Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Forced Induction Systems
Old 03-30-2008, 03:12 AM
2XOverhead's Avatar
Moderator
Dealer : Toyota Scion of Santa Monica
2002 Toyota Tundra V8 SR5 TRD
Last Online: 11-18-2009 11:10 PM
2XOverhead will become famous soon enough. 2XOverhead will become famous soon enough.
2XOverhead's Photo Albums
Question K&N Filters
Just dropped about $60 on a K&N air filter that's supposed to be reuseable. What are some of your experiences on using these filters. Specifically, any issues w/ power, gas mileage, dirtying up your intake parts b/c the filter is "pre-oiled"; any other particular problems?
Or any particular advantages besides saving some money over time.
MODS: Oversized Drain Plug.
DIY: ATF Flush, w/ Pics.
DIY: Coolant Flush, w/ Pics.
Coming Soon?
Old 03-30-2008, 03:50 AM
JRE56's Avatar
Dealer : Spirit Toyota
1997 Toyota Camry
Last Online: Yesterday 05:44 PM
JRE56 is on a distinguished road.
JRE56's Photo Albums
Default Re: K&N Filters
I bought one for a Mitsubishi Eclipse turbo.No change in power or fuel mileage.I've had mine for 10 years.Its only good for longevity.This is the last filter you will buy for your car, just remember to clean and oil it at 50,000 miles.Sooner if you travel dusty roads.
Old 03-30-2008, 01:16 PM
kathyricks's Avatar
Dealer : Capitol Toyota
1993 Toyota Truck
Last Online: 06-02-2009 12:03 PM
kathyricks's Photo Albums
These three experts would tell you using a K&N is a good way to degrade or ruin your MAF sensor which in turn increases fuel consumption which in turn degrades the lifespan of your expensive California emission system components.
Old 03-30-2008, 02:35 PM
Mr. Creosote's Avatar
Legendary Contributor
Last Online: Today 01:46 AM
Images: 4
Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One.
Mr. Creosote's Photo Albums
The MAF sensor issues are a result of over oiling the filter. Oil it properly and there will be no issue.
That being said, it is true K&N filters have drawbacks. They do flow more air than most other filters, but they do so at the expense of filtering ability, i.e. they let in more dirt. Under most practical scenarios, such as daily commutes on paved roads, this will not cause problems. If you travel anywhere where dust is consistently present, however, you should not use a K&N filter. I run them on my daily drivers, but I would not use them on my ATV.
IMO a sign of their reduced dust stopping ability is the fact that K&N themselves sell a "pre-filter" to wrap around the outside of the filter to enhance its performance.
Old 03-30-2008, 02:41 PM
Images: 4
Here is a test showing how the K&N performs relative to other filters:
ISO 5011 Duramax Air Filter Test Report
Old 03-30-2008, 03:10 PM
Blackhawkxx's Avatar
Dealer : Folsom Lake Toyota Scion
Last Online: 07-08-2009 02:43 PM
Images: 13
Blackhawkxx is on a distinguished road.
Blackhawkxx's Photo Albums
IF you get a K&N filter.. I totally recommend getting the dry charger for added protection. Check my pic
2001 Toyota Tundra 2WD V8 SR5 X-Cab TRD Package, 2.5' Bilstein 5100 Adjustable Front Shocks, Rear Bilstein 5100 shocks, 1 1/4' Rear AAL, Poly Steering Rack bushings, Poly Sway Bar Bushings, Poly Upper and lower control arm bushings, Performance Accessories 3' Body lift, K&N Cold Air-intake FIPK GEN 2, K&N Blue Drycharger, JBA Headers, Gibson Dual Rear Split Exhaust, 16x10 American Eagle 186 Alloy, Mastercraft Courser A/T 285/75/16r
Old 03-30-2008, 03:35 PM
Dealer : Longo Toyota
2005 Toyota Tundra
Last Online: 09-22-2009 04:41 PM
Images: 6
mxracer3502 is on a distinguished road.
mxracer3502's Photo Albums
i would also recommend it with the dry charger. dont over oil if you dont get the dry charger... i dont think they would be that bad if toyota is willing to sell them right next to the trd section at my dealership. plus you make your money back buy cleaning them instead of buy a new one everytime you need to change it. ive had them on all my cars trucks and street bikes...but not on my dirtbikes for the above reasons...i use uni filters for that.
Old 03-30-2008, 04:12 PM
2XOverhead's Avatar
Moderator
So far all of your posts have me wondering about this product. The only plus, thus the only reason, I bought the thing is for it's lifetime use. By what you guys are saying, all the extra things/parts you have to do to maintain what otherwise should be a simple and carefree remove/replace maintenance procedure has me considering returning the thing.
I'm 80/20 on returning.
Coming Soon?
Old 03-30-2008, 04:55 PM
DJ DJ is offline
Dealer : Fowler Toyota
2001 Toyota Sequoia,
DJ will become famous soon enough. DJ will become famous soon enough.
DJ's Photo Albums
Which saves what, precisely? Replacing a filter requires a minute or two, so it doesn't save any time that makes it worthwhile. You'll be back to get other parts (oil filters, spark plugs, etc.) so it doesn't save any time at the parts counter that makes it worthwhile. Cleaning it now and then requires one hell of a lot more work and time than replacing it.
Methinks it ought to do something really worthwhile before it is worth your while, and I fail to see what that something is. It adds risk, cost, and labor, all without benefit.
That's why I don't use one. It ain't broke, so I don't fix it. The OEM Toyota filter does a fine job, it's inexpensive, and I'm content to replace it now and then. After 111,xxx miles, it still doesn't burn any oil between changes, and I'm quite satisfied.
Old 03-30-2008, 07:49 PM
Images: 4
IMO an optimal filter arrangement would be to somehow remodel the stock airbox to accommodate a Toyota paper filter with about twice the filter area than the stock one. This would provide the reduced restriction without allowing any dust to enter. Too bad it would be way too much work.
Old 03-30-2008, 08:53 PM
2XOverhead's Avatar
Moderator
Originally Posted by DJ View Post
...Methinks it ought to do something really worthwhile before it is worth your while, and I fail to see what that something is. It adds risk, cost, and labor, all without benefit....
95/5 on returning the thing.
Might as well make a game out of it. Who's gonna make it 100?
Coming Soon?
Old 03-30-2008, 08:55 PM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Last Online: Yesterday 02:02 PM
Images: 22
I totally recommend going and getting your money back.
Based on personal, long-term experience BTW. You will find many, many more threads on the subject.
-Sean
GFX by FreedomEagle50
Manual Hubs
Old 03-30-2008, 08:59 PM
2XOverhead's Avatar
Moderator
Alrightee then, 100% on returning the freaken thing. What am I gonna spend the extra 60 bones on?
Coming Soon?
Old 03-30-2008, 10:52 PM
Images: 4
I suggest the "Aliens" DVD four pack.
Old 03-31-2008, 11:02 AM
T100_2_TUNDRA's Avatar
Dealer : Checkered Flag Toyota
2005 Toyota Tundra
Last Online: 09-12-2009 09:40 PM
T100_2_TUNDRA is on a distinguished road.
T100_2_TUNDRA's Photo Albums
Maybe most of a tank of gas?
