mileage change with a leveling kit and 33s
+ Reply to Thread
Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By Timmi
Thread: mileage change with a leveling kit and 33s
  1. #1
    Rookie kayer32 is on a distinguished road.
    Join Date
    Dec 2011
    Location
    Warner Robins
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Default mileage change with a leveling kit and 33s
    Hey guys I have an 08 Tundra Crew Max and I'm thinking of doing the toytec leveling kit along with 22in wheels and 33in tires. I often make 3 hour trips so the gas mileage is kind of a big deal. So what changes should I expect to see around town and on the highway. Any info is appreciated. Thanks in advance.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    H. M. Murdock Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard wants you off his porch. Highwaylizard's Avatar
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    6,378
    Liked
    1300 times
    Blog Entries
    78
    Images
    65
    Rep Power
    176297
    Default Re: mileage change with a leveling kit and 33s
    Quote Originally Posted by kayer32 View Post
    Good question and welcome to the forum.
    By leveling I am assuming you are going to raise the front end? My understanding of this is that it will increase your frontal area thereby creating more drag. How much of an increase over the stock size tires are the 33's? Here is a calculator, courtesy of the good folks at Discount Tire, Tire Size Calculator - Discount Tire Direct This will help you to determine how the different size tires will affect your mileage on the highway. Larger tires will kill your in-town mileage but help highway mileage. The advantage of larger tires on the highway may be offset by the increased drag from the larger frontal area from the leveling kit.
    Tundra Fuel Economy Blog
    241,233 miles on the odometer [come see me when you get that on your ford]
    Highwaylizard 2004 Tundra Double Cab Limited Edition 4.7 liter V8, four speed automatic, four wheel drive, testing platform for fuel economy, self designed cold air intake using ram air principle, Scangauge, Fitch Fuel Catalyst, Aero Turbine, "Foolie Exhaust" from Aero Turbine back, True Flow Intake with Amsoil drop-in dry filter, Mobile 1 in the engine, NAPA oil filter, NAPA in the differentials. 3:91 gears in the front (Thanks Cajuntundra!) and rear (Thanks Nytrousboy!) differentials, Michelin LTX M/S2 tires
  4. #3
    Join Date
    Dec 2011
    Location
    Warner Robins
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Thanks Highaylizard I'll take that into consideration. You actually made me think of another question. If I lift the back equally this would keep the lines of the truck and should keep the resistance the same right or am I way off on this?
  5. #4
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    6,378
    Liked
    1300 times
    Blog Entries
    78
    Images
    65
    Rep Power
    176297
    Actually no. Lifting the front and rear will still increase the frontal profile and increase your drag. Sorry to rain on your parade. One way to look at this is to draw the truck's silhouette from the front starting from the ground up. The higher up your truck sits the larger the frontal profile and the more drag.
  6. #5
    Supporter Timmi has earned a masters in rep power. Timmi has earned a masters in rep power. Timmi has earned a masters in rep power. Timmi has earned a masters in rep power. Timmi has earned a masters in rep power. Timmi has earned a masters in rep power. Timmi has earned a masters in rep power. Timmi has earned a masters in rep power. Timmi has earned a masters in rep power. Timmi has earned a masters in rep power. Timmi has earned a masters in rep power. Timmi's Avatar
    Join Date
    Jun 2011
    Location
    Christiansburg, Virginia
    Posts
    386
    Liked
    13 times
    Rep Power
    18287
    I have the Bilstein 5100 lift and 275/70/18 tires, which are about 33.5" tall mounted on the truck. My hiway mpg dropped about 1.5 mpg due to the tire being wider and heavier.
    Highwaylizard likes this.
    2009 Tundra Double Cab Grade Salsa Red
    Wild Country Radial XTX Sport
    Ballistic Hostel Black
    Bilstein 5100
    Flowmaster dual 40
    Volant
  7. #6
    Join Date
    Sep 2008
    Location
    above the below
    Posts
    6,378
    Liked
    1300 times
    Blog Entries
    78
    Images
    65
    Rep Power
    176297
    Quote Originally Posted by Timmi View Post
    Is this with taking into account the change in tire diameter as well?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
