Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > GPS and Navigation Assistance
  #76 (permalink)
Old 07-08-2009, 06:27 PM
Imdone's Avatar
2004 Toyota 4Runner,
Last Online: 10-31-2009 02:18 PM
Images: 23
Imdone is a splendid one to behold. Imdone is a splendid one to behold.
Imdone's Photo Albums My eBay
Default Re: Eclipse AVN726E
Originally Posted by woohah View Post
Should be pretty standard with Bluetooth to Bluetooth. I just tried it and it worked. As long as you have the agreement between the unit and your phone, you should be able to push your address book to the unit.
I meant about the Picture part. How did you figure out that the pictures may keep it from working. I have some that I have pics attached and never thought of this.
I am going to remove them and see if that does it.
RBP, ICON, CAMBURG, ALCAN, AMP RESEARCH, TOYO, ECLIPSE, SAVV, FOSGATE, KICKER, JL AUDIO, V-LEDS, PIAA, HELLA, MBRP, UNICHIP, TIMBREN, HYPERTECH
  #77 (permalink)
Old 07-08-2009, 08:16 PM
woohah's Avatar
Dealer : Mckinnon Toyota
2008 Toyota Tundra SR5 Red
Last Online: 07-08-2009 08:16 PM
woohah is on a distinguished road.
woohah's Photo Albums
I kept getting sync failed on the same place each time, so I removed the picture and viola!
  #78 (permalink)
Old 07-09-2009, 01:28 AM
Imdone's Avatar
Images: 23
Nice.
I'll see if this will work on mine with the BB8330.
Edit:
Yes, it worked, get rid of the pics and the Blackberry 8330 will data transfer the phone book. Took about 5 minutes but it worked! SWEET!
  #79 (permalink)
Old 07-09-2009, 04:51 AM
Dealer : Central Toyota Scion
2000 Toyota Avalon
Last Online: 11-14-2009 10:45 AM
kofifi is on a distinguished road.
kofifi's Photo Albums
this unit dual zone??
  #80 (permalink)
Old 07-09-2009, 10:27 AM
Last Online: 07-10-2009 08:06 PM
RotiWA is on a distinguished road.
RotiWA's Photo Albums
Hi AVN 726E owners !
Recently found this threat Googling for a solution to a bluetooth phonebook problem with this unit. We currently use Windows Mobiles phones (HTC Touch HD, HTC Touch Diamond & Sony Xperia) with similar problems.
I found (after a tip from an acquaintance) the solution to the problem mentioned earlier in the thread - that you need to remove contact pics to allow contacs to be pushed to the device.
I've also found that when you push a contact with multiple phone numbers (eg home, mobile, work, etc = most of our contacts), only one number registers in the phonebook. Someone suggested re-creating Outlook contacts with a separate entry for each number, which is not really practical. Anyone found a way to get the phonebook to sync/receive Outlook contacts with multiple numbers ? Unfortunately, the Parrott Hands Free kit (just removed) used to handle all of this just fine.
Cheers.
  #81 (permalink)
Old 07-11-2009, 09:00 AM
Dealer : Expressway Toyota Scion
2007 Toyota Camry
Last Online: 07-15-2009 11:29 AM
t3sn4f2 is on a distinguished road.
t3sn4f2's Photo Albums
Hey guys. Can anyone with a AVN726E help me out with a quick question?
I'm looking into using the unit's A/V input with a CarPC. I noticed in the Crutchfield description that they say you need to have the e-brake on AND the car not be moving. If I bypass the e-brake lock, will it still lock out the unit's AV input because of the GPS sensing movement?
Thanks
  #82 (permalink)
Old 07-12-2009, 02:02 PM
jmaldo's Avatar
Water Is Life
Dealer : Toyota of Augusta
Last Online: 09-23-2009 03:12 PM
Images: 5
jmaldo is on a distinguished road.
Send a message via AIM to jmaldo jmaldo's Photo Albums
Thanks
I dont have anything hooked into the av in, but i do have the ebrake bypass switch and everything works fine while driving (dvd and nav input. I dont see why the av input would be any different.
2008 Tundra CrewMax SR5 TRD 5.7L
Extang Trifecta Cover*Husky Liners*Step Bars*Reverse Camera*Head Rest DVD Players*Eclipse AVN726E
  #83 (permalink)
Old 07-12-2009, 02:17 PM
2007 Toyota Camry
Cool, thanks man!
  #84 (permalink)
Old 07-12-2009, 02:39 PM
jmaldo's Avatar
Water Is Life
Images: 5
Anyone with this unit have any issues with the addresses being off? Mine are about 10 off!!!
  #85 (permalink)
Old 07-14-2009, 07:38 PM
2000 Toyota Avalon
so the bypass is the same as grounding the light green wire correct... If not how do you bypass the system??
  #86 (permalink)
Old 07-14-2009, 09:19 PM
Dealer : North Point Toyota Scion
Last Online: 07-20-2009 02:24 PM
thump4863 is on a distinguished road.
Send a message via AIM to thump4863 thump4863's Photo Albums My eBay
Yep just like normal - mine is grounded out to the side of the system.
08 Super White Tundra DC 5.7L SR5 with the SAP
20" Incubus Poltergeists, Powerstick dual exhaust system, AFE Stage 2 Si CAI, Eclipse AVN726E w/ backup camera, JL Audio XR 650 components, RE Audio SL 12s in a Tech12Volt box, JL Audio 300/4 & 500/1 amps, 20% Tint, Billet Grill
  #87 (permalink)
Old 07-14-2009, 11:50 PM
Imdone's Avatar
Images: 23
You need to ground the parking brake wire. I just attached it to the ground wire from the unit, that's all it takes.
I don't think it's light green though, I thought it was purple and white???
Purple might be the reverse wire... Been a while since I installed mine... Just ground the Parking brake wire whatever color it is.
  #88 (permalink)
Old 08-04-2009, 10:46 AM
wpbrown985's Avatar
2010 Toyota Tundra 4.6L DC
Last Online: 11-19-2009 09:30 AM
wpbrown985 is on a distinguished road.
wpbrown985's Photo Albums
I have a question. My 2010 already has the BT Telephone mic built in the roof. Do I have to install a new mic for it to work or can I use the factory one Toyota provided with it? Also will all of my steering wheel buttons work with this unit? The volume/mode/ track select/ dial/ hang up/ and the command button?
  #89 (permalink)
Old 08-04-2009, 12:09 PM
jmaldo's Avatar
Water Is Life
Images: 5
Anyone using xm on this unit. Im hearing that the avn doesnt display the text right on the unit while using XM? THe update wont be released till late Oct Eclipse says..
  #90 (permalink)
Old 08-04-2009, 06:27 PM
Last Online: 08-04-2009 06:33 PM
Dave777 is on a distinguished road.
Dave777's Photo Albums
I purchased the Eclipse AVN726E 3-4 weeks ago and the GPS usually takes anywhere from 2-4 minutes to acquire the satellites (TTFF). Anyone had this problem with the AVN726E or know how to improve TTFF? The only thing I know of is to move the antenae.
LinkBack to this Thread: http://www.tundrasolutions.com/forums/gps-and-navigation-assistance/164446-eclipse-avn726e/
Posted By For Type Date
Eclipse AVN726e Steering wheel control? 09 DC - Tacoma World Forums This thread Refback 07-08-2009 09:14 AM
