Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Handling Improvements
  #31 (permalink)
Old 01-03-2007, 08:00 PM
tundraman89's Avatar
Dealer : Toyota and Scion Mall of Georgia
Last Online: 11-18-2009 09:48 PM
Images: 34
tundraman89 is on a distinguished road.
Send a message via MSN to tundraman89 Send a message via Yahoo to tundraman89 tundraman89's Photo Albums
Default Re: Installed my Hellwig today :)
Originally Posted by phanham View Post
Ok, after reading all the rave reviews, I gave Nancy a call today and ordered one as well (~$185 shipped). I'll have to watch for the increased oversteer (the truck has fishtailed in the past for me a few times on a few sharp turns on wet pavement), but the understeer has been a bigger factor for me since buying the truck. I can be on a highway ramp and if I'm not paying close attention it's easy to exceed the truck's limitations (i.e. any turn > 40mph) and have to hit the brakes to avoid painting the outer barrier white!
What does the hellwig do is it worth buying one im thinking about getting one.
2000 tundra 4.7L TRD Limited AC cab.
Mods
-Windows tinted
-Highland floor mats
-Maganaflow single in dual out
with 3 " tips
-16x10" rims 5 spoke Ultra
Stargazer chrome plated
-One 10" speaker with a 400
watt amp Under back seat
-Interior lights changed to blue
-Red blinkers
-Sirus radio
-Volant cold air intake
-Ready lift leveling kit
-Tool box
-Hitch recevier
-Chrome step sides
-Chrome bed rails
-Chrome grille guard with spot
lights
-White face gauges
  #32 (permalink)
Old 01-03-2007, 09:38 PM
Dealer : Camelback Toyota Scion
Last Online: 07-29-2007 04:05 PM
kev009 is on a distinguished road.
Send a message via ICQ to kev009 Send a message via AIM to kev009 Send a message via MSN to kev009 Send a message via Yahoo to kev009 Send a message via Skype™ to kev009 kev009's Photo Albums
Does the Hellwig actually increase road traction, or does it just give the illusion by reducing the body roll? I'd like to feel the curve in my truck, rather then just fishtail if it feels safe still with the bar if you see what I am saying. Also, does it do anything for offroad performance?
  #33 (permalink)
Old 01-03-2007, 09:45 PM
Mr. Creosote's Avatar
Legendary Contributor
Last Online: Today 01:47 AM
Images: 4
Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One.
Mr. Creosote's Photo Albums
I believe it should increase cornering ability, since without the bar, more of the cornering force concentrates on the outside tire in a turn when the truck leans over, which would then allow this tire to lose traction sooner.
  #34 (permalink)
Old 01-04-2007, 09:35 AM
cupidstoy's Avatar
Dealer : Reliable Toytota
2004 Toyota Tundra,
2003 Toyota Corolla Lola
Last Online: 12-31-2008 07:02 PM
cupidstoy is on a distinguished road.
cupidstoy's Photo Albums
there are several (many) threads on the effect of adding the sway bar to handling, performance, off road. do a search and you'll find lots of info.
basically, it helps on-road performance with a slight tendency to fishtail in the extreme and it hurts off-road performance at the extreme because you loose some rear end articulation.
2004 Tundra DC Limited Phantom Perl Gray w/ Oak Leather Interior (power sunroof, Kazuma TRD LSD, Advance 4 panel hard tonneau cover, Hellwig antisway bar, lighted running boards, dual battery setup with 1500 watt 120 volt power inverter, additional 'always-on' 12 volt outlets, aftermarket dual zone heated seat kits, Blizzack W965 LT235/85R16 winter tires on stock steel rims, JBA cat-forward titanium ceramic coated headers, tinted front driver's and passenger's windows, alignment to DJ's specs, Roadmaster VR-3 backup camera, Waeco 12 volt fridge/freezer, and, the best for last.... black rubber floor mats from Sams.) Recently added: baby seat!
Wish list: too long, wife would kill me!
2003 Corolla (bone stock, but well loved and cared for!)
"Expect the impossible."
