5-Inchworm 2.28 Dual Transfer Case-4.56 Gears-38.5 Thornbirds-ASP Underdrive Pulley-Flowmaster Muffler
Build Thread-
SAS on 02 Tundra
  #19 (permalink)
Old 10-23-2007, 11:27 PM
Dealer : Team Toyota Scion
Freedonutss's Photo Albums
Last Online: 10-06-2008 11:58 AM
Freedonutss is on a distinguished road.
Only reason its so unbearable is because your steering shaft boot is probably torn. My makes that same noise and ive had my exhaust manifold changed but it still makes that noise. Figured out it was normal engine noise and my steering shaft boot was just torn letting all that engine noise in. I replaced my steering shaft boot which took about 15 mins and now I hear absolutely no engine noise.
  #20 (permalink)
Old 10-23-2007, 11:30 PM
apimpdad's Avatar
2002 Toyota Tundra
i dont have a steering shaft boot . i still need to figure out a better way of blocking noise coming through there though.
Build Thread-
SAS on 02 Tundra
  #21 (permalink)
Old 10-24-2007, 11:00 AM
Maybe a CV boot or something. I saw you had this problem in another thread. Maybe try to custom fabricate a cv boot because they are much larger than the standard steering shaft boot. Ill see what I can come up with.
  #22 (permalink)
Old 11-15-2007, 09:03 PM
Cajun's Avatar
Dealer : Tusket Toyota
Cajun's Photo Albums
Last Online: 02-11-2008 08:14 PM
Cajun is on a distinguished road.
From what I've found... The cheapest fix for cracked exhaust manifolds is to fix them. Yes, a good machine shop can weld the weak area around the flange without damaging the manifold. I had my passenger side fixed. I paid $220 to have it removed, fixed and replaced. Oh I paid extra for new Toyota gaskets. Onced welded they shouldn't fail again.
The headers were tempting but this way was cheaper.
Gary
  #23 (permalink)
Old 11-16-2007, 10:22 PM
gbstundra002000's Avatar
Dealer : Bobby Rahal Toyota
gbstundra002000's Photo Albums
Last Online: 09-20-2008 09:16 PM
gbstundra002000 is on a distinguished road.
Mine cracked two days after I bought the truck and cost $1,700 to replace. The dealer went haves with me though. Checked with toyota then and they are covered under the powertrain warranty of 5years or 60 thousand miles if I remember correctly. I wanted headers then but didn't have the bucks. Sorry it happened to yet another person.
