Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > GPS and Navigation Assistance
Old 12-05-2008, 06:56 PM
Last Online: 08-26-2009 05:54 PM
jamesryanb is on a distinguished road.
jamesryanb's Photo Albums
Default OEM Nav System check mode?
I installed the factory nav on my 07 tundra about a week ago. After I got done with the install the directions have you go into the system check mode to do an operation check. The first time I went in and did it everything checked fine. Since then I added the steering wheel controls. Today I got bored and just went back to to the system check mode and got a message. When you first go into the screen is comes up with AVN and then below that it say DSP-AMP. The DSP-AMP says ok next to it but the AVN says CHEK. So when I press CHEK it goes to the Unit Check Mode AVN and says Memory 58-42 occured 08/12/05 22:58:20.
Soooo........... does anyone know what this means.
Everything is working fine with the navigaiton system, radio, directions, cd, aux. I just want to know if this is something I want to worry about or is it ok?
To access this screen the directions told me to push and hold the info button while turning the llights on and off 3 times
Sorry so long but thanks for any help you all may have.
James
Old 12-05-2008, 09:24 PM
Default Re: OEM Nav System check mode?
Never mind, found out what was wrong. I put a cd into the map dvd sections by mistake. I guess when it could not read the cd it created that message. It cleared now and everything looks good.
Old 12-06-2008, 07:25 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
You already answered yourself, but here is what that code means.
58-42
When one of following conditions is met:
Player error
Scratches or dirt on disc
Access to invalid address due to software error = WRONG DISK.
Glad it was an easy fix
25 yrs with TOYOTA
