Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Handling Improvements
Old 10-13-2008, 12:57 PM
Dealer : Ron Tonkin Toyota
Last Online: 10-22-2009 09:52 PM
zootjeff is on a distinguished road.
zootjeff's Photo Albums
Default Loosening Coil-overs? Compress springs first?
Hi,
I have a 2" lift kit from Fox. I want to lower the front as all I use this truck for is towing and it looks really lame 2" up in the front and 2" down in the back.
Do I just lube the threads, and then start twisting the rings with the spanner wrench? Or should I get some spring compression clips so that the rings will turn easier?
Here is a picture of the threads with the car jacked up..
Old 10-13-2008, 01:47 PM
los211's Avatar
Dealer : Piercey Toyota Scion
2007 Toyota Tundra,
2005 Toyota Sienna The wifes "bus"
Last Online: Yesterday 05:46 AM
Images: 6
los211 is on a distinguished road.
los211's Photo Albums
Default Re: Loosening Coil-overs? Compress springs first?
you should have gotten a spanner wrench with the shock kit. With that all you need to do is spin the lower one loose to whee you want to end up and then using the spanner twist the other one down to where the first one ended up. My advice would be to clean the shock body threads really good and then use a dry film silicon lube. It would be easier to clamp the springs to release the tension but if you have the spanners that won't be an issue. Just make sure the spring stays in its upper perch and doesn't rotate on ya.
'07 SR5 DC 5.7 silver sky metalic
5% tint rear windows, 2 Flowmaster 40 series w/ dual tips out the back, Carriage Works polished grill overlay w/emblem, 3-piece bumper inserts (not CW), Airaid, Ground Force rear shocks, DJM 3" arms, belltech flip kit, 22" BOSS 329 w/ 305/45/22 General grabber UHP, G2 bakflip.
Old 10-16-2008, 05:46 PM
Does anyone know what the ratio of coil over ring location to vehicle ground clearance is? For example, if I lower the coil-over rings by half an inch, does that mean that my truck will sit 1 inch lower? Is it 2:1 or 2.5:1 or 1.5:1 or something else?
-Jeff
Old 10-16-2008, 06:18 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
dyogim's Photo Albums
-Jeff
That's how it was on the Teamwest Sway Away coilovers.
Mike
http://dyogim.blogspot.com
