Handling ImprovementsTechnical discussions regarding sport suspensions, performance sway bars, shock absorbers, lowering kits and handling improvement systems.
This is a discussion thread titled "-Hellwig Anti-Sway Bar A & Q Thread-", within the Handling Improvements forum, part of the Technical & Vehicle Assistance Forums category.
Is there anything I can spray on those sway bar mounting brackets to keep them from rusting?
__________________ Website Founder and Account Manager
2007 Toyota Tundra 4x2 Sport Truck 5.7L V8. DZ BU EC EM FE HM PN RN SL SM SP WR Black over Gray / Black interior.
Interior: Dynamat Xtreme and DynaXorb.
Audio: Eclipse AVN6610 with Sirius, Bluetooth and Backup Camera, AudioControl DQXS/DDC EQ, 1, XA4000 Amp, 3, XA1000 Amps, SC8365 3-Way Comps, 3, SW7200 12" Subs, 2 Eclipse MRE-700 7" DVD Sceens.
Security: CompuStar Pro Custom Security System with Remote.
Exterior: Line-X Xtra, FormulaOne Pinnacle AF35 Window Flim.
Exhaust: Magnaflow custom dual-in dual-out exhaust.
Suspension: BellTech Lowered Suspension Kit, coil-overs, TRD Sway-Bar.
Wheels / Tires: 20x9" Zinik Z12 Mazotti Polished Aluminum Wheels inside Goodyear 305/50/20 GT II tires.
Daily Detailing: Optimum No Rinse Wash & Shine, Finish Kare 425 Spray Detailer.
Detailing: Pinnacle Souvern Carnuba Wax from Autogeek.net.
I am planning on installing by Hellwig tomorrow. Quick question, for those of you with a small (1-2") lift in the rear (aal, or block) what did you do for the end links. Do I need to get longer ones? If so where do I get those. The truck is not lifted at all, but soon will be (1-2 months).
Thanks in advance
I have the Cornfed with the 1.25" block in the rear and just installed my Hellwig, which by the way is SWEET! I didnt' have any problems with the increased distance, but I did have to use a ratchet type wood clamp to try to compress the stuff together close enough to get the lock nut started. Other than that it was a pretty easy install. If you follow the instructions available in the How-To section here, it'll give you some good pictures of how tight the lock nut needs to be and how much the rubber bushing start to bulge once it's tight enough.
Mods: Cornfed 2.5" Lift | Differential Drop Spacers | 930 Inner CV Boots | ProtechEZLift Limit Straps | Spintech Sportsman XL Muffler | Brembo Front Brake Rotors | A.R.E. Z-Series Cap w/ Thule Rack | Stubbs Rock Sliders | Hellwig Anti-Sway Bar | 285/75/16 BFG All Terrain TA KO's | VIAIR 400C Air Compressor w/ 2.5 gal tank | Front clear corner lamps | Odyssey PC1700T battery | Optima Red Top 75/35 battery (backup starter) | Hellroaring 95300A Isolator/Combiner | Truspeed Calibrator
Future: ARB Sahara Winch Bumper | New UCAs & Coilovers | 4.30 Gearing | Mickey Thomas Classic IIs
I've just ordered my Hellwig sway bar for my 05 Tundra DC that I'll pickup a week from now. Is the installation pretty easy? Does it come with all the hardware? Any tricks or advice prior to install. Thanks
There's a thread with nearly 50 replies a few clicks down in this forum. It has tips, instructions, and advice; everything you need for a clean install.
You could always paint them with a good quality paint. The u-bolts might not slide onto the axle though if they were painted. Other than that you can periodically spray some wd-40 to keep off the rust.
I just ordered a Hellwig rear swaybar P/N HEL-7641 from Summit Racing (1-800-230-3030). Summit's website says that this bar fits 2000-2003 Tundra's. When I asked if it would also fit the 2005 double-cab they suggested I call Hellwig (1-800-367-5480) and talk to their application folks. I took their advice and sure enough, the HEL-7641 also fits the 2005 double-cab.
My out-the-door price from Summit was $168.34, shipped to me in New Hampshire. It should be at my house in a week. I'll post another message once I get it installed and give a full report on the installation as well as the results.
Stay tuned...
Interesting... Hellwig told be the frame was different on my 05 DC and they hadn't yet made a determination if they needed to make changes. Guess I'll bolt mine from my 03 up .
On another note, my friend just got one for Xmas for his 99 K1500 Chevy. I love how they did the bar, it goes to the rear, Vs front and the brackets/links are a lot better then the ones they use on the Tundra. I was hoping they would be changing ours to like the new style for the K1500's, but if this one works that's fine.
__________________ 06 Toyota Highlander Hybrid Limited (former ride - 05 Tundra Limited Double Cab, 4x4, TRD Pkg, Trailer Tow, Auto Dimming mirror, Factory Bed Liner, Running Boards, Bug Deflector, Sun roof):
[ Click Here to see my pictures.
Wife's Car :05 Prius - White, Option package 6, Glass Break Sensor, Mods: Auto door lock, Molded mud flaps, Cargo Net. Not much more you can get on it.
Oh by the way, "Batteries are included" with the Prius & Highlander Hybrids
Like what you see and read on this site? If so, please consider supporting this site and help keeping it going by becoming a Subscribing member. You'll gain total access to all the Knowledge Base Tech Forums, fun & information and help keep this site on-line... Remember nothing good comes FREE Join The Club Today!
the install is fine, but make sure all the nuts are the proper ones. I had to go to the autoparts store because at least half the nuts were wrong. they were either the wrong size or the wrong thread.
I got all the correct hardware and the install took about 45 minutes by myself. In hindsight I could have saved myself half that time by assembling the endlinks to the bar first then attempting to install the bar to the truck. Also use Loc-tight (high strength) to keep those bolts from loosening up, just make sure you test fit the bar before locking down those bolts.
Lastly if you're having a problem getting the bushings on the end links where it attaches to the bar try screwing the bushing in like a nut and it'll compress enough to fit the locking metal nut easily.
Spintech 3332XL Muffler | Hellwig Rear Anti-Sway Bar | Updated 2005 Tail Lights | Updated 2003 Alloy Wheels | AMSOIL OAF-15 Oil Filter | Ultra-Strong Oil Filter Magnet | Synthetic Fluids all around | Line-X Bedliner | Osram Silverstars | Michelin LTX M/S tires | Custom Grille w/updated Body Panels | De-Badged | Optima Spiral Cell Gel Battery
I don't why I waited so long to get the Hellwig anti-sway bar....BIG DIFFERENCE...got it in this last wet weekend..It's all worth it..Now I know
why it's one of the top mod you can do....Thanks to everybody that recommend that its a "must have".
Am I the only one to notice that the parts that come in the kit are just filthy? In fact, the entire inside of my box is covered in grime and dirt. The saddle brackets and u-plates are all chipped up. I guess they just keep this stuff laying around, probably in some huge pile of parts out in the open. I'm now not at all surprised as to why some people get the wrong parts in their kits.
All the parts in my shipment were filthy too. I had to wash my hands after I took everything out of the box for inspection. Thankfully for me they got my order right and it went in without a hitch.
