Custom Search
Welcome to the Tundra Solutions Forum forums.
Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Handling Improvements
The Tire Rack- Revolutionizing Tire Buying
Click here for the Best Buy Homepage
Free Shipping at Buy.com!
Cake Batter Muscle Milk, Exclusive Flavor
Bad Credit? No Credit? No Problem!
Handling Improvements Technical discussions regarding sport suspensions, performance sway bars, shock absorbers, lowering kits and handling improvement systems.
This is a discussion thread titled "Too much swaying?", within the Handling Improvements forum, part of the Technical & Vehicle Assistance Forums category.
Old 05-22-2006, 11:46 PM
Dealer : Kern Toyota
98Hawk's Photo Gallery
Last Online: 06-08-2007 02:36 PM
98Hawk is on a distinguished road.
Default Too much swaying?
I have a 2000 AC 4wd tundra with a class III Reese hitch. I know the suspension is soft on this truck. I'm used to a 94 toyoto standard cab...Very stiff. But even when I'm pulling my trailer with two seadoo's, I can feel the truck sway what I think is a little more than it should at highway speeds. I plan on towing about 6000lbs on occasion. I'm kinda worried about this. Is there anything I can do to help with the swaying or am I just gonna have to deal with it. Thinking about helper springs for when I move firewood and such because I amost bottom out now when I hit speedbumps in my development.
Old 05-23-2006, 01:23 AM
IStan's Avatar
Dealer : Findlay Toyota Scion
2001 Toyota Highlander,
- Other - '06 Boosted 350ZR
IStan's Photo Gallery
Last Online: 06-10-2008 12:44 PM
IStan is on a distinguished road.
Default Re: Too much swaying?
Has the suspension always been soft? Might consider the Ivan Stewart (Red Blue?) shocks to stiffen up the ride. As well as Hellwig sway bar.
Tundra is gone...*Map Light mod *Keyless Upgrade *Monster ICruze *Nitto Terra Grappler AT 285/75/16 *Black Helo Maxx 8 16x8 *4x4 TRD Coils *4x4 TRD Shocks *Daystar 2.5" Spacer Kit *Bilstein 5100's *P.A 3" Body Lift *Toyota Drop-in Bedliner *Toyota LSD *Toyota Hood Protector *VentShades *Debadged *Tint *Flowmaster 50 Series Single Exhaust *Clear Corners *Chrome Nerf Bars*
Nissan 350ZR is here...350zen,org
Old 05-23-2006, 06:40 PM
Dealer : Toyota of Southern Maryland
2005 Toyota Tundra
tomhole's Photo Gallery
Last Online: Yesterday 03:24 PM
I'm not smart enough to answer the question directly, so I will postulate.
A soft rear is not a primary cause of sway. Improperly balanced trailers are. Stiffineng up the rear with helper springs, shocks, air bags, Timbrens, etc... will likely not solve the sway problem. Have you checked your hitch weight and trailer weight to determine what % of hitch weight you have? Can you position the load on the trailer to put more weight on the hitch?
I tow a 5,000 lbs, 23' (25' hitch to bumper) travel trailer with a hitch weight of 640 lbs plus (12.8%). With no sway control, it does fine until something exites the second order yaw moment and then it sways. It is not divergent, but not well damped either. I originally had a single friction sway arm installed and that helped, but in high xwinds, it would still excite sway, but it was well damped. Nothing scary and well under control. I switched to a Reese Dual Cam setup and now nothing excites the second order yaw moment and sway is eliminated. I still get pushed around by big rigs, but that is another force at work.
So, see if you can increase your hitch weight while towing the jet skis. Add springs or other such stuff to help with the heavy loads in the bed. Be careful to stay within weight limits regardless of how much help you add. There is a neato keen picture of a Tundra frame cracked by overloading.
Tom
Old 05-23-2006, 10:10 PM
Dealer : Longo Toyota
2000LtdKen's Photo Gallery
Last Online: 06-27-2008 10:11 PM
2000LtdKen is on a distinguished road.
98Hawk,
I have a 2000 Limited Tundra. First order of business would be to make sure your tires are filled up to the maximum limit (all 4) this helped my truck right off the bat. Then I would add a Helwig Sway bar to keep it from leaning too much in the corners. So now we have spent about $150 or so and you should see definate improvement. Trailer loading as another pointed out is also important. Our trucks come with Load Range C tires. These are very comfy and cushy to ride on. You can put Load Range D or E on your truck and inflate them and this will change the ride to be much firmer.
Hope this helps.
Ken
JBA Headers, Gibson Muffler, Daystar Front Level Lift, CDT Kama Speakers, Elemental Designs 9.4 Amp, Eclipse CD2000 Head Unit.
Old 05-24-2006, 09:00 AM
Dealer : Towne Toyota
2004 Toyota Tundra
NJMikeC's Photo Gallery
Last Online: 04-30-2008 02:11 PM
NJMikeC is on a distinguished road.
98hawk,
I think there is a lot of information missing. Primarily missing is your definition of sway and what sway is. It wouldn't hurt to elaborate on that a little.
If you don't have the particular trailer balanced then that is the first thing to look at. I'll guess that your pulling between 2000 # to 2500# with the Seadoos. A WD hitch would help. I'm not sure I remember the specs of when Toyota recommends that but it is a little mute. Even the smallest trailer will act "Squirrely" if the hitch weight isn't balanced correctly.
So in regards to towing the Seadoo's first check if the tongue is level. That will help. Then check your specs of when a WD hitch would be required.
Finally as for 6000# you definetely need the WD hitch and you also have a lot more homework to do. At 6000# of trailer weight you are typically at the max of the truck's GCWR as well as GVWR. That brings into play many factors since you are now outside of the operating range for which the truck was designed for. It is my opinion that you must change some things in your truck to move that operating point. In my opinion the weak links are brakes and the rear end. The transmission can be cooled, max torque point in the engine lowered but don't know quick fixes for the other 2.
Bookmarks
Similar Threads for: Too much swaying?
06 Rav4 swaying benchr RAV4 14 03-10-2007 11:56 AM
TundraSolutions.com and the TundraSolutions.com logo are among the registered trademarks of Tundra Solutions, Inc.
Questions? Please use the Contact Us link or call (559) 323-5444. Other websites: Dealer Hunter JPV Photography
