Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > GPS and Navigation Assistance
GPS and Navigation Assistance OEM Car, Aftermarket and handheld navigation discussions.
This is a discussion thread titled "Nav Issue", within the GPS and Navigation Assistance forum, part of the Technical & Vehicle Assistance Forums category.
Old 08-10-2006, 10:40 AM
adrien1977's Avatar
Dealer : Toyota of Naperville
2006 Toyota Avalon
adrien1977's Photo Albums
Last Online: 10-01-2008 12:54 AM
adrien1977 is on a distinguished road.
Default Nav Issue
I posted a thread yesterday in the AVALON section
Not sure I got a lot of responses so I am trying here since there are more people
so here was the message
hi
As I said in my previous thread, I just got a 2006 toyota avalon limited with nav.
I got the car after a car accident from an auction and we repaired it.
However I have a couple issues with the navigation system.
the car has been outside with the engine on for a while and with open sky and it still has not found any satelite (the time is not set and i do not see the gps sign by pressing enter)
Could someone tell me where is the GPS sensor and also if there is a fuse for it (may be it blew up after the crash)
Also, I tried to remove the dvd but no way, it does not want to go out.
Please I need help
Thanks a lot
Adrien
Old 08-10-2006, 11:26 AM
czechm8's Avatar
Dealer : Jay Wolfe Toytota
2005 Toyota Sequoia,
- Other - Acura TL
czechm8's Photo Albums
Last Online: Today 05:23 PM
czechm8 is on a distinguished road.
Default Re: Nav Issue
Factory NAV antennas for the trucks are under the dash and above the NAV unit. Not sure about the Avalon.
Sounds like the antenna is not connected, malfunctioning, or your NAV unit itself is hosed.
05 Sequoia 4x4 Ltd. Phantom Grey Pearl, Weld 20" wheels on Toyo tires, MagnaFlow cat-back, Amsoil fluids, custom 15" overhead DVD system, Eclipse NAV system w/camera, Sirius tuner. DLS Nobelium components and coaxials, TRU B-2110 and H-1 amps, 13" eD sub, iPod hookup. SilverStar lamps.
Old 08-10-2006, 12:16 PM
adrien1977's Avatar
2006 Toyota Avalon
Thanks for the reply
What do you call nav unit?
I'll try to find a way to check the antenna.
However the system works ok using dead reckoning.
I've been driving and it indicates the position correctly.
Maps a working fine as well.
thanks
adrien
Old 08-10-2006, 12:31 PM
czechm8's Avatar
- Other - Acura TL
thanks
adrien
By NAV unit, I mean the Head Unit itself. Sounds like it works fine otherwise.
You said the vehicle was in an accident...........the NAV antenna wiring could have been severed or kinked, causing the lack of performance.
Old 08-10-2006, 12:36 PM
adrien1977's Avatar
2006 Toyota Avalon
it was a from left accident.
Not too much damage though.
I do not think that the cable was severed but may be disconnected
I just found this
Old 08-10-2006, 04:52 PM
Justme's Avatar
Dealer : Findlay Toyota Scion
2006 Toyota Tundra 4x4 DC Limited,
2000 Toyota Land Cruiser
Justme's Photo Albums
Last Online: Today 01:49 AM
Justme is on a distinguished road.
I think you have bigger problems than the antenna if you can't eject the DVD. Pulling the head unit will answer question about the antenna being attached or not. On the Tundra, it would take all of 10 minutes to do, on the Avalon not sure. Good luck!
hi
Please I need help
Thanks a lot
Adrien
2006 Tundra DoubleCab 4X4, Donahoe 2.5" Coilovers, Donahoe AAL, Procomp rear shocks, JBA Headers, Magnaflow 14586, WAAG Brush Guard, BakFlip, LineX Bedliner, Clear Bra, Window Tint, E7007 Navigation, VSE subwoofer!!
Old 08-11-2006, 10:14 AM
adrien1977's Avatar
2006 Toyota Avalon
According to inov8, the system has to be one to be able to remove the disc.
Thanks
Old 08-12-2006, 11:39 PM
Dealer : Jeff Wyler Toyota
2002 Lexus LX470,
2004 Toyota Highlander,
2003 Toyota 4Runner
PIONEERSUBY's Photo Albums
Last Online: 08-27-2007 03:30 PM
PIONEERSUBY is on a distinguished road.
maybe there isnt a dvd disc in the gps computer located in the trunk. sometimes towtruck drivers remove such parts which is worth 250.00 for an 06 nav dvd disc on the open market. ......as far as ejecting the dvd disc its a little tricky. . there is 2 layers to the eject button. first you slide the top button to the left which opens the dvd opening. then you push the bottom button which is seen after sliding the top button over to the left. you then hold the bottom button in for several seconds and then the dvd comes out. if you hear the mechanism making an eject noise then probably no dvd. if it makes no noise when you hold in the eject button then the unit may not be powered up.
