OEM Nav Unit Losing Satellite Communication...What's going on?
Alright...I am starting to lean towards believing that Toyota nav units are absolute pieces of crap! I just bought a 2008 Crewmax Limited with nav. I've noticed on NUMEROUS occasions already that the "GPS" logo in the top left corner disappears and the little arrow has me either on another street or driving through a pasture somewhere!!!
Ironically, the same thing has happened with my wife's 2006 Sequoia Limited NUMEROUS times. They replaced her nav unit under warranty, swapped nav discs with the latest version, checked everything in the world on three different visits and could find nothing wrong. Hers does EXACTLY the same thing and my '08 Tundra!!!
Two different vehicles...two different years...two different style nav units...both losing the "GPS" signal. It is obvious that the nav unit is not talking with the satellites when "GPS" disappears because this is when you show up on the wrong road, driving through a pasture, etc.
What's the deal guys? Has anyone else experienced this? We paid a lot of money for these units for them to be acting up like they are and her Sequoia is now out of warranty. The weird thing is that it comes and goes. Sometimes no "GPS", turn the trucks off and then back on, and there it is. Other times, it won't come back until you've been driving for 10 minutes.
I should note...the only common denominator is that we both have Vais Technology "boxes" for satellite radio integration into the factory nav unit but I see no way this being the root of the problem. It is completely independent and a completely independent harness.
What is causing them to lose communication with the satellites? Please help! Thanks!
Matt
__________________ 2008 Tundra Crewmax Limited 4x4 5.7L V8 Slate Metallic
OEM Navigation w/ Backup Camera, Sirius, Escort 8500 X50 Radar Detector, TRD Sway Bar, Woodgrain Interior, Toyota All Weather Mats, Chrome Exhaust Tip, WeatherTech Side Deflectors and Sunroof Wind Deflector, Full LED Conversion, Line-X Bed Liner, TRD Badges, Toyota Door Sill Protectors, Tinted Windows
Re: OEM Nav Unit Losing Satellite Communication...What's going on?
Mine does the same thing.. I'll be driving down I95 and all of a sudden you'll see my little arrow going through the Chesapeake Bay.. It's almost comical now to me. I have the 10k service coming up and a nice long list of $hit that is out of whack. They'll probably have it a week trying to get it all fixed, ordered and replaced. I'm not picking it up until all of it is done.
Well...good luck with the GPS situation. It was never resolved under my wife's warranty and now my brand new Tundra is doing it. What is up with the Toyota nav units?!?!?!?!?
Matt
Please let me know what you come up with so I can pass it on to my dealer. Thanks!!!
Matt
Hi, it sounds like a intermitting problem with the antenna maybe a pinch antenna cable or a loose connection, have them check the radio for the antenna connection maybe not locked into place, also have them check connection at atenna or have them replace it. If they are unable to correct the problem call Toyota get a ticket going on this, that is alot of money for something not work. Good luck
Larry
2004 Tundra AC Limited
Added to date Bilstein 6024, 6025, FMS Sports Grille. De-Badged, Kenwood KSC-SW1 Subwoofer in storage compartment rear passenger side, Infinity 6012i & 6012si 6”sub in doors, Kenwood DNX 7100 w/XM, Turboliner bedliner, J & J Chrome Running Boards, chromed factory rims, K&N cold air intake, Window tinting. Viper Alarm and Viper GPS systems, Personal Identity security system,SilverStar 9003st headlight, 05 tail light, clear corner lens with 3157ast Silverstar, DynoMax exhaust,Muth Signal Mirrors, SnugTop Snuglid SL hard tonneau.
I recently did a self-install of the factory XM unit about 2-3 weeks ago. Installation went perfectly. Pre-installation, I never had any issues from my nav system. Post-installation, I have now had 2 instances where this has happened. I've run the calibration utility twice now and it seems to stick for a little bit. Then, spontaneously, the nav system loses itself (as I like to say). I'm wondering if this isn't a loose connection (such as the antenna cable) on the back of the unit. I'm planning on pulling the dash appart again and double checking my connections this weekend. Hopefully that's all that's wrong. If not, I'll have to check with the dealership to see what's going on.
I just can't buy it being an antenna connection issue on two different vehicles...particularly my Tundra which has had the stock head unit removed only once.
Since her Sequoia repairs were begun under warranty and the problem not resolved (warranty now expired), will Toyota honor this and continue working it until the repairs are completed?
I don't know why you guys complaining so much about Satellite loss, if you want better reception, you can always do what aftermarked units have, install GPS antena on a roof, and signal will get much better.
Aftermaket antena cost around $25-$40 - easy fix.
I have very little issues with my unit, and I have GEN5 Nav unit, just like most of you guys here.
2006 Toyota Sequoia Limited 4x4 w/ lxr package, 7008 navi, rear entartaiment system, 20" x-sp enkei.
2001 Toyota Tundra SR5 4x4 - TRD 9+Psi Supercharged, JBA Ceramic Headers, Walboro 255LPH Fuel Pump, 1UZ Rods, 20" x-sp enkei wheels, 7009 navi w/custom JBL wire harness + OEM XM/Sirus radio, drive by wire, and many other mods.
Do you have an aftermarket antenna? What kind did you use and where did you pick it up? How does it connect to the factory head unit?
Matt
