Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > GPS and Navigation Assistance
  #31 (permalink)
Old 06-03-2009, 04:21 PM
Dealer : North Point Toyota Scion
Last Online: 07-20-2009 02:24 PM
thump4863 is on a distinguished road.
Send a message via AIM to thump4863 thump4863's Photo Albums My eBay
Default Re: Eclipse AVN726E
Bypass? Like to operate navi while moving? On all my other eclipses I just grounded out the parking brake wire.
  #32 (permalink)
Old 06-03-2009, 04:56 PM
woohah's Avatar
Dealer : Mckinnon Toyota
2008 Toyota Tundra SR5 Red
Last Online: 07-08-2009 08:16 PM
woohah is on a distinguished road.
woohah's Photo Albums
Correct. Im wondering if that will work the same on this model. Any ideas?
  #33 (permalink)
Old 06-03-2009, 08:47 PM
Dealer : Dixie Toyota
- Other -
Last Online: 07-09-2009 11:05 PM
qualquiera is on a distinguished road.
qualquiera's Photo Albums
The bypass works the same. I use a SPDT switch in one position is connects to ground and in the other position it connects the the actual parking break for normal functionality.
  #34 (permalink)
Old 06-04-2009, 09:37 AM
Got mine on the way - can those of you that have them take a pic of where you mounted your bluetooth mic?
  #35 (permalink)
Old 06-04-2009, 05:27 PM
Imdone's Avatar
2004 Toyota 4Runner,
Last Online: 10-31-2009 02:18 PM
Images: 23
Imdone is a splendid one to behold. Imdone is a splendid one to behold.
Imdone's Photo Albums My eBay
I put mine on the visor and ran the wire down the A-pillar to behind the guage cluster and over to the head unit.
RBP, ICON, CAMBURG, ALCAN, AMP RESEARCH, TOYO, ECLIPSE, SAVV, FOSGATE, KICKER, JL AUDIO, V-LEDS, PIAA, HELLA, MBRP, UNICHIP, TIMBREN, HYPERTECH
  #36 (permalink)
Old 06-04-2009, 08:05 PM
Looks awesome - thanks
  #37 (permalink)
Old 06-04-2009, 08:29 PM
bstaley's Avatar
Dealer : Valley Toyota
2006 Toyota Tundra SR5 4x4 DC,
2008 Toyota Highlander HV Limited
bstaley is on a distinguished road.
bstaley's Photo Albums
Don't have a pic, but I put mine on top of the steering column against the dash. I had a little clip that hooks back under the dash and holds it in place.
  #38 (permalink)
Old 06-04-2009, 09:05 PM
funkytechmonkey's Avatar
2008 Toyota Tundra CrewMax Limited 4x4
Last Online: 11-10-2009 10:32 PM
Images: 10
funkytechmonkey is on a distinguished road.
funkytechmonkey's Photo Albums
about the video.... if you can get one I would like to see it boot up (time it takes to boot up), what the home screen looks like and how it looks when you change from one feature to the next and the amout of time it takes to go from....say, from the ipod controls to radio.
Also, Have you tried hooking up an iphone 3g to it yet? Any friends have one that you can test on it?
  #39 (permalink)
Old 06-04-2009, 10:24 PM
I have an Iphone 3G so when mine gets here Monday I'll test it. I know right now you can't audio stream via bluetooth but with the new 3.0 software in June they are adding it. I saw a youtube video of a guy with the beta version syncing it to a Venza. So once that is out it should work perfect.
  #40 (permalink)
Old 06-05-2009, 07:18 PM
Imdone's Avatar
Images: 23
I'm retarded and don't know how to upload videos here.
The start up screen is whatever screen you left off. If you were watching a movie, that's what comes up, if you were on the AV screen for radio that comes up. If you were on the NAVI screen then you get the normal blub about safety.
Navigation time between functions is instant. There is no delay. When you press the button it does it. Whether you use the steering wheel or the remote or the H/U itself.
  #41 (permalink)
Old 06-08-2009, 08:01 AM
woohah's Avatar
Got my AVN726E installed this past weekend. Took around 6 1/2 hours to get everything JUST right. I have a switch right next to the AUX port that I made to fit perfectly in the little black spaces Toyota leaves. This allows me to shut off the video if I see a cop. The only visible wire is the Mic. I ran it from my visor to the A frame and into the dash. This radio is WELL worth the money. I have been doing a TON of tests with the system and below is what I have found. Both good and bad.
Good
1.) Bluetooth Phone: Works perfectly! Great sound quality and the people on the other end say that the sound is perfect. No road noise whatsoever.
