Weld or clamp exhaust?
+ Reply to Thread
Results 1 to 14 of 14
Thread: Weld or clamp exhaust?
  1. #1
    Join Date
    Feb 2004
    Location
    Pittsburgh, PA
    Posts
    186
    Liked
    6 times
    Rep Power
    298
    Default Weld or clamp exhaust?
    I ordered a Magnaflow muffler. I am assuming that having it welded in place is best and am planning on taking it to a muffler shop. Am I wrong? Can it crack? What about clamping it instead? Are there drawbacks to either method?
    2004 Tundra Access Cab cold piston slapping V8 TRD Natural flat "clay bar?! haha I barely even wash it" white. Faded but still there Line-X bedliner, NASTA polished by a guardrail stainless steel nerf bars bolted to a rusty then coated in grease frame, 22" stainless steel Magnaflow droning muffler with stock tailpipe, Daystar 1" front leveling kit that now sits higher than the many times overloaded rear, bald and too expensive to replace Michelin LTX 265/75/16 tires, Hellwig rear sway bar kit cause everyone else was doing it, Custom paint job by "F**k I forgot to lift the mower deck going over the gravel driveway again", PA whitetail buck modified driver's side. Paid for and runs like a top.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member Invid's Avatar
    Join Date
    Jun 2002
    Location
    Corona, CA
    Age
    42
    Posts
    373
    Liked
    8 times
    Rep Power
    798
    The weld can crack if the shop you have it done at does a poor job of welding it to the pipes. Clamps can come loose and/or separate from the pipe due to vibration and expansion and contraction over endless heat cycles which can cause leaks. I've had all my aftermarket mufflers welded in place and I have never had a problem with doing so over my many years.
  4. #3
    Join Date
    Jul 2004
    Location
    Spring Valley
    Age
    68
    Posts
    38
    Liked
    0 times
    Rep Power
    11
    Yep, welding is the best approach. Makes for a better seal. I'd ask the shop you go to for some kind of guarantee on their work.
    Lance
  5. #4
    Join Date
    Jan 2004
    Location
    Oceanside,CA
    Posts
    704
    Liked
    0 times
    Rep Power
    12
    Quote Originally Posted by EricZ
    I would reccomend havin it welded in place. A 360 degree weld will not leak.
    This method will ensure proper rotaion of the muffler and tail pipe.
    I wouldnt use a clamp, because they can leak, and can loosen.
  6. #5
    Supercharged Member v8Toilet's Avatar
    Join Date
    Apr 2002
    Location
    Worcester, MA
    Posts
    2,145
    Liked
    2 times
    Rep Power
    16
    If the muffler is stainless and the tubing is stock (stainless) than you should have the welder weld it with stainless wire if it's a MIG welder or stainless filler rod if they use a TIG welder. Either way don’t let them weld it with regular mild steel.
    stock exhaust
    TRD LSD
    Extang lift off tonneau
    Hankook DynaPro AS RH03
    stock air filter & box
    220 HP @ 4800 RPM
    302 TQ @ 3400 RPM
    Run With Spintech Sportsman XL muffler, stock air filter, and JBA headers
    208 HP @ 4800 RPM
    285 TQ @ 3400 RPM
    Run With Spintech Sportsman XL muffler, TRD air filter, and stock manifolds
    204 HP @ 4800 RPM
    271 TQ @ 3400 RPM
    Bone stock
    Dyno run results click here
  7. #6
    Join Date
    Feb 2004
    Location
    Pittsburgh, PA
    Posts
    186
    Liked
    6 times
    Rep Power
    298
    Thread Starter
    Default Now I'm confused
    Thanks for the tips. I was all set to get it welded before I talked to a friend of mine. He runs a well respected garage in my opinion. He insists that I'm better off clamping because of the ease of removal and the ability to replace individual parts if something becomes damaged, breaks etc. He also says that there is a possibility that it can crack in the future. Finally, he has a brand new Saleen Mustang. Saleen apparently use Magnaflows on their cars and his was clamped direct from them. He did bring up some good points although maybe he just doesn't want to be bothered with it.
  8. #7
    Join Date
    Jun 2002
    Location
    Corona, CA
    Age
    42
    Posts
    373
    Liked
    8 times
    Rep Power
    798
    Well exhaust piping is cheap and easy to replace if it gets damaged from say impact or under truck debris. I'm sure regardless of which way he chooses to go it'll work well for him
  9. #8
    Veteran Member GaryFisher's Avatar
    Join Date
    Feb 2002
    Location
    Pluto
    Posts
    660
    Liked
    0 times
    Rep Power
    14
    What exactly are the problems that arise say from a small leak around a clamp?
