Received my hellwig antisway bar and am doing the install now. Does anyone know why the packing slip says "not legal for sale or use in California on any pollution controlled motor vehicle."? Not that it's going to stop me, just curious.
Maybe the retailer simple mindedly prints that on all aftermarket items???
Do perform a trial fit of the bar and all the hardware. Buy good replacements for any fasteners that don't fit or just look to be too cheesey.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Good luck with the install. Check my sig for a link to a How-To guide I created that'll provide you some additional pointers...
Seee-ya!
Jim.
__________________ Base: '02 Tundra SR5 Imperial Jade Mica 4WD w/ TRD Off-Road, EVP Convenience & Tow Packages, Oak Interior & Captains Chairs, 6 Speaker/6-Disk CD, VIP 3K, Chrome Wheel Locks, & Anti-lock Brakes with DRL Mods: K&N FIPK II, Ram Air Performance System (RAPS), Unichip, Ivan Stewart Flares and TRD Grille, 2" Cornfed Front Suspension Lift (How-To Guide), BFG A/T 265/75's, Hellwig Rear Anti-Sway Bar (How-To Guide), JBA Headers & 2" Highflow Y-Pipe, 2.5" Exhaust Cutout with QuickTime Performance Electric Cutout (QTEC), Flowmaster 50 Series™ Delta Flow® Performance Muffler with Dual 2.5" x 18" Chrome Tips, ASP Racing Underdrive Pulley, PPD Billet Goodies, Rhino Liner, Tinted-windows, etc. Planned: My Tundra is done for now. Next up: Build new 400ci for my '69 Pontiac Custom S
I put mine on my Tundra by myself. It took a couple of hours. I couldn't get a helper but the floor jack worked fine.
I pre-assembled on the floor and slid it under the rear axle.
I guess I lucked out ... all the fastners were there and it went together without a hitch.
I was surprised however by the crude paint job on it. It looks loke they have some chipanzees in the back room with spray cans. Well at least it's all black.
Put it on yesterday. Would have been easier if I could have got it up on a hoist or had a helper but still wasn't to bad be myself. Paint was kind of crappy so I sprayed everything flat black with some heavy duty marine paint I had lying around. No missing hardware, two extra nuts. Truck handles better now but I think I need to upgrade the shocks still.
I am sure if I search long enough, I will find it, but, haven't found it yet.
I plan to pull my Hellwig bar when I return home. I have the new end links sitting in the garage. I want to replace the D bushings with poly. I cannot remember what the diameter of the bar is.. 1" or 1 1/8". Anyone replaced their bushings with red poly? Can you provide a link where to purchase? Greaseable? Energy suspension? Thanks.
I swear my memory is getting lost over the border.
John
The Toy: 2000 Tundra 4.7L TRD Limited 4x4 Red Pearl (23.0k Original Miles)
The mod list is long. Check some pics in my gallery for mod detail.
They probably just put the wrong slip in the box.
'01 Color-Keyed Limited Tundra TRD 4x4
JBA Headers, TRD Exhaust, IS Grill, IS Bilsteins, Hellwig Sway Bar, AR-23 wheels w/ 265/75 Yokohama AT's, SnugTop XV Shell, BedRug, Yakima Rack
Check the Comments for a link to Summit and you'll see the sway bar is 1 1/8". Check the Description and you'll see a link to a pic of my Polygraphite Front Sway Bar and End-link Bushings from Wheeler's, who may sell 1 1/8" Poly D-Bushings for the Hellwig? Check my Sig for a link to the Hellwig How-To guide!
Seee-ya,
Jim.
Seee-ya,
Jim.
Thanks, guy. Let me check. I already have the Wheelers kit for the front sitting at home waiting for install. I have the Hellwig installed already, but, I want to replace the soft bushings that come with the kit. I have new endlinks for the Hellwig sitting at home waiting for me, but want to replace the D bushings as well, when I pull it down. A little OT, but, I am planning a "mod vacation" for the Tundra. Visit family, BBQ's with plenty of beer, and then, time to play. With a little help, I am planning on 22 mods in 10 days (hard to believe, but, I want to get dirty and have some fun) for my ride when I get home. Many are subtle changes, except for the TRD LSD unit to start the driveline upgrades for me. My daughter tells me the packages are cluttering the garage!
John
I installed my sway bar as the instructions specified. Now, I want to take off the sway bar links to allow for more movement offroad. I should have installed the long bolts updise down. Do I have to remove the mounts from the frame to get the long bolts out if they were installed right side up?
Thanks.
2003 Stratosphere Mica SR5 Access Cab
Shocks: Bilstein 5100 coilovers and 5100s in the rear.
Wheels: Toyo Open Country A/T 275/70/16s on MB Blitz rims
Thanks.
Hi mmarlatt, I believe I successfully reversed mine after making that discovery about two years ago. The memory is a bit foggy, but I think it can be done. Worst case, the brackets may have to be loosend up a bit to get some wiggle room.
I just ordered a Helwig for my truck and was looking for the instructions again, but when I clicked on your link for the how to guide it wasn't found . Has it been moved? Anybody know where I can find this now? I looked in the Aftermarket and Suspension databases and didn't see anything there either. Thanks...
You're right! They moved it. I edited my sig...try it again. (Optionally, check under Mods of the Month for all the good stuff.)
Seee-ya,
Jim.
