Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Handling Improvements
  #16 (permalink)
Old 10-11-2006, 08:12 PM
Dealer : Miller Toyota
2005 Toyota Tundra DC Phantom Gray
Last Online: Yesterday 06:23 PM
Images: 11
dibble9012 will become famous soon enough.
dibble9012's Photo Albums
Default Re: Installed my Hellwig today :)
The mirrors were $242 shipped, lowest price I found with froogle, ebay would probably be cheaper but I wanted them now instead of later. Auto Accessories - Car alarms, Euro Tail Lights, Altezza Lights, Car Covers, Lowering Springs, Performance Car Parts & more at SlickCar.Com They are made by muth. Mine are the heated version = more expensive.
One of my concerns was how much it could distract the driver. Even at night they are not distracting at all, I'm used to them and it's been only a day,lol
I will constantly be checking the sway bar for a while to make sure everything is fine. Boy, still can't believe what a difference it makes!!!
Originally Posted by smf View Post
I just took a look at mine and the drivers side u bolt is slightly tilted as well. The space that you have on the pass side shock mount is about the same space I have with the spacers installed. The finish on yours is also different than mine. I have a black coated bar. I wonder if there is a difference in size as well . When I talked to Hellwig they assured me I have the right part number. Oh well, it's all good now. As for the end link, I have a slight tilt also. I would keep an eye on the rubber bushings to make sure they don't start to mushroom from too much pressure. BTW, I like the mirror turn signals What did they run you if you don't mind me asking?
  #17 (permalink)
Old 10-11-2006, 08:15 PM
Images: 11
The anti-sway bar was $195 shipped from summitracing.com
The mirrors were $242 (heated version) made by muth, I am sure they would fit an 04, I don't think the mirrors changed between 04 and 05
Originally Posted by bmann7 View Post
Nice bar - what did you pay?
Also LOVE the mirrors - can my 04 DC get those Hmmm? how much for them??
You are going to cost me some $ I think!
  #18 (permalink)
Old 10-11-2006, 08:20 PM
Images: 11
Also, I think I already mentioned that I had missing nuts (for the anti-sway bar, hahaha) Anyways, I emailed Hellwig, and within the hour they responded letting me know that I will have replacement ones shipped tomorrow via UPS.
I'm happy
  #19 (permalink)
Old 10-11-2006, 10:23 PM
Mr. Creosote's Avatar
Legendary Contributor
Last Online: Today 01:46 AM
Images: 4
Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One.
Mr. Creosote's Photo Albums
Originally Posted by Puffnstuff View Post
I had a hellwig kit before on my silverado and I had to do a lot of stuff to make it fit right. I even had to drill out several bolt holes because they were not completely circular. I complained to hellwig but they did nothing. To top things off I even had to buy new bolts, nuts and washers because several in the kit were unusable.
Me too. Hellwig needs to include a selection of die grinder bits with each kit. Lots of trimming to do to make it work, plus the whole bar would not properly clamp on the rear axle tube. I kept having to straighten it out until it rusted into place.
  #20 (permalink)
Old 10-11-2006, 11:01 PM
Dealer : Arlington Toyota Scion
- Other - 2003 Accord 6MT,
2004 Toyota RAV4 L 2WD,
2006 Toyota Tundra Limited DC 4WD
Last Online: 07-17-2009 10:54 AM
spleck is on a distinguished road.
spleck's Photo Albums
Thumbs up Great Pictures
Excellent pictures Dibble. Truly worth a 1000 words.
  #21 (permalink)
Old 10-11-2006, 11:06 PM
Images: 11
Default Re: Great Pictures
Thanks, didn't realize my pictures were that good
I have to give a lot of credit to the person who wrote the write up here on TS, It would have taken a lot more time to install if I didn't have that to refer back to!!!
  #22 (permalink)
Old 12-12-2006, 10:14 PM
Images: 11
Here are the last 2 pictures from post 11, for some reason I cannot edit the post to change the URL.
