Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > GPS and Navigation Assistance
Free Shipping at Buy.com!
FREE Personal Trainer Program
GPS and Navigation Assistance OEM Car, Aftermarket and handheld navigation discussions.
This is a discussion thread titled "Nav Issue", within the GPS and Navigation Assistance forum, part of the Technical & Vehicle Assistance Forums category.
  #16 (permalink)
Old 08-19-2006, 12:29 AM
adrien1977's Avatar
Dealer : Toyota of Naperville
2006 Toyota Avalon
adrien1977's Photo Albums
Last Online: 09-30-2008 11:54 PM
adrien1977 is on a distinguished road.
Default Re: Nav Issue
Yes I got all of these already,
I thought that the wirring diagrams would have more information but there is still nothing about the antenna.
is the EWD on the toyota web site?
thanks
  #17 (permalink)
Old 08-19-2006, 12:58 AM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
2004 Toyota Sequoia,
- Other - 1967 Mustang
mustang67408's Photo Albums
mustang67408 will become famous soon enough.
thanks
The EWD is a book and is alot easier to navigate thru when looking things up. Flip page to page
The Toyota website is 100's of PDF's that you have to flip thru. The problm is the 06 and up models do not have any links from page to page.
In the 05 and earlier the page numbers are highlighted in BLUE, and if you click on them they take you to that page. The 06 and up , you cant navigate that way. You have to go search for the particualr page and its very hard to do. Very time consuming.
I have also been thru everything I thought pertained to the GPS antenna. I dont see it and it doesnt explain to well.
Sorry, i dont know what else to tell you, without having the vehicle infront of me. I would just get the wire diagram and start a continuity check form every wire from the head unit to the ecu in the back of the vehicle.
23 yrs with TOYOTA
Discounts on Toyota Parts
K.I.S.S.
  #18 (permalink)
Old 08-19-2006, 01:02 AM
adrien1977's Avatar
2006 Toyota Avalon
I was able to download all the pdfs wor the EWD for the avalon 06 and I made one big pdf out of it. Like you said it is easier to go thru.
I know that the antenna comes from to the back to some connectors by the passenger from door.
I am going to check all that tomorrow anyway.
I do really appreciate your help and the time that you spent trying to help me.
thanks again
Adrien
  #19 (permalink)
Old 08-19-2006, 01:08 AM
2002 Toyota Tundra,
Heres a few more, I dont know what ya have.
23 yrs with TOYOTA
K.I.S.S.
  #20 (permalink)
Old 08-19-2006, 01:12 AM
adrien1977's Avatar
2006 Toyota Avalon
I have the two first not the other 3 but they are for the radio antenna.
Anyway, I'll try with the cable and a multimeter to find out if the cable is not cut, and if not I'll go to a dealer.
Thanks agani
adrien
  #21 (permalink)
Old 08-21-2006, 08:39 AM
adrien1977's Avatar
2006 Toyota Avalon
Finally
We solved the problem.
But it took us time.
The problem was that the antenna cable is not a straight cable from the NAV ECU in the trunk to the antenna under the dashboard.
The hardest task was to find out where that cable was going thru and where the connectors where. There was no indication in the repair manual and wirring diagram to tell us where they were.
Starting from the back we where able to see that the cable was taking another route that the other cable.
it starts from the back, goes in the ceiling (on the back of the ceiling) from the left side to the right side, then passes on the curtain airbags gutters all along up to the dashboard and then to the antenna thru the dashboard.
On the way there are at least 2 connectors.
One is on the dashboard and easy to access by removing the glove compartment.
The other one, and it was the one that was disconnected, is located in the curtain airbag, by the from rigth tweeter.
we reconnected it and, it worked.
The navigation unit is working perfectly with no problem
The car system check do not indicate any error. Everything shows up as Ok
I hope that this will help other may be in the future.
I'd like to thank a lot all the people that helped in this endeavor.
Thanks all
Adrien
  #22 (permalink)
Old 08-21-2006, 08:44 AM
2002 Toyota Tundra,
Glad to hear You fixed it
Sometimes you just have to jump in with both feet like you did. The books and manuals are just referances, it's down in the trenches or up in the headliners where you learn things.
Thanks for the learning experience, I think we all learned something.
23 yrs with TOYOTA
K.I.S.S.
  #23 (permalink)
Old 08-21-2006, 09:16 AM
adrien1977's Avatar
2006 Toyota Avalon
thanks to hear.
Now I have two more problems to fix and we are done.
One is the airbag light that is on even when we drive.
the other one is the dynamic cruise control that first do not work, (I think it is not aligned properly) and that sometimes it shows error E3 in the instrument panel.
I'll will open two new threads (actually I think I have one already open for the cruise control)
So you might hear from me again.
thanks
  #24 (permalink)
Old 08-21-2006, 11:43 PM
2002 Toyota Tundra,
Need acode from the airbag system , so I know what direction to head.
23 yrs with TOYOTA
K.I.S.S.
  #25 (permalink)
Old 08-22-2006, 09:39 AM
adrien1977's Avatar
2006 Toyota Avalon
I do not have a way right now to check codes.
I got to go to my in laws garage.
Also do I need a special scanner or the generic DTC scanner is enough.
not sure which model they have.
thanks
  #26 (permalink)
Old 08-22-2006, 09:46 AM
2002 Toyota Tundra,
There are no generic scan tools that will access the SRS, only the dealers scan tool.
This PDF should help you do it manually tho.
The other PDF is the code chart
23 yrs with TOYOTA
K.I.S.S.
Similar Threads for: Nav Issue
Gen 3 Nav Overide paa GPS and Navigation Assistance 5 06-10-2006 09:20 PM
Interesting Nav Issue w/ 2005 Sequoia ronbof117 1Gen-Sequoia 2 04-09-2006 10:54 PM
04 JBL stereo conversion to 05 NAV questions mfinley Audio & Stereo 3 02-17-2005 02:00 AM
Camry Nav Backup Camera Install in a Tundra rcltrh Member Mods 1 04-09-2004 07:25 PM
Installing factory Nav in 04 Runner. cdoyle Audio & Stereo 2 03-07-2004 06:53 PM
