Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > GPS and Navigation Assistance
GPS and Navigation Assistance OEM Car, Aftermarket and handheld navigation discussions.
This is a discussion thread titled "Need some help on my AVN5435....", within the GPS and Navigation Assistance forum, part of the Technical & Vehicle Assistance Forums category.
Old 06-17-2008, 09:03 AM
Dealer : Mississauga Toyota
2000 Lexus GS400
Last Online: Yesterday 02:03 AM
just1time is on a distinguished road.
just1time's Photo Albums
Default Need some help on my AVN5435....
so i hooked up everything correctly including the speed sensor wire but am still getting the message, "check speed pulse" on the screen. Am sure the wire to the vehicle speed sensor is connected properly.
Why is it still showing this message?
Also, i checked the system check up screen and when the car is moving, the speed pulse does show the speed accurately for the most part. Isn't this an indication that the speed wire is connected? If the speed wire is not connected, would the speed in the system check not show zero since it wouldn't know car is not moving?
But the info under it, i think it is the speed pulse or so still shows "studying". isn't it supposed to show "completed" by now?
Also, i don't turn by turn when am driving. the system just starts the guidance and says nothing until i get to the end and it says your destination is reached or so.
I have the disc version 1.2 if that helps.
please advise.
i had the avn5495(hard drive) in the past and used the same speed sensor connection as am using now and all was fine.
please advice
Thanks
Just1time
Old 06-17-2008, 09:49 AM
czechm8's Avatar
Dealer : Jay Wolfe Toytota
2005 Toyota Sequoia,
- Other - Acura TL
Last Online: Yesterday 11:29 PM
czechm8 is on a distinguished road.
czechm8's Photo Albums
Default Re: Need some help on my AVN5435....
It could still be a speed/pulse issue if the voltage on that connection is low. Or, it really is still studying. Are you getting a full GPS signal?
Disc version 1.4 and higher uses GPS only for turn-by-turn and the speed/pulse is not needed. The newer version disc may solve your problem.
05 Sequoia 4x4 Ltd. Phantom Grey Pearl, Weld 20" wheels on Toyo tires, MagnaFlow cat-back, Amsoil fluids, custom 15" overhead DVD system, Eclipse NAV system w/camera, Sirius tuner. DLS Nobelium components and coaxials, TRU B-2110 and H-1 amps, 13" eD sub, iPod hookup. SilverStar lamps.
Old 06-17-2008, 09:56 AM
2000 Lexus GS400
thanks,
i just confirmed that i hooked the speed sensor wire to the wrong wire.
on my car it is in a set of two rows of wire where the top wires are identical to the bottom. i will rehook it and give an update. But am anxiously awating the update disc from u to see if there is any improvement in the update.
besides the bypass on the speed sensor requirement, what is the major noticeable difference from the 1.2 to the 1.4 and then to the current one?
thanks
just1time
Old 06-17-2008, 10:43 AM
czechm8's Avatar
- Other - Acura TL
Version 1.4 has the firmware upgrade. Versions 2.1 and 2.2 are basically just map and POI upgrades.
The details of the firmware changes were discussed in this thread:
http://www.tundrasolutions.com/forum...0d-dvd-update/
Old 06-17-2008, 07:45 PM
2000 Lexus GS400
hooked on the wire to the correct wire and all is good now.
one thing though, am not sure but the nav voice seems to be coming from the rear speaker. isn't it supposed to come from the driver side front speaker?
going to make sure tomorrow, maybe its just my ears.
just1time
Old 08-19-2008, 03:45 AM
JRE56's Avatar
Dealer : Jim Lynch Toyota
1997 Toyota Camry
Last Online: Today 12:25 AM
JRE56 is on a distinguished road.
JRE56's Photo Albums
Yep, It should come from the front driver side.I have the 5435 Eclipse as well.Double check your L/R balance and fade controls.You probably have your wires hooked up incorrectly.
Bookmarks
