Re: Quick Exhaust Tip Question
I used a similar combination on my 00 Tundra. I used a magnaflow weld-on tip. It looks much cleaner than the screw-on or clamp on versions. I had the guy who was supposed to be welding my muffler on, weld it on. If you weld on a tip, be sure your welder covers the most of the tip with a wet rag to avoid weld splash and it helps to insulate the chrome from blueing. He actually used stainless steel band clamps on the muffler instead of welding, I was impressed, this guy did good work!
Good luck on your install, let us know how it went.
