4.7 Ex. Manifold Removal
+ Reply to Thread
Results 1 to 5 of 5
Thread: 4.7 Ex. Manifold Removal
  1. #1
    Join Date
    Aug 2008
    Location
    New Braunfels
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Default 4.7 Ex. Manifold Removal
    Can anyone tell me how they removed their exhaust manifold? I am having difficulty in gaining access to the middle 2 nuts on the bottom of the manifold on each side. The are over the middle support and under the manifold and I have not been able to get a wrench or socket on them?
    I am an amateur mechanic and a newbie on this list. I see that several of you have managed to accomplish this and would appreciate any suggestions you might have.
    Thanks,
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Lifetime Member HotRod8's Avatar
    Join Date
    Oct 2002
    Location
    Airdrie, Alberta
    Age
    48
    Posts
    241
    Liked
    0 times
    Rep Power
    13
    Default Re: 4.7 Ex. Manifold Removal
    I used a 14 mm 'flex' socket and about 2 1/2 or 3 feet of extensions.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	Flex Socket.jpg
  4. #3
    Supporter ThomasE's Avatar
    Join Date
    Feb 2002
    Location
    San Jose, CA
    Posts
    371
    Liked
    1 times
    Rep Power
    14
    I took a deepwell socket and cut it in about half, used that plus a universal joint and a bunch of extensions going through the wheelwell. Other's have also jacked up the engine and removed the motor mount to access the nuts.
    TRUCK: 2001 2WD V8 AC MODS: JBA headers! Magnaflow muffler, TRD 4x4 coils & shocks, Wheeler's AAL's, Truxedo bed cover, Bridgestone Dueler AT LT265/75/16, Surepull hitch, Drawtite convertor box, MAPP nerf bars, Toyota bed mat
  5. #4
    Supporter nedjames's Avatar
    Join Date
    Nov 2001
    Location
    Shreveport, LA
    Posts
    182
    Liked
    10 times
    Rep Power
    2022
    I jacked up the engine a bit and removed the motor mount. Put a piece of wood on the oil pan and avoid the drain plug. Do one side at a time.
  6. #5
    Supporter Eddie's Avatar
    Join Date
    Jul 2000
    Location
    New Jersey
    Posts
    1,743
    Liked
    0 times
    Images
    32
    Rep Power
    25
    Search through the header threads,most people have posted tips and tricks on removal of their OEM manifolds.
    2000 Imperial Jade Mica Tundra SR5 V8 4WD - sold to my dad
    2002 Thundercloud Sport Edition 4Runner - my "new" Toyota truck
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Tags for this Thread
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
