Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > GPS and Navigation Assistance
Old 02-10-2008, 02:24 AM
Dealer : Acton Toyota of Littleton
2006 Toyota 4Runner
Last Online: 10-19-2009 11:19 AM
cheepyankee is on a distinguished road.
cheepyankee's Photo Albums
Default Need help with e7006 install, and hooking up digital amp.
I installed a 7006 in my 2007 sequoia, and added a back up camera. It was so mind numbingly easy, I quickly ordered another 7006 for my 2004 Sequoia. Both vehicles are virtually identical, right down to the JBL systems.
Or so I thought. Plug in the 7006, and radio stations are cranked to full volume! Wake the neighbors! Even when off, you get a constant "BZZZZZZT".
As you know, 05 and newer have a digital signal and a bigass amp under where the floor shift use to be, and the amp has a part # like 86280-0c050. 2004 and older, analog, with 2 smaller amps (one under radio, and one at rear of console, presumably for the RSE). The part numbers are 86280-AF013 (front) and 86280-AF022 (Rear). I'm guessing the "A" is for analog. Whatever.
Poking around the net, I figure I need a digtal amp. Fine I get one from a Tundra, 86280-0c040. It is visually identical to the one in my 2007 Sequoia, and had same wire harness fittings. Of course, the wire harness fittings in the 2007 are markedly different.
HELP! Is there an adapter harness of some kind I can buy?
Old 10-08-2009, 08:22 PM
Last Online: 10-08-2009 08:23 PM
flyin j is on a distinguished road.
flyin j's Photo Albums
Default Re: Need help with e7006 install, and hooking up digital amp.
Hey I can't help you with the harness but I am in a similar boat. I was told that there
was something wrong with my radio. when I turn it on all of the audio functions
read 0's and I have no sound. I now have two 16848 JBL audio CD Cassette players that both say this when they are on. I have done the speaker test and they all work fine. my last resort is to find the amp that I believe is blown. it so happens that it is a 86280-0C040. If you need to get rid of it and try something else let me know I might be able to take it off of your hands.
Old 10-09-2009, 01:10 PM
tinik's Avatar
Travel & camping is 2 much fun
Dealer : Cramer Toyota Scion of Venice
2006 Toyota Sequoia,
2001 Toyota Tundra Supercharged
Images: 51
tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One. tinik is the One.
tinik's Photo Albums
There no wire harness for sale as far as I know. I ended up building my own wire harness for my tundra. And I have E7009 nav unit
2006 Toyota Sequoia Limited 4x4 w/ lxr package, 7008 navi, rear entartaiment system, 20" x-sp enkei.
2001 Toyota Tundra SR5 4x4 - TRD 9+Psi Supercharged, JBA Ceramic Headers, Walboro 255LPH Fuel Pump, 1UZ Rods, 20" x-sp enkei wheels, 7009 navi w/custom JBL wire harness + OEM XM/Sirus radio, drive by wire, and many other mods.
