I have a 2003 Tundra V8. A few weeks ago I installed a new TRD Supercharger. Something that has me puzzled is this. After passing a slow car on the highway (with help of forced induction) the Air conditioning compressor stopped running. Within a few minutes the dash vents started blowing warm air. I switched the A/C off and on a few times and it didn't help. So I turned off the A/C switch for 3 minutes. I turned it back on and had all kinds of cold air!
Now when you floor the accelerator it makes sense for the truck's electronics
to turn off the A/C for those 6-7 seconds ( parasitic drag). But when you let up on the gas and are back to cruising the A/C should turn back on.
Any others have this problem?
George60
LACK OF PLANNING ON YOUR PART ----------------
DOES NOT CONSTITUTE AN EMERGENCY ON MY PART !!
Ya know, i drive an '03 supercharged tundra, as well. I just recently ran into a SIMILAR problem. My a/c is intermittently not cooling. I turn it off for a minute or so, and when i turn it back on, it's ok. However, i've also noticed that i'm intermittently running pretty hot (engine, not a/c). My guess is that i have a coolant leak, but i'm not certain that the two are related. It could be coincidence that they show up together. My other guess is that I have a busted thermostat. I include this info as the overheating and a/c thing showed up at the same time. are you noticing the overheating?
I've changed a thermostat before, it it was in an older jeep grand cherokee- I think the fact that there's a supercharger is going to make replacing it a bit tougher. I'll be looking into that.
I don't have any problem with overheating. Even in the extreme heat we've had in the last 2 weeks the temp gauge sits where it always has -- right in the middle.
I installed the new thermostat that came w/the SC ... 160 vs. 190 degrees.
George60
I have 2003 supercharged tundra, and I don't have that problem... running with AC and full boost with out any issues.
I am with you, except mine is a 2002 S/C. It blows cold all the time, full boost or not. I did add an aux fan like the sequoia to help with Idle conditions, but that is because I have a body lift.
Glad to hear your problem went away.
25 yrs with TOYOTA
George60
Hi George. I was thinking about this and due to this being a recent install, there is a chance there could be a wire loose going to your AC compressor or pressure switch. I know it is working now but you might want to make sure the connection is good so you don't end up without AC agian. Best of luck.
03 Stratosphere Mica Stepside, 4.7 L, Supercharger, TRD Package, TRD Exhaust,
Scion Head Unit 08600-21802,
Custom leather heated seats 2 tone with TRD LOGO, Moonroof, ARE LID, ZR3 Laser Shifter, Denso IK22 .4mm Iridium Plugs, Scan Gauge 2,
Rhino Liner, Die Hard Platinum P5 battery 5.7 Killer
