GPS and Navigation AssistanceOEM Car, Aftermarket and handheld navigation discussions.
This is a discussion thread titled "Need help installing an Eclipse AVN5495 in 06DC", within the GPS and Navigation Assistance forum, part of the Technical & Vehicle Assistance Forums category.
Has anyone installed the eclipse nav unit in an 06 Tundra DC with the JBL system? I previously had it in my 00AC and it fit perfectly and Crutchfield had an adapter harness. In the 06 they say it won't fit and has no jumper harness. Some of you must have put these units into your Tundra/Seq already. How did you fill in the gap that is left around the slightly smaller head unit and how was the wiring?
00 TUNDRA V8 AC LTD / 03 SEQ LTD / 05 TUNDRA V6 Longbed (2) / 06 TUNDRA DC / 07 TACO DC / 99 Tracker / 87 MR2
Re: Need help installing an Eclipse AVN5495 in 06DC
These are the Toyota part numbers for the spacers you will need on either side of the NAV unit.
86221-52060
86221-52050
There is a right and a left side.
05 Sequoia 4x4 Ltd. Phantom Grey Pearl, Weld 20" wheels on Toyo tires, MagnaFlow cat-back, Amsoil fluids, custom 15" overhead DVD system, Eclipse NAV system w/camera, Sirius tuner. DLS Nobelium components and coaxials, TRU B-2110 and H-1 amps, 13" eD sub, iPod hookup. SilverStar lamps.
86221-52060
86221-52050
spacers as in to fill the gap's benzel on left to right correct?
about wiring I dont see any reason's to be alarmed on the 00 and 06 there were some changes yes but overall the dual Din would fit and yes the Jbl amp will need to be bypassed....
T3 Grill, Line X extra front Bumper coating (too many mod's to list)
thanks so much for that picture I had to zoom in on your picture but that is what I need on my Tundra vs this I didnt know Toyota had a part number for that as I was looking at aftermarket Benzel peices..
I see you have a Pioneer unit. Not sure if these parts will work, but its worth a try.
The bolt holes on the spacers match that of the Eclipse AVN units, but you still have to modify them to make it work. You have to file down the slight ridge on the side that fits against the NAV unit so that it will fit flush against it. You also have to cut away part of the rear of the spacer to fit around the Toyota mounting bracket that bolts to the side of the NAV unit.
When all done it looks pretty stock as you can see from my pics. Just wanted to let you know that it does require some custom fitting.
Thanks czechm8. I called my dealer to order them he says they are for a celica. Looked at the parts photo and your install and they look like they are the ones. This dealer wants $30 USD for both of them. Thanks for your help again... Guys like you save us members tons of frustration and experimenting/research. PS nice Sequoia!
Befor you hand over that much money to the boys in the parts dept. Search ebay for this it cost me $6.99 plus shipping 12.99 total for the same part.
Scosche TA1465B 2000 -Up Toyota Double Din Install Kit
