Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Handling Improvements
Old 10-30-2005, 03:39 PM
daso73's Avatar
Dealer : Hartford Toyota Superstore
2005 Toyota Tundra
Last Online: 04-19-2006 05:59 PM
daso73 is on a distinguished road.
daso73's Photo Albums
Default Rear Jack-Point w/ Hellwig?
Installed Hellwig last month and love it. I just realized though, while trying to rotate my tires, that I have essentially eliminated any possible jack point on my rear axle due to the Hellwig brackets taking up the available space. As most of you probably know, the owner's manual says the rear axle (right next to where your shocks are mounted) should be used when jacking up the rear of the Tundra.
Anyone else w/ this difficulty? Where do you set up your jack? Where else is strong enough to support the weight? I have a 3-ton hydraulic jack w/ a 4-inch diameter lift plate.
Dave
Old 10-30-2005, 03:59 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
dyogim's Photo Albums
Middle of the axle is fine as a jack point. The part near the shock mounts are for jack stands.
Mike
http://dyogim.blogspot.com
Old 10-30-2005, 04:45 PM
HBjeff's Avatar
Dealer : Carson Toyota Scion
2005 Toyota Tundra
Last Online: 11-18-2009 09:43 PM
HBjeff is on a distinguished road.
HBjeff's Photo Albums
thats interesting. im really glad you posted this. can you use like a 4x4 piece of wood at all to narrow the jacks contact patch?
05 tundra 4wd
cut up with long travel
Old 10-30-2005, 07:11 PM
daso73's Avatar
2005 Toyota Tundra
What do you mean? Any ideas are worth thinking about...
2005 Toyota Tundra,
- Other - 96 Acura 3.2 TL
Last Online: Yesterday 05:09 PM
tempetom is a glorious beacon of light. tempetom is a glorious beacon of light. tempetom is a glorious beacon of light. tempetom is a glorious beacon of light. tempetom is a glorious beacon of light. tempetom is a glorious beacon of light. tempetom is a glorious beacon of light.
tempetom's Photo Albums
I was thinking you could put a piece if wood between the threaded parts of the Hellwig mount. If so, I'd carry a piece at all times
Old 10-30-2005, 07:19 PM
HBjeff's Avatar
2005 Toyota Tundra
i would need to see a pic of a hellwig again, but im thinking maybe cutting a piece of wood to go between the jack pad and the axle, to somehow get around the swaybar. maybe hollow a groove out or something
05 tundra 4wd
Old 10-31-2005, 01:43 AM
george60's Avatar
Dealer : Geweke Toyota Scion
2003 Toyota Tundra
Last Online: Today 01:59 AM
george60 will become famous soon enough.
george60's Photo Albums
Do Not use any part of the Helwig bar to jack up your truck. It's not strong enough. Just stick the jack under the pumpkin with some wood blocks and up it goes.
LACK OF PLANNING ON YOUR PART ----------------
DOES NOT CONSTITUTE AN EMERGENCY ON MY PART !!
Rear fog lights on 2005 T4R sbryan 4Runner 2 04-11-2006 02:32 AM
Rear brake does not work? v8Toilet Brakes 2 08-10-2004 07:33 AM
rear heater shweggy 1Gen-Sequoia 10 01-25-2003 12:54 PM