- JC and the Brothers of Thunder
  #35 (permalink)
Old 01-04-2007, 09:41 AM
phanham's Avatar
Dealer : J. Pauley Toyota Scion
Last Online: 09-12-2009 07:58 PM
phanham is on a distinguished road.
phanham's Photo Albums
Since you have one, what is your take on the pros & cons? Will all sharp cornering cause the rear to swing out, or are we talking about some really aggressive, Steve McQueen style driving? I have noticed the understeer being really bad, but I really hope I'm not exchanging problems!
2006 Tundra DC SR5 TRD 4x4. Pretty much stock besides the Extang Trifecta Tonneau, Hellwig sway bar, shorter antenna, & Kel-Tec in the console.
  #36 (permalink)
Old 01-04-2007, 04:39 PM
cupidstoy's Avatar
2004 Toyota Tundra,
mostly it just corrects the understeer making it feel more neutral. on slipperly surfaces is when you might notice the rear swinging out a bit. i also have lsd differential, that makes it a little more likely for both wheels to spin and possibly lose their grip.
overall, i would recommend it if you don't do a lot of off roading. makes the truck handle much better in curves and corners.
  #37 (permalink)
Old 01-05-2007, 07:44 PM
hndymn's Avatar
No job too small.
Dealer : Mark Toyota
2006 Toyota Tundra SR5 AC Salsa Red,
2003 Toyota Matrix Blue XR,
- Other - 92 Toyota LB 1-ton
Last Online: 11-17-2009 01:26 PM
Images: 16
hndymn has a brilliant future. hndymn has a brilliant future. hndymn has a brilliant future. hndymn has a brilliant future. hndymn has a brilliant future.
hndymn's Photo Albums
I'm a pretty tame driver, but sometimes I find myself entering a turn a bit faster than I should. The truck stays flat, and doesn't tip when I make a sudden steering correction, and I like that. Tipping (or "swaying" to use the correct term, I guess) only complicates an already-challenging situation. Who needs it? I still slide sideways in my seat from the g-force, but I feel like I'm more in control than when the truck tips in a hard turn. I haven't pushed it hard enough in a turn to break the rear wheels loose (well, except in the snow) but there is a lightness back there that wasn't apparent before the sway bar installation. It feels as though it could come around more easily. I'm being careful, and working my way up to it. I'll have to find an empty parking lot and make some progressively faster circles.
Spray-On bedliner :: Century commercial cap :: Replaced ball joints (recall) :: Replaced RR fender molding (damaged) :: Hellwig anti-sway bar :: Plugged the piezo :: Gentex compass/temp. rearview mirror :: 56 LED center brake light in cap :: Scangauge II :: Back up camera ::: Someday: Mr. Fusion :: Flux Capacitor ...
"Muhammad Ali [...] had a way with words, but it helped enormously that he could also punch guys in the face." - Maher
  #38 (permalink)
Old 01-12-2007, 12:40 AM
phanham's Avatar
Just got my Hellwig today and installed tonight. UPS had beat it up pretty bad (box was destroyed and bar scuffed up good as all the hardware had been tumbling around), but I really wanted to get the new toy installed. Gotta say the 1-hour estimate is pretty accurate for install; however, noone mentioned the additional hour spent scratching your head, saying "how in the hell???" and cussing Hellwig. I'm pretty sure there will be a special place in hell for those design engineers... After finally getting the frame mounts on (finding something to jam under the block and keep in from spinning on the driver side was a huge PITA!!!), I was lucky to discover there was no way the links were gonna go on in stock form (I had even tried using a jack to compress bushings). I trimmed ~1/8" off each spacer with a Dremel and was able to squeeze them on finally, with 2 threads visible once tightened up. Oh yeah, and my kit was extra special as it only had 3 regular nuts with the others being those wonderful crush-type nuts -- I strongly suggest borrowing some air tools before attempting this mod...
Anyway, the install looks good -- everything looks lined up well with no clearance problems I can see. Didn't get to try it out much more than driving around the block to see if my craftsmanship would fall apart (may have been just me, but seemed like it was pulling more to the right now?), but hopefully tomorrow I can feel the improvement.