2.) Video: Crisp and clean. Just what you would expect from the amount of $$ you put into it. Tested with DVD/DIVX and it played EVERY movie without any problems.
3.) Sound: Once I found the loud setting, it made a world of difference. That and the preset EQ settings. Crisp and clean!
4.) Navigation: Spot on. Loads better than my old Avic-N2. The system was able to get me to a remote location with ease. Still needs updated maps which I haven't found. Doesn't show my street I live on, eventhough my neighborhood is around 7-8 years old and maps appear to be 2008.
5.) Ipod: Awesome if you have the kit. If you are looking to purchase this radio, GET THE KIT! The ipod kit comes with the cable for A/V and it connects via USB, so it will charge your ipod while it is hooked up. You can control everything from the screen unit, so this allows you to hide your ipod.
6.) Sirius Radio: Sounds great and the menu system for this is nice. Easy to get around and is much nicer having the controls within the radio than having an external FM transmitter. (If you are wanting the Sirius/XM Traffic, that unit is more expensive and is different than the standard radio tuner)
Bad
1.) No Manual!!!! WTF?!?! It would be nice to have the manual to this inside the box. I shouldn't have to print it out.
2.) Video Settings: There is no way, that I have found, to adjust the video brightness. I would think there is a setting for this, but with no manual, how am I suppose to know? None of the menus have shown an option to adjust this for Videos. Calling Eclipse today on this as well. Will update.
3.) Maps need to be updated. Calling Eclipse on how this is suppose to be done. I will update when I find out.
4.) No remote. Would have been a nice feature to have. I went to eclipse website and that wasn't even an option. Anyone have an alternative other than a new steering wheel?
Overall
Well worth the money. Still has some bugs to work out, but with some firmware updates, this unit will be SOLID! I expect there to be some minor issues with any radio. I am just glad the ones that I listed are just minor annoyances and preference issues, rather than show stoppers. If you are in the market of buying an AVN726E, it is worth it.
  #42 (permalink)
Old 06-08-2009, 03:46 PM
Good
Bad
Overall
Nice - mine was delivered this morning can't wait to get home and put it in.
08 Super White Tundra DC 5.7L SR5 with the SAP
20" Incubus Poltergeists, Powerstick dual exhaust system, AFE Stage 2 Si CAI, Eclipse AVN726E w/ backup camera, JL Audio XR 650 components, RE Audio SL 12s in a Tech12Volt box, JL Audio 300/4 & 500/1 amps, 20% Tint, Billet Grill
  #43 (permalink)
Old 06-08-2009, 10:33 PM
Imdone's Avatar
Images: 23
Good
Bad
Overall
Here's the Manual. Once you see how many pages it is you will see why they didn't print it.
http://www.eclipse-web.com/us/downlo...df/726ae99.pdf
The RMC105 remote works with this system. It is on their site under "Accessories" but it doesn't have it's own page. I would guess that there is going to be a new remote that is released eventually. Their other remote RRC106 only works with the AVN6620.
The map updates will be downloadable to an SD Card or you will purchase it from eclipse on an SD card. If you open the screen you can see the SD card slot. They don't have this available yet.
The brightness can be adjusted. It's in the manual but I don't remember it off hand.
I downloaded the manual and saved it to my external hard drive so I can access it faster than downloading it when I need it.
  #44 (permalink)
Old 06-09-2009, 09:41 AM
Got mine installed last night. Things I didn't like is that it wasn't plug in play like my old one. Luckily when I bought the first one for my tacoma I had bought a wiring hareness. And luckily again that harness fit my tundra.
I'm having issue with the GPS losing signal. I mounted it in the center speaker location. I also can't seem to get it to push my subs. It sounds like they aren't even really on.
For the guy asking about bluetooth with the iphone it works great. You only have to pair it once. I got back in the truck this morning and it was already paired up.
Overall its nice just have some more tinkering to do with it.
  #45 (permalink)
Old 06-09-2009, 09:48 AM
woohah's Avatar
I mounted my GPS just above the A-frame on the roof of the vehicle and then ran it down the A-Frame and then under the hood. I drilled a hole behind the engine into the cab and then up to the radio. I sealed off the hole once I ran the wire to avoid any possible water damage. I get perfect GPS. Ill see if I can take some pictures of it and post for you guys.
LinkBack to this Thread: http://www.tundrasolutions.com/forums/gps-and-navigation-assistance/164446-eclipse-avn726e/
Posted By For Type Date
Eclipse AVN726e Steering wheel control? 09 DC - Tacoma World Forums This thread Refback 07-08-2009 09:14 AM
