Re: Bec 105 compatible with e7007?
From what I read the 7007 & 7009 have a R10 pin plug at the rear , which will require you to change the connector and pins.
Here is a tread on the 7009
E7007/8 Sienna NAV into 2006 Tundra
THAT'S THE HILLBILLY WAY
2006 Limited 4x4 ,Debadged.Westin side bars,Hellwig Sway bar, Lund Deflector ,Snug-Top Expo shell .Magnaflow 14" muffler with resonator removed.
" If I knew I was going to live this long I would have taken better care of myself " "Marriage changes passion...suddenly you're in bed with a relative."