  #23 (permalink)
Old 12-12-2006, 11:04 PM
slimjim2525's Avatar
Dealer : Gale Toyota Scion
2006 Toyota Camry SE Silver,
- Other -
Last Online: 05-22-2009 01:13 PM
slimjim2525 is on a distinguished road.
slimjim2525's Photo Albums
I asked santa for those mirrors, how easy was the install?
  #24 (permalink)
Old 12-12-2006, 11:12 PM
Images: 11
It's a really easy install. The best way to install the actual mirror glass is to remove the whole mirror assembly (have to do this anyways for the wiring) and take it inside on carpet, that way you can get more force to have it snap in. But remember, don't force it too much, if it won't snap in, one of the pins might be mis-aligned.
I also used some molded 2 pin disconnects in line, one after the wire enters at the mirror and door, and another after the wire enters the cab from the door. This way if I ever need to replace the mirror or worst case the door, everything is easy to remove. I have some of these left over if you need them.
  #25 (permalink)
Old 12-12-2006, 11:40 PM
hndymn's Avatar
No job too small.
Dealer : Mark Toyota
2006 Toyota Tundra SR5 AC Salsa Red,
2003 Toyota Matrix Blue XR,
- Other - 92 Toyota LB 1-ton
Last Online: 11-17-2009 01:26 PM
Images: 16
hndymn has a brilliant future. hndymn has a brilliant future. hndymn has a brilliant future. hndymn has a brilliant future. hndymn has a brilliant future.
hndymn's Photo Albums
I agree the Helwig Sway bar makes a huge difference. I took me about an hour or so to install. I did have to modify one of the bolt sleeves since it was about a 1/4 of an inch longer than the other and I could not get the bolt on. As for fit...how close does your sway bar sit from the pass. shock mount? Mine was less than 1/8 of an inch and it sometimes rubbed. I talk to the guys at Hellwig an they told me on some tundras there is a clearance issue. If you do have this probelm send them an email and they will send you spacer brackets for free.
I installed a Hellwig bar on my 06 today too. (12/12/06) It had the gray and black hammer tone powder coat finish, and the quality was very good. The bad: the locknuts for the j-bolts were extremely tight. I could see the bolts twisting as I tightened the locknuts. Can this be normal? The bolt sleeves for the end links seemed a bit too long, and that made it a struggle to start the nylon lined locknuts. By jiggling everything around, and squeezing hard, I was able line things up, and to compress the black rubber washers enough to get 1 thread started, and then it went smoothly. There's a reason for leaving all bolts loose until the end. Please don't ask how many tries it took to do this. The good: shock mount clearance seemed OK, and vertical alignment of the end links was good, but the driving! OMG, what a difference. I highly recommend this upgrade. I got mine directly from Hellwig: 800-367-5480, ask for Nancy, say you want the group buy price for Tundra Solutions, $150.00 plus shipping. She was very pleasant.
Spray-On bedliner :: Century commercial cap :: Replaced ball joints (recall) :: Replaced RR fender molding (damaged) :: Hellwig anti-sway bar :: Plugged the piezo :: Gentex compass/temp. rearview mirror :: 56 LED center brake light in cap :: Scangauge II :: Back up camera ::: Someday: Mr. Fusion :: Flux Capacitor ...
"Muhammad Ali [...] had a way with words, but it helped enormously that he could also punch guys in the face." - Maher
  #26 (permalink)
Old 12-12-2006, 11:48 PM
Images: 11
The locknuts on the j bolts were tight for me too, not sure if it twisted them, but it sure did take some work to put those on. Make sure you didn't tighten the j bolts to the point where it notched the frame, not sure what you could do if that did happen.
Same thing on the end links. I actually used the bottle jack to hold everything together/compressed so I could start the nylon lined nuts. (not enough to lift the truck though )There was about 1 to 3 threads showing after the end link nut when I was done.
  #27 (permalink)
Old 12-13-2006, 12:11 AM
CHINKinatundra's Avatar
Dealer : Red McCombs Toyota
2002 Toyota Tundra
Last Online: 08-10-2009 10:24 AM
Images: 2
CHINKinatundra is on a distinguished road.
