Forced Induction SystemsDetailed discussions regarding cold-air intake systens, superchargers, turbo chargers, and other induction systems for your vehicle.
This is a discussion thread titled "Air intake Question", within the Forced Induction Systems forum, part of the Technical & Vehicle Assistance Forums category.
I have the K&N drop in filter and Helix throttle body spacer. I’m not sure if I notice that much of a HP increase. So should I take off these modifications that were put on when I received the truck and install an intake system? If so, which brand of intake system? Some of the reviews that I read said that the Throttle body spacer was a waste along with the drop in performance filter. I want one that will give me the most HP for the money. I emailed K&N and asked them if I’d have to remove my Helix throttle body spacer to install the FIPK intake system and of course they said yes.
Helix is a total waist of money. and as for the FIPK, I had one and it ruined my MAF sensor, the oil you put on it ruins the MAF. I did enjoy it while it lasted though. better throttle response and sounded pretty cool too. Ofcourse if you go extremely easy on the oil I bet you could get away with it.
"The glass isnt half empty or half full...
its twice as tall as it needs to be"
~How an engineer views life
what he said.
as for the throttle body spacer, from what i have heard, all it does is move the powerband up. it's nice if you spend a lot of time drag racing, but if you tow, you are actually losing power at the low end.
05 Salsa Red Pearl DC
01 Honda Civic
95 Acura Integra
The AEM Bruit Force CAI uses a rather large synthetic filter, easy to clean, just wash it, and no oil to screw up the MAF. I love mine, but I've got the other stuff to go with it for the HP, TQ & MPG.
Will be getting 50K service this week, and I have had no problems with my dealer's service dept. They like to see what I've done since the last visit, and of course they test drive it.
__________________ 2003 Tundra Access Cab Limited 4WD w/ all packages,Black-debadged. was stock 31K on 5/9/05, now 55K Click USERNAME, View Public Profile! Performance:UNICHIP module; AEM Brute Force Polished Intake System' AEM DryFlow Filter with red K&N DryCharger; AirRaid Throttle Body Spacer; JBA Titanium-Ceramic coated Headers; JBA Y-Pipe; Gibson CAT-Back Dual Extreme Stainless Exhaust; PulseStar Pulse Plugs; Fitch Fuel Catalyst System; Optima D35 Yellow Top; Battery Bug; Exterior:Extang Full-Tilt Tonneau Cover; Loading Zone Cargo Divider; Topline Tailgate Step; Mr. Gille Upper & Lower Billet Grille; WAAG Bumper Guards, front & rear; HT Side Step Nerf Bars; AVS Hood Protector with Graphics; WeatherTech Vent Shades; JDM Black Taillights; TurnSmart Solar-power Mirror Turn-Signals; Altec 48" Line-of-Fire LED Light Kit on rear; Altec 53" Screamer Amber Side Marker LED Light Bars; PIAA Backup/Work Lights; 35 % Tinting; BullyLED Third Brake/Cargo Light; Interior: Gentex Auto Dimming Compass/Temp Rear View Mirror; Garmin's Nuvi 660 GPS; Scan Guage II; Passport SR7 Radar/laser shifter; Passport G-Timer GT2; P.I.E. Adapter Wheels/Tires: Moto Metal M0951 Gloss Black 17 in. Alloy Rims; Goodyear Fortera TripleTred radials P275/60R17 Suspension:Bilstein HD Shocks, F&R; Hellwig Rear Sway Bar & Helper Springs; TCS Poly Steering Rack Bushings; Wheeler's Front Sway Bar Bushings; Timbren SES Kit, Front; SpiderTrax 1.25" Wheel Spacers; Brakes: TRD Big Brake Kit (front); BAD BONEZ BJ
I will agree the Helix is a waste of money. However the oil on a K+N type filter does not ruin the MAF. A fine coating can form, but is easily cleaned off. A properly oiled K+N filter for example will not harm the MAF, been running one for 200,000 mi, serviced every 50,000 and still have the original MAF. I clean the MAF every 20,000 mi with MAF cleaner spray available at the local auto parts store (takes about 5 min to do, real easy). There are a number of posts on cleaning a MAF. An over-oiled filter can cause grief as the MAF will get coated quickly and not work properly, but is is easily cleaned as mentioned. The trick is to carefully follow the oiling instructions that come with the filter, more is not better in this case.
The stock intake is good, however has a restriction that is easily fixed see the post on the "Engine and Drivetrain" forum called "Stock Airflow Numbers and Mod".
ya stock is the best i know of. my friend and i would race, mine stock, his had k&n.we would also switch with same results. i would be about 1 to 1.5 truck lengths at 60 with stock, then he would start catching me between 60-70, be neck and neck between 70-75, then he would pass me around mid 70s. needless you will be much slower on low end up until the 60's so unless you like to race people starting at 60-100 it is pointless
this was at sea level however, if it was at a higher altitude the story could be much different
First, yank the TBS. They are worthless.
Second, intakes are on of the most hotly debated topics on TS. Some folks swear by them and some folks swear at them.
There is a poll in the poll forum about the "best" intake, and the overwhelming choice is the stock intake. For most people, adding a intake will almost always result in the loss of low-end torque.
All a man really needs for happiness in this world is a good woman, a faithful dog, and a big-a$$ed set of tires on his truck.
Ride: 2001 Tundra SR5, 4WD, The Lean Mean Green Machine, Lift, Front: Bilstein 5100 Adjustable Shocks w/ Total Chaos Diff Drop, Lift, Rear: 1" Wheeler's Blocks, Wheels: Chromed Factory 4Runner Rims, 17", Tires: Bridgestone Revos, 285/70R-17, Performance: Unichip, Borla Exhaust, Bling: TRD Grille, Westin Nerf Bars, Clear Corners & Eurotails, Debadged, Audio: Factory Audio, XM Satellite Radio with P.I.E. Adapter, Shark Fin Antenna, Eye Candy: Hottie Wife in Passenger Seat, Security System: Two Very Large Dogs
fyi
My truck is a stock 2005 with a replacement 3 chamber flowmaster.
My buddies truck is a 2006 with a K&N CAI and a 3 inch full exhaust magnaflow(No headers) I beat him every time we race. Stock is where it is at.
__________________ '05 Tundra DC TRD 2 WHL: The TOW truck, Spectra Mica Blue, with Kenwood H/U, Kenwood Amp and crossover. Infinity 6010cs, 10" Rockford SUB, 6 disc CD Changer mounted in Center console, SWI-X to retain steering wheel controls, 7" TV with DVD. Tinted Windows, Three chamber Flowmaster, Painted front chrome strip
if you are wanting an intake go with the true flow system. it uses the stock box and replaces the intake tube with a much smoother direct one. as far as the tbs goes throw it away.
05 tundra
true dual aero turbines
true flow intake
asp pulley
9.43 in the 1/8
Dumb question from a not so knowledgeable engine guy....what does MAF stand for? manifold?
The only dumb question is the one not asked.
Mods: Spray in bedliner
Magnaflow dumped before axle
window tint
chrome door handles
true flow air intake
fully debadged
Removed resonator
blinglights foglights
Enkei Deep Six
Goodyear G-Force 295-45-20
