I went out to my trunk yesterday afternoon and laying in the driveway was a rubber washer, metal washer and the metal tube spacer. The long endlink bolt had snapped off near the bottom. I was a little bummed. It has been installed about 8 months now. Well I just got off the phone with Hellwig and they are sending me out 2 new ones (one for back up) no questions asked. Great customer service! I guess it would be good to check on them once in a while?
Tom 03 AC SR5 Silver Sky Metallic
Cab height ARE cap, Westin chrome step bars, tinted front windows 35%, Hella mini foglights under front bumper ,fog lights under the frame to light up the door area, fog lights under rear bumper (factory dash switches for each set of lights),Bedrug, Hellwig swaybar, one-touch window control for both windows,Kenwood DDX-6019 double din dvd unit,2 amps, 2 sets of speakers, 6 disc cd changer,Q-logic sub box, subs, rearview camera, & skid plate. Freebies: Power outlet mod,fog light mod, map light mod &, debadged. Hope to add: Chrome bull bar, headest monitors for back seat passengers (daughters) Waiting for time to install: kicking alarm w/remote start. My Website
They sent 2 full sets out 2nd day UPS. I have already put them on. All companies should take care of there customers so well.
I had them send me a set some time ago. I have had the sway bar on for about two years. I lowered the rear about an inch and a half and called Hellwig to see if I cound buy some shorter links, they sent me a pair that is an inch shorter free!!!!!!!
They have excellent customer service, highly recommended.
I also had an issue with the saddles bending, the perch that goes on the axel bent and they sent me new ones that were boxed in the front and rear, again free!!!!!!!!!!
I have had the Hellwig on for about 6 months. Two weeks ago I noticed that one of the bolts had snapped on the threaded end and all hardware was gone. Two new bolts with all bushings, washers, etc were sent out to me. I will install this weekend. My only concern is the frequency that people report the end links are breaking. It seems like a much beefier set up should be evaluated for this kit. You would think that Hellwig would get tired of sending out replacement parts!
__________________ 2002 Tundra AC 4x4 Off Road Package - Revtek coil lift with Wheeler's 1.5" AAL. Superlift Truspeed Recalibration unit. Flomaster dual exhaust. Husky floor liners. Hellwig anti sway bar. Xmas Gift 2006 - 3" Perf. Accessories body lift and Gap guards - Installed 1/6/07! New tires in March 2007 - BFG AT 30570r16 on MT Classic IIs. Total Chaos steering bushing kit. Front swaybar bushing kit from Wheelers Offroad. Stubbie 21" antenna. Underdrive pulley installed with NAPA belt. Timing chain replacement and brake job are next!
I'm going to get some quick disconnects from frontrangeoffroadfab.com They are stainless steel and super beefy. I have so much into the truck at this point, what's another $125.
2001 Tundra TRD Access Cab 4x4, SAW/Camburg coilovers, TC diff drop kit, Wheeler's Offroad AAL and Bilstein 5100's, LT265/75R16 BFG AT KO on Wheeler's black alloys, True Flow intake tube and filter with a modded air box, JBA titanium coated headers, Magnaflow 11226 muffler with stainless steel pipes and resonator removed, Skidrow front skidplate with custom made aluminum side shields, extended rear diff breather hose, Hawk LTS brake pads, Wheelers stainless brake hose kit, Helweig swaybar, Downey Offroad front swaybar link kit and cv joint boots,TRD "posi" 3rd member, debadged, backseat-power outlet-map lamp-taillight mod, Optima red top, TRD mirror covers painted flat black, Viair 300P air compressor, blacked out mouldings, bumpers and grille emblem
what grade hardware are the bolts that they supply are?
__________________ Bristol Va Home Blacksburg Va Hometown
Tundra 00 White AC 4x4 mods: IS Grill, Clear corners, Euro tails, TRD 3rd brake light, Indiglo guages, Prodogy P3 controller, Rear 55w Reverse lights, Polyurethane Rack and Pinion bushings... more to come
Supra 87 Black Turbo Targa Mods: Euro side markers, Eibach springs, Tokico Illumina struts (blown rod)
Supra 87 White Targa non turbo daily driver running!! finshing up small touches now
They are only grade 5 bolts (3 marks on head of bolt). I am going to give the local bolt supply house a call to see if they have grade 8's in that length. Again, nice they send replacements for free, but think the tougher bolts would be a nice change. Unfortunately, you have to take the frame bracket off to get the new bolt in.
There is only one place I found on the internet that carries 9" Grade 8 -7/16 bolts at $9.50 a piece. The replacements from Hellwig arrived yesterday, so I just reinstalled them. If they break again, I'll order the others. Even only having it off for a short time, I was again impressed at the increase in handling! Loving the fast turns-if only gas wasn't so #$&!ing expensive!
I suggest a replacement end link set that is made by Addco and sold by Auto Zone. A set is available that is the same length as the original. The quality is much higher than the original Hellwig links. A few years ago, they were about $11 a set.
Thank you, the order is in, keeping my finger crossed maybe the last time I have to install it. Going to use a framing square to make sure the bar is at a 90 degree angle to the link.
Just finished re installing my rear stab bar, with the grade 8 link bolts. Made sure the links were 90 degree angle to the bar and used a small level to try to get them as plumb as possible. One thing I noticed different from the first installation: the U-bolts over the rear axle are pointing a bit forward instead of straight down. This was needed to get the link perpendicular.
Keeping my fingers crossed, maybe I should not take those higway curving offrams at 60 mph????
