Manifold estimates
+ Reply to Thread
Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Like Tree8Likes
Thread: Manifold estimates
  1. #1
    Junior Member Zachg4's Avatar
    Join Date
    Oct 2009
    Location
    Virginia
    Age
    23
    Posts
    149
    Liked
    19 times
    Images
    15
    Rep Power
    423
    Default Manifold estimates
    Alright guys taxs returns are coming up and my truck has been "ticking" since the day I bough it. I cant take it anymore, I want to get it fixed. Its just my passenger side thats leaking. I took the heat shield off and ran seafoam to see if I could find a crack, but it looked to me like the gasket could be bad. Or maybe its warped and I dont have a good enough eye. Basically what I want to know is a ballpark price of what it should cost to get this fixed. I thought about headers but since he would be replacing both sides I figured the labor would be more.
    2001 Tundra Access Cab 4x4 V8. 5inch TC lift and 5100s up front set at 2inches. 35 12.50 Nitto Mud Grapplers. 20x10 Chrome Fuel Hostages. Y-Pipe No Mufflers at 45s. Black Emblems. Black Low Profile UWS Toolbox. Pioneer Headunit. Pioneer Door Speakers w/ 300w Rockford Amp. 1 12 inch Rockford P3 and 300w Rockford Amp.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,393
    Liked
    3189 times
    Images
    47
    Rep Power
    162921
    Talking Re: Manifold estimates
    1. Stainless JBA Headers #2010S (For California Emissions Vehicles): $460, or, do what I did and get T304 Stainless Shorty Headers from this eBay seller (49 State Legal): $190
    2. Percy's Seal-4-Good Gasket Set #66080: $33
    3. Remflex Collector Flange Gasket Set #8015: $16
    4. Toyota Locking Header Nuts #90080-17187 (16 for the headers + 6 for the collector bolts @ $1.35 ea + shipping): ~$46
    5. I got these 40mm long black anodized, hex-socket head, M10 x 1.25 thread bolts (and washers) for the collector flanges from my local McFadden-Dale industrial hardware supply. They are thread-matched to the exhaust studs so I could use the same locking header nuts. They are also available from McMaster-Carr for $4.53 for a pack of 10 (you'll need 6):
    Click image for larger version.
Name:	Collector Flange Bolt-Nut 1.jpg
    6. Labor: $Depends on who you have do it. I'd budget $400-$500 for labor.
    I'd also strongly recommend replacing the fuel-air sensors with new Denso units while you've got it all apart. Amazon is usually the cheapest.
    Pics of my final install attached below. I did slightly bend the shift cable bracket down so it allowed more gap between the rubber-coated cable and the heat from the header tubes.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	91933   Click image for larger version.
ID:	91934   Click image for larger version.
ID:	91935   Click image for larger version.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * O2 Sensor Replacement DIY * * *
    "I came into this world covered in someone else's blood and screaming...I'm not afraid to leave it in the same way."
  4. #3
    Join Date
    Nov 2007
    Location
    Los Gatos, CA
    Posts
    98
    Liked
    6 times
    Rep Power
    1250
    Default Re: Manifold estimates
    To find the leak: Use a short piece of garden hose as a stethescope. To get a price, check your local mechanics and find someone who has done the job. Perhaps you could post your findings...
  5. #4
    Join Date
    Nov 2005
    Location
    Katy, TX
    Posts
    650
    Liked
    113 times
    Images
    13
    Rep Power
    4500
    hmm, I'm going to have to further research these stage 8 bolts. Wonder if they make something for the 2003 highlander 4 cylinder, bc toyota's 3 bolts are prone to loosening and blowing the engine? It is the bolts at the headgasket that strip the threading on the head. Thanks Remmy
  6. #5
    Join Date
    Oct 2009
    Location
    Virginia
    Age
    23
    Posts
    149
    Liked
    19 times
    Images
    15
    Rep Power
    423
    Thread Starter
    Thanks for the replys! and thanks for the links Remmy. That helps a lot. Now I just need to get labor costs. Hopefully I can do that this weekend.
  7. #6
    Join Date
    May 2006
    Location
    Hampton
    Posts
    35
    Liked
    5 times
    Rep Power
    11
    I've looked at the stage 8 bolts for my Porsche CV joints - they're sweet. My Tundra has a similar leak. Please post some pics and your experiences doing the swap.
  8. #7
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,393
    Liked
    3189 times
    Images
    47
    Rep Power
    162921
    Quote Originally Posted by Zachg4 View Post
    How about an update. What did you decide to do?
