Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Forced Induction Systems
Old 10-29-2008, 06:38 PM
TUNDRA10X's Avatar
Dealer : Scott Toyota
2002 Toyota Tundra
Last Online: 11-20-2009 09:08 AM
Images: 110
TUNDRA10X is on a distinguished road.
TUNDRA10X's Photo Albums
Default IK22 Denso Iridium plug change
Three years, five months and 32,500 miles after the supercharger install I replaced the originals today with more of the same. Every one of the plugs were at 'zero torque' ie., every one of them was loose! I think a re-torque after a few miles and hot/cold cycles is a must! Note the "mushroom" shape of the center electrode and the "ideal color of toasty brown" on ceramic center.......Very even cylinder to cylinder. No particular plug stood out in color or wear. A few more pics in My Albums, just click on camera icon ubove.
IK22 Denso Iridium plug change-ik22-plugs-and-under-bonnet-001.jpg   IK22 Denso Iridium plug change-ik22-plugs-and-under-bonnet-003.jpg   IK22 Denso Iridium plug change-ik22-plugs-and-under-bonnet-005.jpg
Old 10-30-2008, 05:42 PM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Last Online: Yesterday 11:30 PM
Images: 12
HOGWILD is a splendid one to behold. HOGWILD is a splendid one to behold.
HOGWILD's Photo Albums
Default Re: IK22 Denso Iridium plug change
One of those plugs looked really oily on the outside? guess probably cause you said they were not tight? Great looking Truck with some nice looking mods! BRAVO!!
Old 10-30-2008, 06:55 PM
TUNDRA10X's Avatar
2002 Toyota Tundra
Images: 110
Thank you, and on closer inspection you are correct! That was number 3 on the right bank. The discoloration is probably blow-by as there is no oil or burnt residue on the threads, just darkened and dry. When extracting them I could tell the tech probably didn't use any anti-seeze as they 'grabbed' and 'chattered' while turning all the way out.....Sure enough, no evidence of anything on the threads. How about some more close-ups:
IK22 Denso Iridium plug change-ik22-plugs-and-under-bonnet-041.jpg   IK22 Denso Iridium plug change-ik22-plugs-and-under-bonnet-040.jpg   IK22 Denso Iridium plug change-ik22-plugs-and-under-bonnet-034.jpg   IK22 Denso Iridium plug change-ik22-plugs-and-under-bonnet-039.jpg   IK22 Denso Iridium plug change-ik22-plugs-and-under-bonnet-036.jpg
Old 10-30-2008, 10:07 PM
HOGWILD's Avatar
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Images: 12
Really nice ALBUMN ya got! So how many miles can ya get on a set with your setup? Does your truck have the speed nanny on it? 06's have them cause of tire ratings! I use only a small stripe of the stuff when i install plugs and cut torque to about 6 ftlb! I do not like it all goobered up at bottom of hole! My 93 has an accumulation down near holes and i have been trying to figure how to clean it but not too big a deal! I do 30K intervals on my 3.0 V6 plugs!
Old 10-31-2008, 02:30 PM
TUNDRA10X's Avatar
2002 Toyota Tundra
Images: 110
Some say these are good for 100,000. After examination with a 12X loupe of new verses old, I'd call that a stretch. The tips have melted at 32,000+ miles into a neat little ball. Yes, TRD ECU w/single 9th injector non VVTI--2002........Nanny firmly embedded.
IK22 Denso Iridium plug change-ik22-plugs-and-under-bonnet-043.jpg   IK22 Denso Iridium plug change-ik22-plugs-and-under-bonnet-042.jpg
Old 11-01-2008, 01:11 PM
HOGWILD's Avatar
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Images: 12
I will do mine at 50K and i am not running the same plug but they are Iridiums and i feel any longer will be a stretch myself! Will also be doing Coolant and ATF for same reason around same 50K time frame! cause i can
Old 11-30-2008, 10:10 PM
UnSub's Avatar
Dealer : Toyota of Irving
2004 Toyota 4Runner,
2003 Toyota Tundra TRD Supercharged
Last Online: 11-16-2009 09:59 PM
Images: 6
UnSub will become famous soon enough. UnSub will become famous soon enough.
UnSub's Photo Albums
The IK22 are 30k plugs. They are performance plugs and not made to last 100k like other iridium plugs. You can check the specs on sparlplugs.com.
03 Stratosphere Mica Stepside, 4.7 L, Supercharger, TRD Package, TRD Exhaust,
Scion Head Unit 08600-21802,
Custom leather heated seats 2 tone with TRD LOGO, Moonroof, ARE LID, ZR3 Laser Shifter, Denso IK22 .4mm Iridium Plugs, Scan Gauge 2,
Rhino Liner, Die Hard Platinum P5 battery
5.7 Killer
Old 01-24-2009, 11:50 AM
tinik's Avatar
Travel & camping is 2 much fun
Dealer : Cramer Toyota Scion of Venice
2006 Toyota Sequoia,
2001 Toyota Tundra Supercharged
Images: 51
tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One.
tinik's Photo Albums
Do you know what part number for toyota dealer? I want to change mine, and dealer have no clue what part number is.
thanks
gene
2006 Toyota Sequoia Limited 4x4 w/ lxr package, 7008 navi, rear entartaiment system, 20" x-sp enkei.
2001 Toyota Tundra SR5 4x4 - TRD 9+Psi Supercharged, JBA Ceramic Headers, Walboro 255LPH Fuel Pump, 1UZ Rods, 20" x-sp enkei wheels, 7009 navi w/custom JBL wire harness + OEM XM/Sirus radio, drive by wire, and many other mods.
Old 03-01-2009, 12:03 AM
UnSub's Avatar
Images: 6
thanks
gene
Part number PTR24-34050 is what I used for a set of 4 plugs. I later found them $2 cheaper each at URD ($9.75 each). Sorry I did not see your post earlier
5.7 Killer
