It took me a few hours, mainly because I was interrupted a few times. Anyways, haven't taken it for a test drive yet because my dad has to move his motorcycle for me to get out of the garage. Install was really easy.
What a productive day, finished my muth signal mirrors and installed the Hellwig
just got back from test driving the Tundra, all I can say is WOW. It's a night and day difference turning with the sway bar, it, ummm, doesn't sway anymore
I didn't notice a huge difference in normal driving, but so far I have not driven on any bumpy roads. I'm still amazed at how well the truck turns now, no wonder this is one of the most popular mods!
EDIT: is it normal to have a couple leftover nuts? I have 2 of the smaller nuts that would fit the "j" hooks, but the directions do not say to double up on the nuts in that location
EDIT 2: Nevermind, they are used as jam nuts on the J hooks
What was the kit quality like? Did you have to modify anything to make it fit right? Reason I ask is I had a hellwig kit before on my silverado and I had to do a lot of stuff to make it fit right. I even had to drill out several bolt holes because they were not completely circular. I complained to hellwig but they did nothing. To top things off I even had to buy new bolts, nuts and washers because several in the kit were unusable. I'm waiting for hotchkis to come out with a kit for our trucks.
I didn't have any problems at all, only thing I can think of is to make the end link bolts a little longer, its kinda hard to get the last nut on there while holding everything together. I did have 2 nuts missing, but that could just be my own fault, I will get some later this week, they are just the jam nuts so everything is put together. I just have to check the nuts every now and then.
I have heard several complaints about the finish, I think the finish is fine, it's a silver/black vein powdercoat.
I can get pics after work today (class was cancelled today )
EDIT: I searched on the forum for "hellwig" and found that many people were having problems with the finish, more so than I had previously thought. The finish on my sway bar is PERFECT, like I said before it's a pitted silver/black powdercoat.
I agree the Helwig Sway bar makes a huge difference. I took me about an hour or so to install. I did have to modify one of the bolt sleeves since it was about a 1/4 of an inch longer than the other and I could not get the bolt on. As for fit...how close does your sway bar sit from the pass. shock mount? Mine was less than 1/8 of an inch and it sometimes rubbed. I talk to the guys at Hellwig an they told me on some tundras there is a clearance issue. If you do have this probelm send them an email and they will send you spacer brackets for free.
__________________ O6 DBL Cab Limited 4x4
Weld Cheyenne 17x8.5 with 4.5 BS
285/70/17 Toyo Open Country AT
RevTek 2.5 Leveling Kit...1.25 Block in Rear
Hellwig Sway Bar
3M Clear Shield Bra
Volant Cold Air Intake
Magnaflow 12256
Bully Bars
Viper 791-XV
XM and my Garmin Nuvi
Yea, the bar is really close to the passenger side shock mount, I will keep an eye on everything for a while just to make sure the bolts are all tight and nothing is rubbing.
I just sent them an email regarding the missing nuts for the u-bolts, I had enough to install the bar, but not enough to double up on the u-bolts. Might just head out to autozone tonight and get the nuts anyways, I'm impatient, lol. I also need to buy some grease for the fittings.
You can probably see that it is a little off center, I'll have to go back and look at it tonight
Here are some pictures of it centered better. To get it centered I had to "tilt" the drivers side u-bolt/bracket. Also on the drivers side the end link is a little tilted too, not too much, do you think this could be a problem, how could I fix it if it is?
Centered
Distance between shock mount and sway bar on passengers side
This is how I had to center it, the u-bolt/bracket are tilted a little towards the back
Here's a picture of the drivers side end link bracket, it is not as bad now after I fixed it, but it does tilt a little still, is it ok to tilt a little?
I just took a look at mine and the drivers side u bolt is slightly tilted as well. The space that you have on the pass side shock mount is about the same space I have with the spacers installed. The finish on yours is also different than mine. I have a black coated bar. I wonder if there is a difference in size as well . When I talked to Hellwig they assured me I have the right part number. Oh well, it's all good now. As for the end link, I have a slight tilt also. I would keep an eye on the rubber bushings to make sure they don't start to mushroom from too much pressure. BTW, I like the mirror turn signals What did they run you if you don't mind me asking?
Hellwig Sway Bar
3M Clear Shield Bra
Magnaflow 12256
Bully Bars
Viper 791-XV