  9. #8
    Join Date
    Mar 2012
    Location
    Maine
    Posts
    23
    Liked
    8 times
    Rep Power
    4
    I have done both of mine already and I can tell you from my personal experience that the manifolds crack so unfortunately I don't see it just being the gaskets. According to our labor guide at work it calls for 4-5 hours per side and that is if all the bolts come out easily, but with a little heat and some loving they should I didn't break a single one.
  10. #9
    SAS'ed #5 dyogim's Avatar
    Join Date
    Sep 2000
    Location
    Co.Co. County, CA.
    Age
    37
    Posts
    6,586
    Liked
    405 times
    Images
    119
    Rep Power
    27120
    Quote Originally Posted by Remmy700P View Post
    I'm sure you've posted your on the headers, how are they holding up? I was thinking about getting these for my motor swap currently in progress...
  11. #10
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,393
    Liked
    3189 times
    Images
    47
    Rep Power
    162921
    Quote Originally Posted by dyogim View Post
    Doing fine! They have a nice thick flange that is ruler straight, aligned ports, excellent and consistent welds, and T304 steel. They bolted right up to the stock downpipe. Percy's header gaskets and Remflex collector gaskets are the trick.
    I also don't have the issue that some of the JBA shorty header owners are facing about the position of the fuel-air sensor bung. Mine are properly indexed to allow them to be backed out for replacement.
  12. #11
    T23
    T23 is offline
    Supporter T23's Avatar
    Join Date
    May 2002
    Location
    Alaska!
    Posts
    256
    Liked
    4 times
    Rep Power
    272
    1. Stainless JBA Headers #2010S (For California Emissions Vehicles): $462, or, do what I did and get T304 Stainless Shorty Headers from this eBay seller (49 State Legal): $190
    5. I got these 40mm long black anodized, hex-socket head, 1.25 thread bolts (and washers) for the collector flanges from my local McFadden-Dale industrial hardware supply. They are thread-matched to the exhaust studs so I could use the same locking header nuts (about $10 for 6 of each):
    I'd also strongly recommend replacing the fuel-air sensors with new units while you've got it all apart.
    Would you need to buy all those extra parts if you had bought the JBA option? From what I can read they claim it is the whole kit. Gaskets, bolts, etc. ?? Thanks!
    2001 Tundra: Thunder Grey, Limited, TRD 4x4 Access Cab.
    Team West Race Runner SAWs - 1.5" Lift w/ Kartek 930 boots, Wheelers Differential Drop Kit
    SkidRow Front Skid Plate, Wheelers Add-A-Leaf Kit w/ Bilstein 5100 Rear Shocks
    BFGoodrich® All Terrain T/A® KO LT265/75R16 on AR23s
  13. #12
    Join Date
    Apr 2013
    Location
    United States
    Posts
    5
    Liked
    0 times
    Rep Power
    0
    my past experience in building small block chevys the gasket kits that come with headers arent the best so i usually bought aftermarket ones that are thicker which tends to seal and lot better
  14. #13
    Supporter SuckersWalk's Avatar
    Join Date
    Aug 2009
    Location
    Earth
    Posts
    4,604
    Liked
    2170 times
    Images
    26
    Rep Power
    67158
    Quote Originally Posted by bfunke View Post
    had those on my mustang for about a year. they never moved. however, they were a bit of a pita (not difficult, just took more patience that i usually had) when i was removing and installing the headers with head changes and such so i ended up dumping them and went with some ss arp bolts and nord-lock washers just for ease of removal and install.
    2005 Tundra DC Limited 4wd - Phantom Gray Pearl
    Search for your answer. http://www.tundrasolutions.com/forums/1gen-tundra/106548-how-to-search-this-forum/
  15. #14
    Join Date
    Apr 2013
    Location
    United States
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Worth it... Just put headers in mine at a local DIY shop. Took me 12 hrs but i got them in! They are a PITA but the ticking bothered me to no end.... FYI the seal flange on my pass. manifold 1st cylinder was completely gone, hence the MASSIVE ticking...
    Also I would get Percy's no leak manifold gaskets from summit, and some extra studs/bolts for re-install.
  16. #15
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,393
    Liked
    3189 times
    Images
    47
    Rep Power
    162921
    Quote Originally Posted by kijones View Post
    If the existing studs are not badly corroded and you can chase the threads clean, then all you need is new locking header nuts from toyota. Going through the process of removing the studs just to replace them with bolts is pointless -- and will at least double the time it takes to complete this job.
    +2 on the Percy's though!!
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
