Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Forced Induction Systems
Free Shipping at Buy.com!
FREE Personal Trainer Program
Forced Induction Systems Detailed discussions regarding cold-air intake systens, superchargers, turbo chargers, and other induction systems for your vehicle.
This is a discussion thread titled "Intake Air Temperature Mod", within the Forced Induction Systems forum, part of the Technical & Vehicle Assistance Forums category.
Old 08-22-2003, 11:05 AM
scdtrd's Avatar
Dealer : Lagrange Toyota
scdtrd's Photo Albums
Last Online: 07-31-2008 04:34 PM
scdtrd is on a distinguished road.
Lightbulb Intake Air Temperature Mod
Intake Air Temp Mod:
Has anyone DONE this?
Put the resistor inline with the sensor?
If so.. PLEASE... what is the resistance and type of resistor used?
I need the info to do this myself please!
Thanx!
SCDTRD
The Beast:
1994 Toyota Camry V6 XLE
The Mods:
Front tower Ractive Strut Bar, Whiteline rear AntiSway Bar, Rage Breaker 17.5x7 Rims and Falken Ziex 512 rubber, Limo Tint, Pioneer DEH 7700MP Head Unit, Polk 6x9 rear and Polk 6.5 Front speakers, Tokico struts front and rear, Carbon kevlar brake pads, Cryo treated rotors, ZEX 82021 N2O system, Polished and ported upper and lower intake runners, shift kit, and more to come.....and.... YES... it is a CAMRY....
"Back in the black!"
Old 08-22-2003, 03:44 PM
scdtrd's Avatar
C'Mon.. SOMEone out there knows.. please post!
The Beast:
The Mods:
Old 08-23-2003, 12:42 AM
Dude Boy's Avatar
Dealer : Toyota of Gladstone
2000 Toyota Tundra,
- Other - 1952 Ford F-1 4x4
Dude Boy's Photo Albums
Last Online: 02-24-2008 12:50 AM
Dude Boy is on a distinguished road.
Search Muddog17's posts. He's into that sort of thing.
ADDING POWER HAS NEVER BEEN SO FAST!
Old 08-25-2003, 05:33 AM
scdtrd's Avatar
I did a search for Muddog17, but there is no member listed with that name?
Is that member using an alternate name?
SCDTRD
The Beast:
The Mods:
Old 08-25-2003, 06:11 AM
nhparrot's Avatar
Dealer : Rockingham Toyota
2007 Toyota Tundra Slate Blue CrewMax
nhparrot's Photo Albums
Last Online: Today 06:14 AM
nhparrot will become famous soon enough.nhparrot will become famous soon enough.
Try Mudog715
~Glenn~
Forum Rules
Got a question 'bout TS.com site policy? click
HERE!
Old 08-26-2003, 12:23 PM
scdtrd's Avatar
I believe I found it.. put a 4.7Kohm resistor in series with the IAT and it will trick the ECU in thinking it is 30 deg cooler than it really is. Should be good for 2 - 3 deg timing adv and a bit richer on the juice!
Who knows... will try and let you know!
SCDTRD
The Beast:
The Mods:
Old 08-26-2003, 04:49 PM
Eddie's Avatar
Dealer : Crystal Toyota
2000 Toyota Tundra,
- Other - 93.5 Supra
Eddie's Photo Albums
Eddie is on a distinguished road.
SCDTRD
Sounds about right,a coolant temp sensor should read around the low 30's (degs F) with that much resistance. And since the coolant temp sensor is a thermistor,resistance goes down as temps go up. A 1/2-watt resistor should handle the 5 volts that runs through the sensor circuit.
I'd run a SPDT switch so the resistor can be bypassed,and/or a pontentiometer to allow some adjustability to the sensor readings.
Old 08-26-2003, 05:41 PM
scdtrd's Avatar
COOL!!! I did not think of that.... A serious idea!
I can add BOTh a coolant mod and a IAT mod BOTh with pots... and "dial in" what I need.. Drive and test.. drive and test!
Hmmmmm... on to something here!
Thanx!
SCDTRD
The Beast:
The Mods:
Old 08-26-2003, 06:42 PM
Eddie's Avatar
2000 Toyota Tundra,
Thanx!
SCDTRD
Hmmm...coolant and IAT mod huh? Similar to a device I made
Mine bypasses the coolant temp sensor though,it's for testing purposes. I use this device to test certain emissions components,and to test them the coolant temp has to be within 15 degrees of air temp. The air temp sensor gets a fixed resistance while the coolant temp has a pot in order to "fine tune" the temperature. Of course you need a scantool to verify the temps.
I'd take photos of it,but the digicam broke
Old 08-26-2003, 11:27 PM
scdtrd's Avatar
OK... ok.. so tell me you made such a device. What were the resitance values of the Coolant and IAT? I know I need a SPDT pot in the 5 to 10 watt range. Please share!
This is great info!
SCDTRD
The Beast:
The Mods:
Old 08-28-2003, 09:29 PM
Eddie's Avatar
2000 Toyota Tundra,
This is great info!
SCDTRD
I'm using a 1.5K ohm resistor for the air temp sensor. A 0-2K ohm linear taper pot for the water temp sensor. There's also a SPDT switch wired after the pot to switch between the pot and a 180 ohm resistor. They're 1/2 watt resistors by the way.
Since you're "piggybacking" the sensors I'd use a higher resistance pot,like 5K ohm. I'm trying to create hotter readings,not cooler.
The box and my multimeter are at work,I'll bring both home tomorrow. I won't be able to get you the actual resistance values vs. temp readings until Monday since I'll be out all weekend.
Old 08-29-2003, 06:26 AM
scdtrd's Avatar
That would be very kewl!!!
Thank you for doing that.. I hope you have a great and SAFE labor day weekend!!!
SCDTRD
The Beast:
The Mods:
Old 09-06-2003, 08:57 PM
Eddie's Avatar
2000 Toyota Tundra,
Here's some resistance values I found in the assembly manuals. I haven't had the chance to do an actual resistance to scantool temp readings test yet.
Intake Air Temp sensor:
-20 C (-4 F) = 12.5 - 16.9 Kohms
20 C (68 F) = 2.19 - 2.67 Kohms
60 C (140 F) = .5 - .68 Kohms
Coolant Temp sensor:
-20 C = 10 - 20 Kohms
0 C (32 F) = 4 - 7 Kohms
20 C = 2 - 3 Kohms
40 C (104 F) = .9 - 1.3 Kohms
60 C = .4 - .7 Kohms
80 C (176 F) = .2 - .4 Kohms
Old 09-07-2003, 07:15 AM
03TundraTRD's Avatar
03TundraTRD's Photo Albums
Last Online: 03-15-2007 07:11 PM
03TundraTRD is on a distinguished road.
scdtrd
Can you tell me where I can get one of those resistors and where/how would I install it on my 03 Tundra V6 this would help my perfprmance a whloe lot since Guam is like 85 to 90 degrees all year long
MODS: SpinTech Pro Street Muffler, Panisonic MP3 player, BellTech 1'' Drop Shackle.
Old 09-07-2003, 08:31 PM
Eddie's Avatar
2000 Toyota Tundra,
Originally posted by 03TundraTRD
scdtrd
An electronics supply store like Radio Shack sells resistors. They have to be at least 1/2 watt resistors,1/4 watt ones will probably burn out.
You need to find the positive wire of the sensor circuit and connect the resistor in series.
