Don't have a date for finished product right now. I only know they are projected at the end of August to the middle of september. I am working on getting a date. I should be able to post the progress tomorrow.
I will post a must order by date at a later time. There isn't one right now. You can order them right now, however, they will not be shipped until completion. Just use the directions that I have posted in this thread for ordering.
I spoke w/S & S today. They are coming along nicely. The pipes are bent and all the flanges are cut. The Y-pipe is running behind but will catch up soon.
Loren is now working with another dealer to get the wiring harness issue taken care of. S & S would like to have the O2 sensor wiring extension done at the same time as the rest of the kit but it may not happen. Rgerdes and S & S are working diligently together with the connections Rgerdes has with Toyota and are trying to find company that can put these together for the kits.
If the extensions are not ready when the headers are done, S&S will supply extension wire to couple the existing wiring, then when the extension is finished they will supply to owners to update their systems.
S & S advised should be next few weeks to be done with the headers, hopefully they can get the O2 wiring done around the same time.
Once you know a "Must order by date", would you mind starting a new thread with lots of bells and whistles so us computer dummies can see it?
Im still getting lost with what I saw where with all of these catagories!
If I make a new thread it most likely will be moved to this one as it has to so with this group buy. If you subscribe to this thread using the link at the bottom of the page you will get an email every time someone posts something on this thread. I would recommend using this feature for this so you don't miss anything.
I will also edit the first post of this thread so it will show the group buy end date.
if anyone knows a source for the plastic connectors toyota uses for the sensor plugs, please let s&s know, it will speed the process for the wire extensions. i told them to look at digikey, but i don't know a part number.
I don't think you need to go that far yet, but if it is needed I will let you know. If you want to wait to get the part # until we need it I will PM you or post here.
We have been in contact with Denso and have Toyota Part numbers. Not all the connectors are currently available as it is not a popular part ot sell. Loren has the 2 female connectors and I'm trying to get the 2 mail connectors. Loren has made another inquiry with one of his suppliers and he has sent the o2 sensors (that I provided) to the vender to try and match the connectors. If all fails I will try to get a special handling order processed for the connectors. I made several phone calls to get these part numbers as this info is not easy to get. There are 4 different part numbers. Be patient as we all want the plug-in system and splicing is not an option............ Ralph