Send a message via MSN to CHINKinatundra CHINKinatundra's Photo Albums
about how much did they charge you for shipping from Hellwig?
  #28 (permalink)
Old 12-26-2006, 12:12 PM
chilehead's Avatar
Last Online: 05-19-2008 09:53 PM
chilehead is on a distinguished road.
chilehead's Photo Albums
Awesome, thanks for the info! I was about to buy the black powdercoated ones for $195 shipped from summit until i read this Nancy was out today but the other lady, who was also very nice, did the deal for me and knew what i was talking about. Can't wait to get it installed
EDIT: just got confirmation on the shipping quote.... $37.58 !! Ok, so i only saved about $8, but i was going to get it anyway and i got the new finish too, so its all good
2006 SR5 V8 Tundra AC - Bluesteel Metallic
NASTA Nerf Bars, Hellwig Anti-sway bar, Line-X Bedliner, Billet Antenna & Jesus fish
  #29 (permalink)
Old 12-29-2006, 09:12 AM
enlightened's Avatar
Dealer : Dunning Toyota Ann Arbor
Last Online: 08-30-2009 02:46 PM
Images: 9
enlightened is on a distinguished road.
enlightened's Photo Albums
My Christmas present for the '01 Tundra. I had it installed at the local dealer, the technician I've known for 25 years there said it was a little difficult, it took some extra time to line up correctly, but he did a good job and everything fit together fine. The passenger shock mount is a little close to the sway bar curve, I will keep an eye on it for rubbbing. The pictures posted here are a VERY good illustration of how the Hellwig RSB fits on the Tundras! Very nice black-gray hammered finish.
The ride is Incredible Awesome! No harsh ride on rough roads, but going around turns, and putting a little gas into it, the truck is level as a dinner plate, and the speed and ability to complete the turn is greatly increased, until you reach the point of losing traction. I would say the ONLY thing holding the rear end to the ground is the postive traction of the rear tires (pays to have good ones) with this new setup, so I will be careful until I am used to the full potential to the newly suspended Tundra!!!
2001 Toyota Tundra 4x4 SR5 reg. cab, V-8 auto. imperial jade green with matching Astro-cap w/overhead racks
Hellwig rear ASB, Wheeler's poly ASB bushings, H&R 2" leveling progressive coils, Bilstein HD yellow/blue shocks, Husky liners, drop-in Toyota bed liner, TRD Dual Side exhaust, StubbsWelding rocksliders, red 48" Hi-Lift Jack, U-Haul hitch, receiver shackle, SkidRow front/trans/t-case skidplates, POR 15 and ChassisCoat Black frame restoration, 265/70R/16 BF Goodrich M/S tires on Tacoma TRD wheels
  #30 (permalink)
Old 01-03-2007, 02:14 PM
phanham's Avatar
Dealer : J. Pauley Toyota Scion
Last Online: 09-12-2009 07:58 PM
phanham is on a distinguished road.
phanham's Photo Albums
Ok, after reading all the rave reviews, I gave Nancy a call today and ordered one as well (~$185 shipped). I'll have to watch for the increased oversteer (the truck has fishtailed in the past for me a few times on a few sharp turns on wet pavement), but the understeer has been a bigger factor for me since buying the truck. I can be on a highway ramp and if I'm not paying close attention it's easy to exceed the truck's limitations (i.e. any turn > 40mph) and have to hit the brakes to avoid painting the outer barrier white!
2006 Tundra DC SR5 TRD 4x4. Pretty much stock besides the Extang Trifecta Tonneau, Hellwig sway bar, shorter antenna, & Kel-Tec in the console.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
polvo
RAS Installed H2O_MAN Suspension & Axle 13 09-16-2009 07:28 PM
Hellwig sway bar barng Handling Improvements 75 01-31-2006 03:56 PM
Installed Donahoes today dezert_rida Suspension & Axle 6 01-09-2005 07:02 PM
Installed a Hellwig anti-sway, and.... molex Suspension & Axle 13 12-14-2003 04:47 PM
ABS installed? maz Suspension & Axle 5 12-11-2003 07:28 PM
