Handling ImprovementsTechnical discussions regarding sport suspensions, performance sway bars, shock absorbers, lowering kits and handling improvement systems.
This is a discussion thread titled "Hellwig AntiSway Bar", within the Handling Improvements forum, part of the Technical & Vehicle Assistance Forums category.
If you go to the top of the page you will see a SEARCH button, click on that then type in Hellwig. There are many threads that discuss the complete installation of the anti-sway bar.
Dan
__________________ DAN Click on my door and see my interior. 2001 Tundra SR5 V8 Desert Sand Mica
TRD Dual Exhaust | Bilsteins Shocks & HD TRD 4x4 Coil Springs | Hellwig Anti-Sway Bar | Westin Nerf Bars | Stainless Bed Rails | Bed Extender | Bed Liner | Form Fix Hood Protector | Custom Painted IS Grille & Mirror Covers | Stainless Tundra License Plate Frames | Custom Made Receiver Hitch | Totally De-Badged | Super Magnetic Oil Drain Plug | Mobil One Synthetic Oils | Custom Window Etching | Tinted Windows | Muth Signal Mirrors | Door Sill Protectors | Interior Rubber Mats | Gentex Temp & Comp Auto-Dim Rearview Mirror | Weatherflector Ventvisors | TS Decal | Complete Brake Upgrade | Truxedo Tonneau Cover| Michelin LTX M/S Tires
Re:
5. Made sure I mounted the U-Bolts outside of the brake line mounting brackets. I know through all the threads that this is the preferred place. I also see that the Wheelers Off Road website shows the install in the same location. Good enough for them, then good enough for me.
Actually, I don't think this is correct. Here's a pic of my install:
If you mount the U-bolts on the OUTSIDE of the brake line mounting brakets you will be off-center as to where the bushings need to mount on the sway bar. e.g. Each bushing needs to mount in the straight section of bar, not the curved section as would be the case if you mounted the U-bolts on the OUTSIDE of the brake line brackets.
The picture on Wheeler's web site is in error. Look at the right U-bolt...it's not even straight! (It's a poor representation of the "proper install" if you ask me.)
You will more properly load the sway bar if you mount the U-bolts perpendicular to the sway bar...
Seee-ya,
Jim.
__________________ Base: '02 Tundra SR5 Imperial Jade Mica 4WD w/ TRD Off-Road, EVP Convenience & Tow Packages, Oak Interior & Captains Chairs, 6 Speaker/6-Disk CD, VIP 3K, Chrome Wheel Locks, & Anti-lock Brakes with DRL Mods: K&N FIPK II, Ram Air Performance System (RAPS), Unichip, Ivan Stewart Flares and TRD Grille, 2" Cornfed Front Suspension Lift (How-To Guide), BFG A/T 265/75's, Hellwig Rear Anti-Sway Bar (How-To Guide), JBA Headers & 2" Highflow Y-Pipe, 2.5" Exhaust Cutout with QuickTime Performance Electric Cutout (QTEC), Flowmaster 50 Series™ Delta Flow® Performance Muffler with Dual 2.5" x 18" Chrome Tips, ASP Racing Underdrive Pulley, PPD Billet Goodies, Rhino Liner, Tinted-windows, etc. Planned: My Tundra is done for now. Next up: Build new 400ci for my '69 Pontiac Custom S
There's a lot of good stuff out there with the searches for sure.
I must have read them all twice before buying and installing this set-up.
Does this re-open the can of worms about what is the best placement?
My D-bushings are very close to the curved edge but not quite right on.
I pondered this while I was under the truck today and when I went back to the Wheelers site and with what others have done
on and outside of this site, I decided to go for the wider spacing.
Originally posted by tremo 5. Made sure I mounted the U-Bolts outside of the brake line mounting brackets. I know through all the threads that this is the preferred place. I also see that the Wheelers Off Road website shows the install in the same location. Good enough for them, then good enough for me.
Seee-ya,
Jim. [/b]
Yep, thats the way I mounted mine as well.
