Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Handling Improvements
Old 01-20-2006, 07:53 PM
dphouse's Avatar
Dealer : Northridge Toyota
2003 Toyota Tundra
Last Online: 05-25-2009 03:09 PM
dphouse is on a distinguished road.
dphouse's Photo Albums
Default Lifted Tundra and Minimizing Body Roll?
TS,
How can I reduce the dreaded body roll with a lifted tundra? I was wondering if polyurethane bushings and/or a Hellwig sway bar would help? Does anybody have experience with the bushings? I know the sway bar by Hellwig will help, but will the bushings do much?
I am thinking of getting the steering rack bushings in conjunction with polyurethane bushings for the front suspension.
Any feedback is appreciated (as long as it is positive)
Mods:Teamwest SAW 2.5" Coilovers, Bilstein 5100's, 1.25" Pro-Comp Blocks, 285/75/16 BFG AT KO on MT Classic II's, Factory Skid Plate, 20% tints, Truxedo Lo-Pro Tonneau Cover, Debadged Emblems, Stubbie Antenna, K&N Air filter, Borla Cat-Back Exhaust.
Old 01-20-2006, 09:57 PM
TMS2U's Avatar
Moderator
Dealer : Longo Toyota
Last Online: 10-01-2009 03:29 PM
TMS2U is on a distinguished road.
TMS2U's Photo Albums
Default Re: Lifted Tundra and Minimizing Body Roll?
Helwig or an add-a-leaf. Doing the bushings isnt a bad idea, but wont help as much as a sway bar or AAL
Old 01-21-2006, 04:34 PM
dphouse's Avatar
2003 Toyota Tundra
Hey Tedd,
I have a 1.25 block in the rear. Swapping that out for an add a leaf will help out? Which add a leaf do you recommend?
-Narbeh
Old 01-21-2006, 04:38 PM
TMS2U's Avatar
Moderator
Yeah. The Deaver progressive pack that Demello sells is pretty good, but there ore others. Do you still have your overload leaf?
Old 01-21-2006, 05:35 PM
dphouse's Avatar
2003 Toyota Tundra
[QUOTE=TMS2U]Yeah. The Deaver progressive pack that Demello sells is pretty good, but there ore others. Do you still have your overload leaf?[/QUOT
I didn't remove any of the leaf springs upon install of the block, so the overload spring is still there. Are you suggesting a complete replacement of the leaf spring pack or to just add a leaf?
Thanks Tedd.
Old 01-21-2006, 08:15 PM
TMS2U's Avatar
Moderator
AAL is plenty. The Deaver progressive pack will get rid of the overload leaf
Old 01-21-2006, 09:49 PM
MOREPOWER's Avatar
Last Online: 09-06-2008 09:56 AM
MOREPOWER will become famous soon enough.
MOREPOWER's Photo Albums
I strongly recommend a hellwig sway bar it took all body roll out of my tundra. I have an inch block and a hellwig wow what a difference.
add a-leaf are OK but will stiffen your ride
