Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Handling Improvements
Old 01-05-2007, 09:01 PM
Dealer : Royal Moore Toyota
2005 Toyota Highlander,
2007 Toyota Tacoma
Last Online: 07-14-2007 06:54 PM
GreenMtnMan is on a distinguished road.
GreenMtnMan's Photo Albums
Default Rear stabilizer bar
Can the XRunner's rear stabilizer bar be installed on a 05+ 4x4 Access Cab SR5Tacoma? Anyone done this? Does it make a difference, good or bad? I drive a rough gravel road but don't go 4-wheeling and will spend most of the time driving city roads with towing required rarely.
Nimble sports cars are fun to drive but I need a truck. That shouldn't mean handling can't be improved, right?
Old 01-05-2007, 10:20 PM
L R H's Avatar
Dealer : Lagrange Toyota
2007 Toyota Tacoma R/CAB SR5 PreRunner
Last Online: Today 12:52 AM
L R H is on a distinguished road.
L R H's Photo Albums
Default Re: Rear stabilizer bar
Would make a clean install, much cleaner than the Hellwig, and prob nicer fit than the Addco. I have only made a few quick looks underneath the XRunner as they are too low to see under, but i think everything would fit OK except for the cross bar bushing brackets are welded on, and I'm almost sure they are not offered. Years ago I checked out the Tundra factory rear set-up and the rear axle housing would have to be purchased or tabs/mounts fabricated. I wonder if one could weld on bracket mounts if axle had synthetic fluid?, otherwise the oil would coke and leave debris to possibally cause damage. Welders chime in. The rear bar might require longer end links or at least slightly re-indexing bar on housing due to increased ride height and axle under springs configuration. Would still look better than the Hellwig as Hellwig has some of the crudest brackets/fasteners of anything I have ever seen and I have had quite a few. Hellwigs hardeware is one step above coat hanger wire technology.
Old 01-08-2007, 04:33 AM
L R H's Avatar
bump; anyone used a bar other tham Hellwig?
Old 01-17-2007, 11:38 AM
2006 Toyota Tacoma
Last Online: 07-29-2008 12:51 PM
Silver-Bolt is on a distinguished road.
Silver-Bolt's Photo Albums
I have the Helwig on mine. It works OK but the mounting system is mickey-mouse at best. As soon as I have some time I will re-configure the mount. It is an improvement but I would prefer a little stiffer bar.
2006 Toyota Tacoma D/C TRD Sport
18x9 BBS wheels
285-60-18 Nitto Terra Grappler A/T
Undercover bed cover
05 Tacoma Towing upgrades Taco5 Towing 17 11-18-2006 08:37 AM
anti sway bar and rear drop kit Tmachine2 1Gen-Tundra 1 09-04-2006 07:30 PM
Tacoma rear sway bar...183 free shipping Tacomabill Tacoma 0 07-22-2006 09:19 PM
Tundra Offroad Mods and Tech DevinSixtySeven Off-Roading 15 05-24-2004 10:22 AM
Lowering shackles with rear sway bar? bwilder10h Suspension & Axle 3 12-30-2003 06:39 PM
