Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Handling Improvements
Old 10-24-2008, 08:23 PM
Dealer : Balise Toyota
2004 Toyota Tundra
Last Online: 11-15-2009 08:11 PM
Gman1985 is on a distinguished road.
Gman1985's Photo Albums
Default hellwig quastion
ok i got my sway bar and went to install it but since im mechanicly challanged .. i put everything together right, but i started tightening everything before i scrwed the right link to the bar so after everythin was tightened i had to force the right link to the bar. would it make any harm ?
hope it made sence its kind of hard to explain.
Old 10-25-2008, 12:56 AM
5 Speed's Avatar
Dealer : Longo Toyota
Last Online: Today 12:20 AM
Images: 19
5 Speed will become famous soon enough.
5 Speed's Photo Albums
Default Re: hellwig quastion
I did the write up DIY for the new hellwig
http://www.tundrasolutions.com/forum...6/#post1044206
I don't understand your question but I can't think of any way you could hurt it during the install unless you stripped the nuts or something. If you can be a little more specific maybe I can help
Old 10-25-2008, 11:49 PM
Dealer : Folsom Lake Toyota Scion
Last Online: 09-05-2009 01:19 PM
Budo Kai is on a distinguished road.
Budo Kai's Photo Albums
I think what you're saying is that you installed and tightened everything except that right end link and then forced and tightened that last end link...Is that correct?
My guess is that it should be fine unless you used some mechanical device to line it up which might bend something. I agree with the previous poster that there is a chance you could have messed up the threads on the bolt but if you were able to screw it on without straining too much then it should be fine.
I don't know about the gen1 tundra ( Mine was installed on a 2007 ) but the end links had lock nuts so they were harder to tighten. ( just an fyi )
Old 10-27-2008, 12:38 PM
Dave@Hellwig's Avatar
Dealer : Visalia Toyota
Last Online: Yesterday 10:51 AM
Dave@Hellwig is on a distinguished road.
Dave@Hellwig's Photo Albums
You are probably OK as the bushings can flex up to 5 deg off centerline.