  #39 (permalink)
Old 01-12-2007, 11:23 PM
hndymn's Avatar
No job too small.
Images: 16
My box was beaten up too, had a hole in it, but everything was there. I spent over 2 hours installing it: everything that could go wrong did. At least it was warm; almost 40F. Speaking of warm I agree that there must be a special place for Hellwig engineers. A very. Special. Place. I thought about shortening the link bolt spacers, but decided the engineers knew best, and after 4 or 5 attempts I got the nut to catch on the bolt. The bar performs well when the bed is empty, but I haven't loaded the truck with much weight. I'm wondering what will happen when the springs compress, and the frame lowers. It seems like something's got to give. Once my cap comes in I'll be loading it up and then I'll know.
  #40 (permalink)
Old 01-15-2007, 08:35 PM
chilehead's Avatar
Last Online: 05-19-2008 09:53 PM
chilehead is on a distinguished road.
chilehead's Photo Albums
I too would reccommend this mod to anyone, but be prepared to buy addational parts or modify it in some way. I only had about 4 nuts that fit... i had to go buy mostly all new nuts and that was after I had already screwed on the ones that actually worked. (my bad I didn't check them all before starting... i was too excited!) I am close to the shock mount on the passenger side so I requested spacers from hellwig and they showed up promptly. I'll keep them handy and keep a close eye on that for any rubbing. FYI, I used the jack method as others used for the end links and did not modify the sleeves.
Handling, as everyone else has already stated, is a great improvement! This is how the truck should have come stock IMO.
Fit and finish
Handling improvement
2006 SR5 V8 Tundra AC - Bluesteel Metallic
NASTA Nerf Bars, Hellwig Anti-sway bar, Line-X Bedliner, Billet Antenna & Jesus fish
  #41 (permalink)
Old 01-15-2007, 09:16 PM
Dealer : Toyota of Glen Burnie
2002 Toyota Tundra,
- Other - Wife's Nissan Xterra
Last Online: 11-15-2009 08:46 AM
KFlash is on a distinguished road.
KFlash's Photo Albums
To follow up on the issue with the spacer being too short. I was about to head in the direction of cutting the spacer when I had a brainstorm (perhaps I read it in a post at one point). You need 4 large vice grips - I had 2 and bought 2 more (not real expensive). Put the upper bushings in place and pinch that part together by gripping the two washer and slowly squish down the bushings. Then slide on the spacer and the lower bushings/bar/bushings in place. Use the second pair of vice grips to squish these two bushings together. This actually is near the slight bulge you will want with the bushings once installed. By doing this, there is plently of thread to spin on the nylock nut. You also should take caution if pulling the whole end link together just by tighting the nut - you could end up stripping out the nut!
The frame bolt that is welded to a square plate can be held in place with a pair of channel locks. A did use an air rachet that made quick work of the crush/lock nuts.
Anyway, just another method. Mine arrived with the box pretty banged up as well, but all the parts were there.
2002 Tundra AC 4x4 Off Road Package - Revtek coil lift with Wheeler's 1.5" AAL. Superlift Truspeed Recalibration unit. Flomaster dual exhaust. Husky floor liners. Hellwig anti sway bar. Xmas Gift 2006 - 3" Perf. Accessories body lift and Gap guards - Installed 1/6/07! New tires in March 2007 - BFG AT 30570r16 on MT Classic IIs. Total Chaos steering bushing kit. Front swaybar bushing kit from Wheelers Offroad. Stubbie 21" antenna. Underdrive pulley installed with NAPA belt. Timing chain replacement and brake job are next!
  #42 (permalink)
Old 03-11-2007, 10:59 PM
1lowlife's Avatar
Dealer : Cowboy Toyota and Scion
2005 Toyota Tundra
Last Online: 10-05-2008 01:33 AM
1lowlife is on a distinguished road.
1lowlife's Photo Albums
Talking Re: Installed my Hellwig today :)
Just to let you guys know, I installed my Hellwig about two years ago.