You dont want it to far out. The farther out you mount it the MORE it works to keep the truck level. You dont want the ride to be to level, it has to work some. Im certain most everyone here would suggest moving yours in just a bit (other side of brake line).
There was a LONG thread on this from the first group buy from Macs Springs early last year. This subject was discussed at length for quit a while. In the end it was decided to put them just inside the brake line mounting point. Seemed to be where it worked best for most everyone.
Also I trimmed off about 3/4" off the ends of the U bolts after I had mine on for a while. Still have about that much thread left showing after I was done. It was just to long. Not sure if everyone else did this though.
This still gets my vote for "Best Mod".
__________________ SATundra
2001 Limited, V8, 2wd, TRD, Metallic Silver Sky MODS:
TIRES: Michelin LTX M/S LT265/75/R16 load C rated
SUSPENSION: front - red/blu 4x4 HD Bilsteins shocks & HD TRD 4x4 coils providing 1.75" lift, rear - TRD add-a-leafs, Hellwig swaybar, yell/blu 4x4 Bilsteins INTERIOR: CB-Ham/Scanner/150W linear amp in custom console, 10 disc CD player, Donnelly comp/temp mirror, Toyota All Weather floormats, tinted windows, radar detector, backseat angle mod, EXTERIOR: Grizzly SS brushguard, Better Built alum toolbox w/lights, Weatherflector Ventvisors, chrome step tubes, UTR bedliner, hitch, SteelHorse Bull Rings, Mobil 1 oils, 2 TS stickers, 2 TS license frames, 2 www.TundraSolutions.com stickers, ELECTRICAL: 55W undercarriage entry lights, extra set 55W reverse lights, 55W underhood lights, DEI alarm, 12V Acc plug/engine compartment, 400watt power inverter, foglight/cargolight/acc plug/maplight mod
Here is a reply to the U-Bolt placement discussion from 8-31-03.
This is information provided by Wheeler's Off-Road owner Gary Wheeler:
"The instructions say to put the u-bolts over the axle to the inside of the lower shock mounts and to place the saddle brackets onto the u-bolts so the saddle bracket is to the inside of the lower shock mounts. There's no measurements or rocket science to it and the instructions don't provide any better location info than that. We have good luck mounting them as pictured. The bar still moves freely in the bushings and the bar has plenty of room before the bend starts. Having the clamps that far apart provides the bar maximum leverage to work which is what you're installing it for. If someone else can mount the clamps somewhere closer inboard then that's fine. Like I said, there's no rocket science to it and our picture is not an improper installation. The u-bolts and bushings are not under any bind or side load, the bar moves freely up and down before mounting it to the end links and the clamps and u-bolts are fine in the picture."
And as a final follow-up from Gary:
"Take a look at the front factory sway bar. Notice how the D-bushings are out as far as possible and the bends coming in and going out start pretty much right on either side of the bushing. The factory sway bar only has a short straight spot for the bushing, with a curve on either side. I remember on some of the older toyotas that had the bar in front of the axle that the bushings were spaced right to the last point they could go before the bar curved. Most sports cars are like that, too...
Thanks,
Gary"
Hope this information is helpful in adddressing the U-bolt placement issue.
Thanks for the follow-up Jerry! Looks like either way is "correct", but he may have a point re "Having the clamps that far apart provides the bar maximum leverage to work which is what you're installing it for." From what I recall it was rather close to the curve part of the bar, but perhaps there's still room.
Q: Did you understand this comment "The bar still moves freely in the bushings..." Moves freely? How does that happen once it's all tightened down?
Seee-ya,
Jim.
This was only in reference to the install before tightening it all down. You want to be sure that it does not bind and that it moves freely in the position that it is located. Binding would occur if it truly was in an incorrect location such as in an actual bend in the bar or near an obstruction.
I am very impressed with the results of this install and I just completed the full install of the TRD yellow/blues on all four corners as well. Great ride from a great truck !
Seee-ya,
Jim.
