Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > GPS and Navigation Assistance
Free Shipping at Buy.com!
FREE Personal Trainer Program
GPS and Navigation Assistance OEM Car, Aftermarket and handheld navigation discussions.
This is a discussion thread titled "Eclipse Navi Unit 5435.", within the GPS and Navigation Assistance forum, part of the Technical & Vehicle Assistance Forums category.
Old 01-17-2008, 02:25 PM
Dealer : Woodbine Toyota
2007 Lexus IS350
nemesisaudio's Photo Albums
Last Online: 02-22-2008 12:25 PM
nemesisaudio is on a distinguished road.
Default Eclipse Navi Unit 5435.
Hey there. I just installed the Eclipse AVN 5435 Navi unit in my car. The unit does operate properly but there seems to be an issue with the navi menu. Once i insert the cd I am not able to input an address and check the maps and routes. The option comes up as a Grey icon on the screen and will not allow me to enter anything. I just hooked up the wires that powered on the unit and gave me sound. I do not have an updated disc of any sort, just the one that came with the unit. Since i did not have a manual when i did the install i was just wondering if I left anything out. Can anybody advise me on what may be the problem and how i might be able to fix it.
Much thanks!!!!
Old 01-17-2008, 03:02 PM
czechm8's Avatar
Dealer : Jay Wolfe Toytota
2005 Toyota Sequoia,
- Other - Acura TL
czechm8's Photo Albums
Last Online: Today 08:55 AM
czechm8 is on a distinguished road.
Default Re: Eclipse Navi Unit 5435.
Yes. There is a wire that needs to be hooked to the parking brake. The NAV functions are not available until you depress the parking brake.
You can simply ground this wire to the vehicle chassis to fix the problem.
There are two other wires that need to be connected.
1) Reverse sensor wire
2) Speed/Pulse wire
Of course, you will need to attach the GPS antenna and mount it as well.
05 Sequoia 4x4 Ltd. Phantom Grey Pearl, Weld 20" wheels on Toyo tires, MagnaFlow cat-back, TRD air filter, Amsoil fluids, custom 15" overhead DVD system, Eclipse NAV system w/camera, Sirius tuner, DLS Nobelium components and coaxials, TRU 2-channel amp, 13" eD sub, eD Nine.1 amp, iPod hookup. SilverStar lamps.
Old 01-17-2008, 09:37 PM
2007 Lexus IS350
thanks a lot for that advice. I have grounded the parking break already. And i had already attached the antenna for the navi unit to pick up the signal. The navi was working perfectly, it picked up the streets i was driving around once the install was complete. I was just not able to enter an address in the navi menu. I am just unclear as to why the speed/pulse wire needs to be connected and why the reverse sensor wire needs to be connected? Also do you know the colors to those two wires you are referring to? And to where they need to be connected.
Thanks much!!!
Old 01-18-2008, 12:49 AM
core64's Avatar
Dealer : Norwalk Toyota
2005 Toyota Tundra Limited 4x4,
2008 Toyota Sienna Limited AWD
core64's Photo Albums
Last Online: Yesterday 11:19 PM
core64 is on a distinguished road.
Just a thought, but make sure you are in the right region. The map screen will work, but wont let you input destinations if you are in the wrong region. Its that little map (of the US and Canada divided into numbered regions)on the left side of the destination screen. You must set it for the region you are in. I think default region is #1 east coast.
Old 01-18-2008, 12:54 AM
core64's Avatar
Sorry, its not region but search area. Default is search area US1 (Pacific northwest- Oregon, Washington. And its not it destination screen, its in the memory point screen. Looked in owners manual to me sure. I have the 6610, but should be similar to your 5435.
Old 01-18-2008, 07:34 AM
czechm8's Avatar
- Other - Acura TL
Thanks much!!!
The main function of the reverse wire is to activate a backup camera when you put the vehicle in reverse. I don't know if it has any other functions.
If you have software version 1.2 or lower, you have to have the speed/pulse wire hooked up. The NAV unit guides by GPS and the speed signal from the vehicle.
That could very well be why some of your NAV functions don't work
There was firmware released in version 1.4 and newer map discs that did away with the speed/pulse wire requirement and allows the NAV to do turn-by-turn directions using GPS only. I think this was done because some vehicles don't have speed/pulse wires and the voltages varied greatly between manufacturers.
If you are interested in a newer map disc, send me a PM and I can hook you up.
Old 01-18-2008, 07:45 AM
LGL002's Avatar
Dealer : Rudy Luther's Toyota
2003 Toyota Camry SE ,V6, Nav,
- Other - 1969 Ford Torino GT,
2004 Toyota Tundra Limited A/C 4X4
LGL002's Photo Albums
Last Online: Yesterday 08:57 PM
LGL002 is on a distinguished road.
According to my AVN5510 manual one of the reasons for hooking up the reverse wire signal is to reset/correct trip mileage and time to your set destination.
Larry
2004 Tundra V8 Limited Access Cab 4X4 , Auto Dim Comp/Temp Mirror, Aero Turbine #2525 muffler, Access Roll Up Cover, Optima D31A battery, Multi-Vex adaptive outside mirrors, Eclipse AVN5510 Nav unit and Sirius SIR-ECL1 tuner as of 10/07 pictures in my photo gallery
2003 Camry SE V6 Navigation, Sirius, Lunar Mist
Optima 34R battery
If a combo of all these whizz bangs met their claims you'd have to syphon gas out of your tank every second day and sell the excess horsepower on the third????
Old 02-20-2008, 05:30 AM
JRE56's Avatar
Dealer : Jim Lynch Toyota
1997 Toyota Camry
JRE56's Photo Albums
Last Online: Today 05:01 AM
JRE56 is on a distinguished road.
Hello everyone ! I'm new I'm mainly interested in the 5435 and found more info tonight on the unit than a year on another site. I purchased one thru the net and was wondering what color are the buttons on the sides,with the upgrade can you play a MP3 with a higher bit rate than 128 and when you type in,lets say burger on the nav.,will it show all the POI's of burger joints in area.
Thanks !