    SR5 V6 4X4 5Spd Modifications Include... ACT performance clutch, Bassani Split Side Duals, Fabtech Shocks and front Coilovers, IS Kit, Grillecraft Grille, BBS Wheels, 285/75/16 Firestone Destination M/T's for wheelin, 20" Enkei RT-6's w 295/50/20's for street , Air Box Mod, Pro Comp Boost GaugeTRD Supercharger, URD Fuel kit, URD 2.2 Pulley ALL GONE - Now Audi S4 Avant
  10. #9
    Leader of Group Evil DevinSixtySeven's Avatar
    Join Date
    Oct 2001
    Location
    Snowy Highlands
    Posts
    11,134
    Liked
    745 times
    Images
    22
    Rep Power
    12366
    a small leak sounds bad and results in loss of power. it also means moisture dripping out the leak. if theres a gasket at the leak, it will degrade the gasket.
    have a good muffler shop weld the thing in place. there is already a donut joint in front of the stock muffler, if youre worried you can always have them weld in a flex section or something. i'll be doing the same when i have my y-pipe modified to a 3-bolt flange, in order to connect to a 3-bolt flanged flex pipe, to the stock exhaust pipe, because i'm sick of leaking clamps and dont want an impact at the tailpipe (like from a rock, ledge or stump) to torque back up the exhaust pipe.
    -sean
    GFX by FreedomEagle50
    1-Gen Tundra Offroad Technical FAQ Index
    Manual Hubs
    OB's cup size: 36DD
    "some people will call you stupid but its worth a try because i know i also want one more inch."--SouthernTundraSC
  11. #10
    Join Date
    Feb 2004
    Location
    Pittsburgh, PA
    Posts
    186
    Liked
    6 times
    Rep Power
    298
    Thread Starter
    Default Decision made, some other ?'s
    My Magnaflow will be delivered on Monday. I am going to install it myself and clamp it first to see how I like the sound. If I like it, then maybe I will decide to have it welded. I bought a 2.5" in/out model and the stock pipe I believe is 2 3/8. How much pipe overlap on each side of the muffler should I have? I was thinking at least 1 inch on each side. I am assuming that if I decide to weld, I can just take the whole thing off and have the muffler welded just as it is clamped. Should also save some $. Can I cut the pipe with a good quality hacksaw blade or is it a Sawsall caliber job? (I'm pretty stubborn and not overly lazy ) What about the donut seal? My truck is a 2004 with 7K miles. Will it need replaced or is it too new?
  12. #11
    Junior Member TUNDRAVILLE's Avatar
    Join Date
    Nov 2004
    Location
    Elsmere
    Age
    48
    Posts
    80
    Liked
    0 times
    Rep Power
    11
    Default ??
    my brother had a flowmaster put on his ford, they welded it and it caused it to rust out at the welds, maybe they didnt use the right wire, dunno, maybe a coat of some kinda heat resistant rust preventative would have worked to prevent it, just a thought.
  13. #12
    No Really, I swear, I'm Done.. Imdone's Avatar
    Join Date
    Mar 2001
    Location
    Peoria, AZ
    Posts
    3,083
    Liked
    3 times
    Images
    40
    Rep Power
    281
    A cutting wheel/grinder or plasma torch are the best tools for that Job, a sawsall will get you through it but it will take a minute.
    TRD S/C, RBP, ICON, CAMBURG, ALCAN, AMP RESEARCH, TOYO, ECLIPSE, SAVV, FOSGATE, KICKER, JL AUDIO, V-LEDS, PIAA, HELLA, MBRP, TIMBREN, HYPERTECH
  14. #13
    Join Date
    Feb 2004
    Location
    Pittsburgh, PA
    Posts
    186
    Liked
    6 times
    Rep Power
    298
    Thread Starter
    Thanks for the replies. What about the pipe overlap?
  15. #14
    Supporter ThomasE's Avatar
    Join Date
    Feb 2002
    Location
    San Jose, CA
    Posts
    371
    Liked
    1 times
    Rep Power
    14
    I replaced my muffler with a Magnaflow a couple of weeks ago, I clamped it all together. If you mean how far in to put the exhaust pipe/tail pipe into the muffler, I just put it in as far as it would go, maybe 3". You will need some 2.5" outside diameter exhaust piping, that will fit over the existing 2.4" stock pipe, and will fit right inside the muffler. I used an angle grinder with a cutoff wheel to cut out the old muffler, it went really fast. Also I'd suggest removing the entire exhaust system before cutting off the muffler, it's a lot easier to cut it on a table than cutting upside down under the truck.
    TRUCK: 2001 2WD V8 AC MODS: JBA headers! Magnaflow muffler, TRD 4x4 coils & shocks, Wheeler's AAL's, Truxedo bed cover, Bridgestone Dueler AT LT265/75/16, Surepull hitch, Drawtite convertor box, MAPP nerf bars, Toyota bed mat
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