Love it on corners and turning. From turning a corner from a stop, to cruising highway ramps, it drives much better.
A couple bushings gave out on one side.
Maybe I had it a bit too tight.
Maybe they just wore out.
I emailed Hellwig customer support from their website.
Hellwig Products
nancy@hellwigproducts.com
They returned my email the next day and asked for my address to send me a new set of bushings, washers, and lock-nuts.
They arrived three days later, AT NO CHARGE.
That is excellent customer service.
I went ahead and changed out both sides and didn't tighten them as much this time.
There are a few posts here on this site with installation help for the Tundra.
1Lowlife's 2005 Silver Sky Double Cab Tundra 4x2
Exterior Mods:
Debadged of labels & insignias, Retrax bed cover, Bedrug bed liner,
AVS hood deflector, Ventvisor window vents, Line of Fire tail light,
Magnaflow Single-out Cat Back System,
Undercarriage courtesy lighting, Silverstar headlights, Muth signal mirrors,
Hellwig rear anti-sway bar, Stant 10506 locking gas cap,
Disconnection of the DRLs.
Interior Mods:
Pioneer Premier DEH-P860MP, Terk XM Direct Satellite Radio Package,
Custom enclosure for 10" Fosgate P2 woofer,
Two old school Fosgate Punch 75 amps (each runs a pair of door speakers),
One Fosgate 60i amp on the P2 (runs mono on the sub),
Pioneer TS-D161R 6-1/2" speakers in each door,
Pioneer CD-RB20 for Aux input for MP3 player,
OBX Sport Pedals,
Extreme seat cover for driver's seat.
Please forgive my endless posts. I have an obsession to detail with a touch of ADD.
  #43 (permalink)
Old 03-12-2007, 09:53 AM
Dealer : Miller Toyota
2005 Toyota Tundra DC Phantom Gray
Last Online: 11-19-2009 10:28 PM
Images: 11
dibble9012 will become famous soon enough.
dibble9012's Photo Albums
Yup I still like mine
  #44 (permalink)
Old 01-04-2009, 03:41 PM
Dealer : Al Hendrickson Toyota
2005 Toyota Tundra
Last Online: 11-17-2009 03:30 PM
GORILLA is a splendid one to behold. GORILLA is a splendid one to behold.
GORILLA's Photo Albums
hi,
i would say alot,
but i posted enough for all of you to know how i feel about:
my front & rear HELLWIG.
but what you might not know is:
there is a LIFETIME warrenty on this product.
hardware, etc.
nancy or dave would be able to give you all that info.
take you time, and read all the thread's, of people who have the product, not the people who claim understeering/oversteering, etc.
gorilla
  #45 (permalink)
Old 10-26-2009, 08:35 AM
Shotgun Scott's Avatar
Dealer : Gault Toyota Scion
2006 Toyota Tundra Limited DC 4x4
Last Online: 11-16-2009 08:17 AM
Images: 9
Shotgun Scott is on a distinguished road.
Shotgun Scott's Photo Albums
Has anyone mounted the RSB on a truck that has been lifted? I had a RSB that I never installed on my 2000 Tundra (traded it in for a T4R before trading up to a 2006 Tundra). The part number is 7641, but I read a thread that Hellwig has an upgrade package for that one (P/N 7975) with upgraded hardware. I have used a 1" ToyTec rear block with Bilstein 5100's. I trust the members more than sales guys, because you've been there...done that. So, am I going to need longer endlinks to accomodate the lift? Thanks!
RAS Installed H2O_MAN Suspension & Axle 13 09-16-2009 07:28 PM
Hellwig sway bar barng Handling Improvements 75 01-31-2006 03:56 PM
Installed Donahoes today dezert_rida Suspension & Axle 6 01-09-2005 07:02 PM
Installed a Hellwig anti-sway, and.... molex Suspension & Axle 13 12-14-2003 04:47 PM
ABS installed? maz Suspension & Axle 5 12-11-2003 07:28 PM
