Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Forced Induction Systems
Old 10-30-2008, 07:02 PM
Dealer : Brimell Toyota
2002 Toyota Tundra
Last Online: 05-20-2009 09:51 AM
rotarex is on a distinguished road.
rotarex's Photo Albums
Default Compression ratio and turbo
hey guys, as some of you know im planning of rebuilding my engine, but im doing some prep work, buying everything before i do my rebuild and so on,
4.7 engine
my question is the 8.5 or the 9.0 for compression which one do i want to go for to use the STS system?
will one deliver more power across the ban? how much big of a difference is it? and will it make my MPG worst before i install the turbo..??
the engine will be rebuild but will wait for turbo when i have more money
also
is it possible to use the RX7 twin turbo? this way i can have low and top end power rather than a single turbo working more at top end ?
sorry im a newbee at the turbo, i am a pro at NA rotary only
i just notice the URD rotrex SC the lower compression ratio pistons would be good for that setup also rite? seems in my price range, anyone running the setup?
Old 11-06-2008, 03:36 AM
Dealer : Germain Toyota Scion of Naples
Last Online: 09-09-2009 04:26 PM
scaryperson27 is on a distinguished road.
scaryperson27's Photo Albums
Default Re: Compression ratio and turbo
I don't think you have a clear idea of what you are getting yourself into with this engine. I would say get a faster car...
2000 Tundra 2wd V8
Some decal work done.
Hope to have UD pulley soon
Old 11-11-2008, 09:50 AM
barron64's Avatar
Dealer : Lynch Toyota of Auburn
2006 Toyota Tundra DC 4x4 SR-5,
1996 Toyota Tacoma LX Extra Cab 5-Speed
Last Online: Today 09:51 AM
Images: 9
barron64 is on a distinguished road.
barron64's Photo Albums
If you are running a low boost system, say 5lbs of boost max, you can stick with stock compression ratio. Keeping your compression ratio high keeps your low end throttle response and torque. Lowering the compression allows for more boost but kills your bottom end power until the turbo spools up.
Old 11-14-2008, 08:49 AM
v6er's Avatar
Dealer : Brown's Charlottesville Toyota
Last Online: 10-19-2009 09:02 PM
v6er is on a distinguished road.
v6er's Photo Albums
O boy do you have alot to learn before you should doing a turbo build yourself, I recommend you get a couple good books on turbocharging and read up. I would recommend "Street Turbocharging" by Mark Warner. Very informative book, well explain everything you need to know about building a boosted engine. Also find someone who knows what they are doing to help out. And good luck, I'd love to see a boosted tundra.
"The glass isnt half empty or half full...
its twice as tall as it needs to be"
~How an engineer views life
Old 11-17-2008, 09:57 AM
Eddie's Avatar
Moderator
Dealer : Crystal Toyota
2000 Toyota Tundra,
- Other - 93.5 Supra
Images: 32
Eddie will become famous soon enough. Eddie will become famous soon enough.
Eddie's Photo Albums
Read this too Amazon.com: Maximum Boost: Designing, Testing, and Installing Turbocharger Systems (Engineering and Performance): Corky Bell: Books
