Re: light not lead up
Originally Posted by thering
hi,
I have an avn5435, i just relied that the light about the Screen is not lead up, like Nav. Menu ...etc. is not Lead up, I think there is a wire that missing. Any body have any ideal. What wire do I need to connect to the 4Runner to lead up those light around the screen
thank you very much
Yes, your Night Illumination wire is not hooked up, or hooked up wrong. When you turn your headlights on, the buttons should light up and the NAV screen will go to the night display mode.
You will need to look at a wiring diagram to identify the correct wire in the harness. It is usually green or green striped.
05 Sequoia 4x4 Ltd. Phantom Grey Pearl, Weld 20" wheels on Toyo tires, MagnaFlow cat-back, Amsoil fluids, custom 15" overhead DVD system, Eclipse NAV system w/camera, Sirius tuner. DLS Nobelium components and coaxials, TRU B-2110 and H-1 amps, 13" eD sub, iPod hookup. SilverStar lamps.
