Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Cars & Vans Forums > Highlander Hybrid
Old 09-08-2006, 12:56 AM
Dealer : Liberty Toyota Scion of Burlington
2006 Toyota Highlander HV
Last Online: 10-01-2006 10:46 AM
dgreep is on a distinguished road.
dgreep's Photo Albums
Unhappy HiHy eclipse AVN5435 speed pulse wire
I just had the Eclipse AVN5435 installed in my 06 HIHY I am having a problem with the speed pulse wire not allowing voice guidance or route correction due to issues with not having the correct speed wire connected. I recieve the correct reading on the diagnostic screen but it will flash a speed pulse message some times. Has anyone successfully installed this or any other aftermarket nav system in the highlander hybrid? If so where did you connect to the speed sensor wire? My installer says there are four wires in the Hybrid that send this signal to the ECM but none of them seem to work correctly. Does anyone have a wiring schematic to trace out a correct wire. Any suggestions?
Old 09-08-2006, 02:37 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
Default Re: HiHy eclipse AVN5435 speed pulse wire
There is only 1 input to the speedo from the skid control ecu
There is only 1 out which splits into 3.
I would tap into connector C12 PIN 18 (gray wire) on the back side of the combination meter.
This is the INPUT from the skid control ecu and the speed sensors. This signal is digital (I THINK).
As it passes thru the speedo (combination meter) it is converted to ANALOG and then goes out to the factory NAV/Multi display and the HV ECU.
It maybe analog in and digital out. I am not sure.
You could also try that wire Connector C11 pin #6 (white wire) on the back of the combination meter as well.
TIS is on a new program so I cant post pictures as of yet.
E-mail me and I will send them to you. The picture of the connectors and loctions.
mustang67408@cox.net
Hope this helps
25 yrs with TOYOTA
Old 09-08-2006, 02:45 PM
Thanks for the info. I am on vacation right now but I will definitely be taering into it and let you know how it comes out.
Old 09-22-2006, 09:31 PM
Chrom0zone's Avatar
Dealer : Toyota San Diego
2006 Toyota Sequoia,
1995 Toyota 4Runner,
- Other - 1995 Saab 900SEturbo
Last Online: 07-18-2008 08:37 PM
Chrom0zone is on a distinguished road.
Chrom0zone's Photo Albums
I had the same issue, not with my Sequoia but with my Saab.
I could not find a speed wire the AVN would read.
I was able to get the update disc for this unit, It has a firmware update so you no longer need a speed wire connected. It just uses GPS like the newest AVN's, inaddition it allows you to change the splash screen and has a Map update as well.
Old 04-10-2007, 02:54 PM
Dealer : Performance Motors Toyota
2005 Toyota 4Runner
Last Online: 02-08-2008 02:11 PM
thering is on a distinguished road.
thering's Photo Albums
how do u change the flag screen! and how do u update the firmware!
DIY: How To: Fog Light Modification SMTRDSPORT Tacoma 67 04-09-2009 09:59 PM
Help! 2001 Seq Nav Speed Sensor Wire JMan 1Gen-Sequoia 6 10-23-2007 10:36 AM
2005 Taco Speed Sensor Wire TheMike Electrical & Computer Systems 0 03-10-2006 02:57 PM
Questions and observations for Eclipse AVN(5435) Owners... keninsb Audio & Stereo 0 08-24-2005 09:19 PM
