Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Forced Induction Systems
  #121 (permalink)
Old 05-30-2008, 12:53 PM
Barberdan's Avatar
Dealer : Anderson Toyota
Last Online: 09-26-2009 01:44 AM
Images: 4
Barberdan is on a distinguished road.
Barberdan's Photo Albums
Default Re: TUNDRA TRD SUPERCHARGER: The Real Deal!!
I ran 94mph with a pathetic 2.5s(nearly) 60 ft time at 3300FT and 90 degrees. Corrected for altitude I did a 14.3 @ 97.5MPH but I know my RCSB could cut out some of that 60ft time with a little gas and break pedal staging before the launch. I can see how sfz989 got the times out of his tundra at 350ft above sea level. My Tundra was not anywhere close to chirping a tire at our grippy track in Eastern Idaho so a supercharger is going to mostly get to the ground on stock sized sport tires.
Oops, I got the elevation wrong. My pickup did 14.43 @ 96.7 corrected for 2700ft elevation. This was with about 400 miles on the odometer and a lift/leveling kit for the front. It should run much better now lowered and broken in.
2007 Toyota Tundra 4X2
5.7L Regular Cab/Short Bed
Sport package two seater
  #122 (permalink)
Old 05-30-2008, 01:08 PM
Sparks Toyota-TRD's Avatar
Preferred Dealer
Last Online: 11-06-2009 05:29 PM
Sparks Toyota-TRD will become famous soon enough.
Sparks Toyota-TRD's Photo Albums
with more power and torque, you can drive it out easier than if you had to kill it to get the times...........
now you will get more wheel spin if you just kill it of course and go no where, ...........spinnin' ain't winnin'............so you will have to find the "sweet" spot for the leave for sure.
and learn how to drive it all over again.
Mark
TRDSPARKS.COM TRD Performance Parts and Accessories at Discounted Prices!
Toll Free#1-866-249-3607
WILL TRD / AFTERMARKET PARTS VOID MY WARRANTY? NO -->> http://www.trdsparks.com/warrant_aft..._products.html
  #123 (permalink)
Old 05-31-2008, 12:03 AM
Dealer : Wilde Toyota
2007 Toyota Tundra DC SR5
Last Online: 06-06-2008 06:25 PM
FIVE.seven is on a distinguished road.
FIVE.seven's Photo Albums
Originally Posted by GameOver View Post
And im even sorrier to burst yours but I guarantee you the rcsb does low to mid 12's with a sticky set of tires (2wd) and the double cab should pull off high 12's espescially with a set of longtubes, intake, and catback.. Just wait and see and I won't even say i told ya so. That instant trq that the supercharger will provide is going to make a huge difference and it will also smooth out the power and trq curves making it even more efficient.
May I ask how you can "guarantee" that? Have you looked at the torque curve? Do you know how much boost is provided at what rpm? And then you're talking about stickies, longtubes, intake, and catback. Well, now we're talking about two different things aren't we? I don't think you were actually reading what I wrote. Instead, I think your Toyota pride was just hurt a little bit though it was no intention of mine. Remember I own one too and I'm just stating what I see from a sheer numbers standpoint. You on the other hand are "guarantee'in" something based on ummm, nothing.
Consider that an Ram srt 2wd which weighs in at about 5000lbs curb has about the same power figures as the TRD 5.7 and only does mid 13's. How do you propose to get a truck that weighs almost a thousand more pounds to do a better time with the same power?
See, what alot of people don't understand is that if you have a lighter vehicle, say 3000lbs, then 123 additional hp will equate to a neck breaking difference. However, when that vehicle is almost twice that weight, well... you essentially need twice the power to feel the same neck breaking difference as in the 3000lb vehicle. It's all about power to weight ratio. Why do you think a 200 whp civic can run 12's?
  #124 (permalink)
Old 05-31-2008, 10:04 AM
GameOver's Avatar
2009 Toyota Tundra
Last Online: 11-28-2008 06:54 PM
GameOver is on a distinguished road.
Send a message via AIM to GameOver GameOver's Photo Albums
Well, I don't know where you mentioned that a bolt on supercharged tundra was excluded..? But yes with a CAI, Longtubes, Exhaust, and a programmer Its all lined up for it to happen. with the 18 inch stock steel wheels, and weighing in at 5,000 lbs it will take about 575 hp to the flywheel (pretty good estimate) to run a 12.3, and with the above mentioned mods that may be dead on or a little conservative. I'm just saying I'd be willing to bet on it. And the ford lighting weighs in at almost 4700 lbs curb weight and I've seen plenty that arent much past the 500rwhp mark doing low low 12's highs 11's. I'm also quoting the times that would be ran where I live in Central FL where im right at sea level, so take that into consideration.
2009 RCSB Tundra 5.7 (on its way)
Turbo Project to follow shortly
  #125 (permalink)
Old 05-31-2008, 10:35 AM
Go Fast's Avatar
Dealer : Branch Toyota
Last Online: 09-28-2009 08:59 AM
Go Fast is on a distinguished road.
Go Fast's Photo Albums
It's going to be interesting to see how fast the RCSB's are going to be with a Stock TRD Supercharger. I'm thinking my DBL cab, with good air should be able to run high 12's. Should have put mine on the scales, when I was at the track to check the exact weight.