Old 08-13-2006, 08:51 PM
adrien1977's Avatar
2006 Toyota Avalon
Thanks all for the responses.
First:
I was finally able to get the DVD.
Like someone said in another thread (Avalon section), the car has to be on, or better say the nav system on, and then I can eject the DVD.
The DVD is the version 5.1.
Second.
By removing the glove compartment I was able to "kinda" check the gps antenna. Wires seemed fine, not cut or anything.
The car was in a smalll accident, just the left front was damaged. The dashboard was fine.
So after making sure the antenna was plugged correctly I tried again.
No luck, still no satellite reception.
Everything seems to be fine since dead reckoning nav works perfectly.
I am not sure what to look for now.
Are there any relays I should check?
If someone has any idea, please help me....
Thanks a bunch.
Adrien
Old 08-13-2006, 08:52 PM
adrien1977's Avatar
2006 Toyota Avalon
Oh
And I also check the cabling in the nav unit in the trunk and everything seems fine.
thanks
Old 08-13-2006, 10:22 PM
adrien1977's Avatar
2006 Toyota Avalon
Ok
I have more information.
  1. Start the engine.
  2. While pressing and holding the "INFO" switch, operate the light control switch: OFF " ON " OFF " ON " OFF " ON " OFF.
  3. The diagnostic mode starts and the "Service Check Mode" screen will be displayed. Service inspection starts automatically and the result will be displayed.
I did this and in the navigation part a DTC error code show up.
I am trying to find it but I have no chance so far.
The error code is:
58-40
That is it.
Does anyone have a way to tell me what it means?
thanks
Old 08-14-2006, 02:06 AM
mustang67408's Avatar
KE7WLF Master of Disaster
2002 Toyota Tundra,
2004 Toyota Sequoia,
- Other - 1967 Mustang
mustang67408's Photo Albums
Last Online: Today 06:37 PM
mustang67408 will become famous soon enough.mustang67408 will become famous soon enough.
Ok
The error code is:
58-40
That is it.
thanks
That code is :
58-40 GPS Antenna Error
1. Wire harness
2. GPS antenna
3. Navigation ECU
23 yrs with TOYOTA
Discounts on Toyota Parts
K.I.S.S.
Old 08-14-2006, 09:33 AM
adrien1977's Avatar
2006 Toyota Avalon
cool thanks a lot
Old 08-19-2006, 12:25 AM
adrien1977's Avatar
2006 Toyota Avalon
Ok
Now it can't get worse.
I received the new antenna from the dealer.
I tried it quickly inside the car (I removed the glove compartment and unswitched the old one), with the antenna as close as possible to the door (it was almost outside).
Results: nothing was working. No satellite reception. (I used the system check)
Dang.....
I decided to go directly at the source. I removed the navigation ECU and plugged the antenna directly there. Ran a quick system check and ohhhhhhh finally, it worked.
So I guess the issue is the wirring. Dannnnngggg.
So I downloaded as many files as I though would be usefull from the TOYOTA TIS web site (i paid for a one day subscription $10).
Results, there is a bunch of explanation regarding all the wirring to the navigation ECU except the one for the antenna. I think I am doomed.
Anyway,
Does anyone have a complete wirring diagram to find out were exactly this cable is going to and which junction connectors it is using.
I looked everywhere and could not get the information I needed.
Pleaaaaasee help...
Thanks
--Adrien
Old 08-19-2006, 01:15 AM
2002 Toyota Tundra,
Here are some PDF's. I dont know if you have these or not. The antenna for the GPS is very complicated. It goes thru the head unit and is then divided into other wires as it heads to other ECU's
The best thing to do is buy a EWD (electrical wire diagram) from Toyota.
All the wire routing and connectors will be at your finger tips.
23 yrs with TOYOTA
K.I.S.S.
Similar Threads for: Nav Issue
Gen 3 Nav Overide paa GPS and Navigation Assistance 5 06-10-2006 10:20 PM
Interesting Nav Issue w/ 2005 Sequoia ronbof117 1Gen-Sequoia 2 04-09-2006 11:54 PM
04 JBL stereo conversion to 05 NAV questions mfinley Audio & Stereo 3 02-17-2005 03:00 AM
Camry Nav Backup Camera Install in a Tundra rcltrh Member Mods 1 04-09-2004 08:25 PM
Installing factory Nav in 04 Runner. cdoyle Audio & Stereo 2 03-07-2004 07:53 PM
