Custom Search
Welcome to the Tundra Solutions Forum forums.
Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > GPS and Navigation Assistance
The Tire Rack- Revolutionizing Tire Buying
Click here for the Best Buy Homepage
Cake Batter Muscle Milk, Exclusive Flavor
Bad Credit? No Credit? No Problem!
GPS and Navigation Assistance OEM Car, Aftermarket and handheld navigation discussions.
This is a discussion thread titled "installing a factory dvd/navigation system on an '07 tundra", within the GPS and Navigation Assistance forum, part of the Technical & Vehicle Assistance Forums category.
Old 02-08-2008, 12:23 PM
jamesryanb's Photo Gallery
Last Online: Yesterday 08:26 PM
jamesryanb is on a distinguished road.
Default installing a factory dvd/navigation system on an '07 tundra
I have an 07' tundra dc xsp. It has the factory single disc cd player. Is it possible to install the factory dvd navigation system in it places?
Old 02-08-2008, 01:08 PM
DanielAcosta's Avatar
Dealer : Earnhardt Toyota
DanielAcosta's Photo Gallery
Last Online: Today 04:05 AM
DanielAcosta is on a distinguished road.
Default Re: installing a factory dvd/navigation system on an '07 tundra
I heard of someone plugging the nav in place of the JBL. Not sure if the plugs would match with yours though.
07 DC SR5 TRD 4x4 5.7
Truxedo Lo-Pro with deck rails.
Front Susp: Stock coilovers, shocks, 4" lift (http://www.tundrasolutions.com/forum...6-4-inch-lift/), wheel well height 41.5."
Rear Susp: ProComp ES3000 #326510 (2.25" taller than stock), 1.25" blocks plus PRG mini-pack (http://www.tundrasolutions.com/forum...and-new-truck/) gives 2.25" total lift, parking brake cable bracket spacers, wheel well height 43."
Front diff and rear ds drop; trailer hitch electrical harness tucked up above bumper.
After 20K miles swapped 305/65/18 BFG AT for 285/75/18 Toyo AT, still on stock 18x8x60 offset TRD wheels, about 1/8" clearance to sway bar. Like the extra height but miss the width. Next time either 305/70/18 or 35x12.50/18.
Added 5th 285/75/18 Toyo AT as spare. Foam pad above spare to help with bed bounce.
TRD exhaust, 26K miles, 17mpg city after battery disconnect reset. Note: after 7K miles of data, I think the improved mileage is more from a gentler right foot than anything else.
Bed Bounce: Stiffer E-tires are worse than stock P-metric; biggest improvement from PRG mini-pack, slight improvement from shocks and foam pad above spare. Still a stiff ride but tolerable now.
Best things about this truck: 5.7 and transmission, interior size and comfort, very quiet at high speed.
Worst things about this truck: bed bounce, no VSC in 4wd, mileage sucks above 70.
Old 02-08-2008, 09:30 PM
Dealer : Le Mieux & Son Toyota
2007 Toyota Tundra 5.7 Crewmax Limited
gbbuilders's Photo Gallery
Last Online: 07-02-2008 10:52 PM
gbbuilders is on a distinguished road.
I installed the factory nav in place of my JBL system on my '07 Crewmax. It is possible to install the nav system on your truck, but if you don't have the factory JBL system then you will need to purchase an amplifier. Otherwise, you will just need about a couple of wiring harnesses. If you don't have a nav system located yet or need parts to install one, PM me. I did alot of research to find out what it would take to install the nav along with the rear backup camera so I can save you some time. Also, most of the parts you will need will come from Canada. I have a Canadian contact for parts or entire Nav system install kits (Everything you need including the nav system). If you would like to contact him I will simply send him an e-mail just to make sure its alright to give out his contact info. Any questions just ask.
Greg
Old 02-10-2008, 07:13 PM
Thanks everyone for the advice. I do not have the JBL so not sure how mine would work. I hope just a harness and amp? Anyone have an idea about how much that whole set up would cost to do?
Thanks again!
Old 04-23-2008, 11:10 AM
Dealer : Joe Myers Toyota
marine9704's Photo Gallery
Last Online: 04-23-2008 11:10 AM
marine9704 is on a distinguished road.
I've spent almost 6 months tracking a lot of info and this is what I've come up with for the non JBL system. You need the head unit and the amp including all the pig tails that go with both. Make sure that the pig tails are long as I have purchased a navigation from a third party and could not for the life of me figure out the connections. So I ventured into a junk yard where BEHOLD there is my beloved 08 Tundra Crewmax Limited totalled. I got a good hand from one of the workers and removed the wiring I needed. I took it to a local stereo shop and he sent the radio to be tested and re-wired and it should go into my truck today. I think the install cost will be a little expensive aroung $200.00 dollars because they will basically be putting in a new system but if they charge me even $1,000 dollars its still a third of what the system will cost from canada. I'll let you know how it works out for me when I get it installed. I know everyone says it can't be done but when your a Marine you know that even the impossible is possible. Remember:You must keep sending work out; You must never let a manuscript do nothing. but eat its head offin a drawer. You send that work out again and again, while your working on anotherone. If you have talent, you will receive somemeasure of success-but only if you persist. Isaac Asimov
Old 04-23-2008, 05:07 PM
thanks for the reply. I have been searching ebay and junk yards because i did not want to the pay the price that it would cost to get it from canada. when you get yours in and running let me know how it went.
Bookmarks
TundraSolutions.com and the TundraSolutions.com logo are among the registered trademarks of Tundra Solutions, Inc.
Questions? Please use the Contact Us link or call (559) 323-5444. Other websites: DealerHunter JPV Photography