New personal best 1/4 Et for 2008 season.
14.311 @ 94.35 60 Ft 2.072 >> Working on 14.2's
2007 Tundra 4x4 Dbl Cab 100% Stock No Mods:
http://www.dragtimes.com/Toyota-Tund...lip-15251.html
2007 Tundra 5.7 DBL Cab 4x4 LTD, Radiant Red, Options:
FE, CK, AL, MG, NV, CF, BL, RB. Best ET 2007: Record Run Et For Dbl Cab 14.412 @ 93.58 MPH & 60 Ft Et Record For Dbl Cab and RCSB
@ 2.082, R/T .016, 330ft 5.979 & 1/8 Mile 9.227 @ 75.24 MPH. 100% Stock No Mods. At New England Dragway, Epping, NH On A Porta Tree Timing System. Picture & Time Slips Posted At. http://www.dragtimes.com/Toyota-Tund...lip-13779.html
1999 Suzuki Hayabusa GSXR 1300, Stock Motor,Pipes, & Swing Arm.
Best ET 1/4 Mile 9.559 @ 143.23 MPH, 60Ft 1.529, 1/8 Mile ET 6.161 @ 116.86 MPH
Picture & Time Slips Posted At. http://www.dragtimes.com/Suzuki-Haya...lip-13818.html
ISR Legal Stocker,2003 Arctic Cat F7 Twin: 1/8 mile 6.392 @ 98.4 MPH 60Ft 1.302 Driver Jenny.... "Jenny Jet"
http://www.dragtimes.com/Arctic%20Ca...lip-13819.html
Stock 08 Ford Shelby GT 500, Vista Blue.
New Personal Best ET 12.200 @ 115.22 MPH At New England Dragway. Time Slip At Link Below. Working on getting into the high 11's before any engine mod's!!!
http://www.dragtimes.com/Ford-Mustan...lip-15418.html
  #126 (permalink)
Old 05-31-2008, 10:44 AM
GameOver's Avatar
2009 Toyota Tundra
And I'm right with you on that. at sea level or darn close a DC tundra (traction permitting) should do high 12's.. I'd say 12.6-12.7 at the fastest
  #127 (permalink)
Old 05-31-2008, 10:59 AM
Go Fast's Avatar
I think the track we race at is about 200 Ft above see level. Agree with you about getting good traction for those Et's as well. In 4x4 with stock TRD Supercharger, there should be no problem with traction, but not really sure how the 4x4 system will hold up with that much power!?!?!?
  #128 (permalink)
Old 05-31-2008, 11:05 AM
GameOver's Avatar
2009 Toyota Tundra
Only time will tell, but Im pretty sure at stock boost the supercharger wont cause too much stress on it. Also im curious to see when someone tries to launch in 4wd and switch to 2wd after the holeshot..
  #129 (permalink)
Old 05-31-2008, 11:40 AM
Mr. Creosote's Avatar
Legendary Contributor
Last Online: Today 03:14 AM
Images: 3
Mr. Creosote has done just about everything. Mr. Creosote has done just about everything. Mr. Creosote has done just about everything. Mr. Creosote has done just about everything. Mr. Creosote has done just about everything. Mr. Creosote has done just about everything. Mr. Creosote has done just about everything. Mr. Creosote has done just about everything. Mr. Creosote has done just about everything. Mr. Creosote has done just about everything. Mr. Creosote has done just about everything.
Mr. Creosote's Photo Albums
You must have to let off the gas for an instant to get the tcase to switch back, which would cancel a fair amount of what you might have gained anyway. For traction without the 4WD drag, I would just use drag radials and 2HI the whole run.
  #130 (permalink)
Old 05-31-2008, 11:56 AM
Go Fast's Avatar
Will not shift back into 2 wheel drive under full throttle!!! If you back of the throttle,there goes your good Et!!!
  #131 (permalink)
Old 05-31-2008, 12:31 PM
GameOver's Avatar
2009 Toyota Tundra
hmm, 2 bad they can't have the on the fly system such as the Dodge Cummins pickups..
  #132 (permalink)
Old 05-31-2008, 05:56 PM
Dealer : Conicelli Toyota Scion of Conshohocken
Last Online: 09-23-2009 11:02 PM
Images: 24
MakeItYourOwn is on a distinguished road.
MakeItYourOwn's Photo Albums
It is 'on the fly', but it won't engage / disengage under full throttle.
  #133 (permalink)
Old 05-31-2008, 06:01 PM
guntech's Avatar
Benny Hill
Dealer : Prestiqe Toyota
2003 Toyota Camry,
Images: 71
guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything. guntech has done just about everything.
guntech's Photo Albums
Anyone that is going to be raceing 12s or low 13s, should be running either drag radials or slicks. Otherwise, you just doing things 1/2 azzed.
  #134 (permalink)
Old 06-01-2008, 01:05 AM
Dealer : Fremont Toyota
Last Online: 10-10-2009 10:27 AM
Images: 7
sofix is on a distinguished road.
sofix's Photo Albums
i wonder if chips will be able to fix it???
  #135 (permalink)
Old 06-01-2008, 02:26 PM
GameOver's Avatar
2009 Toyota Tundra
Not if it's a 4wd vehicle..
