Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Forced Induction Systems
Old 09-16-2009, 06:44 PM
Highwaylizard's Avatar
Dealer : Butler Toyota Scion
2004 Toyota Tundra Limited DC 4.7 4spd
Last Online: 11-17-2009 06:13 PM
Images: 64
Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all. Highwaylizard is a name known to all.
Highwaylizard's Photo Albums
Default Ram Air Intake Scoop
Well I finally have the latest revision of my ram air intake scoop fabricated and hope to have it installed on the truck late tonight. This version incorporates a design change that was suggested by Boosted27606 which has proved to be very effective. The old scoop had a boxed back wall and this latest revision has a curved floor to smooth out the transition of the air flow from horizontal to the vertical uptake tube that feeds through the fender well to the air box.
Here are a few pictures and I will post back with the results in a week or two.
Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with True Flow foam filter, Mobile 1 in the engine, K&N oil filter, Royal Purple in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Toyo H/T Open Country tires.
testis amotio per pera
150,620miles on the odometer Tundra Fuel Economy Blog
19+ MPG on the Highway at 75 MPH in a DC with a four speed automatic and a bad O2 sensor - not too shabby!
Old 09-16-2009, 07:38 PM
Images: 64
Default Re: Ram Air Intake Scoop
Some more pictures before the install tonight.
Ram Air Intake Scoop-ram-air-ii-front.jpg   Ram Air Intake Scoop-ram-air-ii-inside.jpg   Ram Air Intake Scoop-ram-air-ii-bottom-curve.jpg
Old 09-16-2009, 08:28 PM
Gutz's Avatar
Diplomacy is dead!!!
Dealer : Fletcher Jones Toyota
2007 Toyota Tundra 5.7 RC/SB
Last Online: Today 12:16 PM
Images: 15
Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything.
Gutz's Photo Albums
Awesome!!!!
iF57 Tundra Racing Club
Old 09-16-2009, 10:39 PM
Marky_Mark's Avatar
Rut Ro!
Last Online: Yesterday 11:41 PM
Images: 13
Marky_Mark has done just about everything. Marky_Mark has done just about everything. Marky_Mark has done just about everything. Marky_Mark has done just about everything. Marky_Mark has done just about everything. Marky_Mark has done just about everything. Marky_Mark has done just about everything. Marky_Mark has done just about everything. Marky_Mark has done just about everything. Marky_Mark has done just about everything. Marky_Mark has done just about everything.
Marky_Mark's Photo Albums
Awesome!!!
"They Were Just Jealous That My Tundra Pulled More Kitty's Than A Bowl Of Milk"
Old 09-17-2009, 10:35 AM
Images: 64
Originally Posted by Gutz View Post
Awesome!!!!
Originally Posted by Marky_Mark View Post
Awesome!!!
Hey Thanks guys. We did not get it installed last night. Welding on the trailer ate up my allotted time so I am scheduled back in tonight. Getting the mounting bracket unbolted will take some time and then I need to take a cut-off wheel to the old scoop so I can reuse the mounting bracket. If all goes well I should be able to post pictures of the install sometime tomorrow evening.
I am looking forward to how this works out compared to the original scoop.
Old 09-17-2009, 11:39 AM
Tundradrenalin's Avatar
Assistant Administrator
Last Online: Today 09:35 AM
Images: 205
Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family.
Very slick. Please paint this one.
Keep us updated!
Under the Hood: AMSOIL Synthetic Lubes all around, AMSOIL Ea Air Filter, Doug Thorley Headers, Magnaflow Exhaust, Semi-RAMair airbox mod
Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, 1.5" Wheeler's blocks, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear]
Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES
Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full LED Conversion
Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead
Cosmetic: Line-X Bedliner, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve, Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
Old 09-17-2009, 12:10 PM
Images: 64
Keep us updated!
Hey Tundradrenalin!!
Thanks for the compliment. No painting as this one is stainless steel too. Paint does not bond to stainless very well under ideal conditions and this being exposed to some serious friction (air flow) would lead to pealing very quickly.
At any rate I am not out mowing today so I am finishing up the trailer and then going to tackle getting the old scoop off the truck. I may not be able to get it off of there as the bolts I used were not metric so they may be unwilling to cooperate. I have not been able to find the metric bolt size for the mounting location I have been using.
Old 09-18-2009, 08:08 PM
Images: 64
Quick update: the guy who does my tigging forgot to come in so we had to reschedule for next week. I am anxious to get this done and see the results.
Old 09-19-2009, 12:23 PM
jbtoy's Avatar
Dealer : Boch Toyota South
Last Online: Today 06:15 PM
Images: 55
jbtoy will become famous soon enough.
jbtoy's Photo Albums
Me too! So far, looking good there.
John
The Toy: 2000 Tundra 4.7L TRD Limited 4x4 Red Pearl (23.0k Original Miles)
The mod list is long. Check some pics in my gallery for mod detail.
Old 09-20-2009, 02:21 PM
escondidotundra's Avatar
Dealer : Kearny Mesa Toyota Scion
2003 Toyota Tundra
Last Online: 11-18-2009 09:09 PM
escondidotundra is on a distinguished road.
escondidotundra's Photo Albums
subscribed
Old 09-25-2009, 11:39 PM
Images: 64
Tentatively scheduled in for Monday night to do some welding and hope to get the new mounting bracket fabricated and the new scoop tigged to the bracket. Replaced the passenger manifold O2 and while I had the wheel off I took a picture of the hose that is routed through the fender line from the present scoop to the air box.
Old Yesterday, 03:59 AM
tundrunk's Avatar
2003 Toyota Tundra sr5 1wd
Last Online: Today 06:32 PM
Images: 18
tundrunk will become famous soon enough.
tundrunk's Photo Albums
AAAWWW! Come on man! I just found this thread and got teased by the ending! Nice job on that, any updates?
