Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Forced Induction Systems
Old 10-01-2008, 05:35 PM
jjhu00's Avatar
Dealer : Rudy Luther's Toyota
2008 Toyota Tundra "Moby Dick"
Last Online: 11-19-2009 09:53 AM
Images: 3
jjhu00 is on a distinguished road.
jjhu00's Photo Albums
Default 5.7L Supercharger bypass defeat
anyone figured out how to defeat the boost bypass valve on the new TRD superchargers for the 5.7L engine? this procedure will enable constant boost from the supercharger in any rpm range rather than wasting it through the bypass loop for fuel economy sake.
Old 10-01-2008, 05:57 PM
TRDatVT's Avatar
Dealer : Gloucester Toyota
2008 Toyota Tundra Salsa Red DCSB SR5
Last Online: 11-24-2009 10:02 PM
Images: 6
TRDatVT is on a distinguished road.
TRDatVT's Photo Albums
Default Re: 5.7L Supercharger bypass defeat
From prior experience with a actuator (bypass) valve on the TRD chargers... The bypass valve allows for reduced wear (on the supercharger and the belt) and drag on the motor during normal around town driving. Defeating the bypass can be done usually by simply removing the hose that allows the valve to see vacuum (thus it will see atmospheric pressure always). I do think this is unecessary and will cause reduced life of the internals as well as unecessary reduction in power and throttle response during around town driving due to increased load on the motor and no boost... ALSO, the supercharger will NOT always produce full boost (although it will be at full boost alsmot immediately after 2000 RPM)... removing this valve probably will not improve performance at all.... Just my $0.02
Josh
2008 Salsa Red Pearl DCSB SR5 2WD
Corsa Sport Single Exit, Doug Thorley's, 20% Tint up front, Line-X, Access Roll-Up Tonneau, Alpine Touchscreen Nav, Sirius Satalite Radio...
VA 757 Area Group MEETS
Future Mods: Color Matches Grill, Lowering Kit, TRD CAI, Wheels, Fender Flares, Supercharger, JL Stealthbox, Black Headlight Mod...
Old 01-08-2009, 08:10 AM
Dealer : Power Toyota Scion Tempe
2006 Toyota 4Runner
Last Online: 09-26-2009 01:43 PM
fzust is on a distinguished road.
fzust's Photo Albums
Actually, defeating it is really bad. The bypass, just keeps the S/C from sucking against a closed throttle plate, cavitating, and super-heating air. it is vacuum activated, so when you get your foot in it, it closes and you get full boost when you need it. Bypass is a good thing. No downside.
Old 01-16-2009, 08:13 PM
bulldog11267mad's Avatar
Dealer : McGeorge Toyota
2003 Toyota Tundra
Last Online: Today 12:27 AM
Images: 4
bulldog11267mad will become famous soon enough.
bulldog11267mad's Photo Albums
this is kinda on and off topic but does anyone know of a smaller pulley for the trd supercharger? and has anyone made a custom pulley? if so how much more power did you get?
Old 01-16-2009, 08:26 PM
tinik's Avatar
Travel & camping is 2 much fun
Dealer : Cramer Toyota Scion of Venice
2006 Toyota Sequoia,
2001 Toyota Tundra Supercharged
Images: 51
tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One.
tinik's Photo Albums
There is a company that makes oversize crank pulley (to increase your boost)... As far as getting smaller pulley for SC I don't think its possible to get one.
2006 Toyota Sequoia Limited 4x4 w/ lxr package, 7008 navi, rear entartaiment system, 20" x-sp enkei.
2001 Toyota Tundra SR5 4x4 - TRD 9+Psi Supercharged, JBA Ceramic Headers, Walboro 255LPH Fuel Pump, 1UZ Rods, 20" x-sp enkei wheels, 7009 navi w/custom JBL wire harness + OEM XM/Sirus radio, drive by wire, and many other mods.