Yes Jerry thanks for following up on that.
Q: A: When the suspension (axle) moves up and down (going over bumps, turning, etc...) the sway bar pivots because the endlinks are mounted to the frame which is what is trying to keep everything level, straight or flat. This is the action that makes the swaybar work. I would imagine that there is a tremendous amount of pressure applied to those bushings when this pivoting occurs and the further out you mount the U bolts the more pressure that will be applied to try and keep everything level.
Hope that makes since.
Just got done installing mine last night. I've got an 03 so don't know if it's set up differently. I was able to put the rt side U-bolt to the INSIDE of the brake line attach point but not the Left side. The left side axle housing had a couple of welded on brackets that would have interferred with the saddle bracket so the U-bolt had to go outside the brake attach point. It still looks centered on the axle and the bushings look pretty close to even so I think I'm still OK.
Did have a couple of tips/hints. On the left side frame, the upper bracket bolt is just too cramped to get my hand up to hold it in place. I used a wire to fish it up to the bolt hole. Also, I found it much easier to put the bar links on the frame bracket with the bracket OFF the frame and then reattach it to the frame...just too tight getting the link bolt down through the bracket. I too had to trim off maybe 1/4" from the link tube to get enough length to thread the nut on.
Juries still out as to how good this mod is for me. I'll get a better chance to judge it this evening.
Thanks for the tips... just installed mine, but one quick question. Took it out, and when I turn, I can hear a distinct 'click-click'. I lubed the D-bushings good, and I can imagine the different areas that might be causing it, but is this normal? Or is something possibly not installed correctly? (followed included instructions and multiple tips from the site).
Thanks in advance...
Brian
Originally posted by BaxxSC Thanks for the tips... just installed mine, but one quick question. Took it out, and when I turn, I can hear a distinct 'click-click'. I lubed the D-bushings good, and I can imagine the different areas that might be causing it, but is this normal? Or is something possibly not installed correctly? (followed included instructions and multiple tips from the site).
Brian
The "click-click" doesnt sound right to me. Mine is silent. Its coming from the rearend right?
Just a guess - but did you recheck your nuts/bolts on the endlinks? Theres alot of stuff there, maybe you left something loose. Also you might try getting back under there and see if you can see anywhere where metal to metal might be rubbing, perhaps where your U-bolts mount close to the brake line mount on the axle housing. Remember the swaybar moves a little bit when its put under pressure, from the D-bushings compressing.
BTW I also added a good grease inbetween all the bushings/washers in the endlink assembly.
Let us know if you find whats causing it.
found it... the end link bracket on the driver side was not tightened all the way. It gave me trouble tightening it in the first place (due to welded bolt plate location) and it seemed find when finished at 12:30 am ... tightened up more and everything is fine and rides great!
B
Has anyone had a problem with the end link brackets loosening? The "J" bolt scares me a little. I have considered drilling a hole in the frame where the bracket already has one and adding an additional bolt. Other than that a great handling mod with the Addco end links.
So far;
Yeasu FT-8800 Amateur Radio, Rugged Liner, DuraHitch reciever w/7 pin light plug, Fog light mod w/custom indicator, Rear seat mod, Mobil-1, Spin on tranny filter, Magnefine power steering filter, Hellwig rear sway bar w/addco links & extra bolt, Formfit hood deflector, Almost free alarm upgrade, Sequoia split three wheels W/Yokohama H/T-S, Seat belt mod, Aux backup lights, De-badged, AC in derfost mode mod, Osram SilverStars, EnergySuspension Poly/greasable front swaybar bushings, Odyssey PC1200MJT Battery, Fumoto valve, R.A.S., XM w/USA Spec. TRD 4x4 Coilovers w/Bilstiens all around... When will it end!?!?...
Has anyone had a problem with the end link brackets loosening? The "J" bolt scares me a little. Other than that a great handling mod with the Addco end links.
I cant remember anyone having any problems with the swaybar once they got it installed. Its the "best mod" you can do to the truck IMHO.
