Exhaust manifold stud removal question
+ Reply to Thread
Results 1 to 11 of 11
Thread: Exhaust manifold stud removal question
  1. #1
    Junior Member ripshion's Avatar
    Join Date
    Feb 2002
    Location
    Bend, OR
    Posts
    92
    Liked
    0 times
    Rep Power
    14
    Question Exhaust manifold stud removal question
    Quick question for the people that installed aftermarket headers on their Tundra's. How do you remove the exhaust manifold studs? What did you remove it with? The stud looks like it has a torksen head on it, socket? what size? I just want to make sure I have the right tool when I do make the install.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter ricqik's Avatar
    Join Date
    Feb 2000
    Location
    Twin Cities, MN
    Posts
    1,475
    Liked
    42 times
    Images
    4
    Rep Power
    4574
    You can use a small socket that fits. I don't remember the # of the socket. My sockets are Metrinch so it has that shape. Mine are design to work for both metric and standard with same socket.
    '00 tundra
    '06 sequoia
    '98 forester
  4. #3
    Join Date
    Feb 2002
    Location
    Bend, OR
    Posts
    92
    Liked
    0 times
    Rep Power
    14
    Thread Starter
    Thumbs up Thanks!
    Thanks ricqik
  5. #4
    Join Date
    Feb 2002
    Location
    New Jersey
    Posts
    8
    Liked
    0 times
    Rep Power
    0
    Default torx
    I belive its a female torx #10
  6. #5
    Join Date
    Feb 2002
    Location
    Bend, OR
    Posts
    92
    Liked
    0 times
    Rep Power
    14
    Thread Starter
    Default odrspang thx!
    OK, thanks alot!
  7. #6
    Veteran Member Dude Boy's Avatar
    Join Date
    Feb 2000
    Location
    Northern Oregon
    Age
    69
    Posts
    1,462
    Liked
    6 times
    Rep Power
    1078
    Can you get the headers on using the stock studs? Seems like it would be better to go that route rather than screwing a bolt into aluminum threads. You would be a lot less likely to strip any threads if you could keep the studs. I think someone has said they were able to do this.
    ADDING POWER HAS NEVER BEEN SO FAST!
  8. #7
    Join Date
    Jun 2002
    Location
    La Mesa, CA
    Age
    48
    Posts
    409
    Liked
    0 times
    Rep Power
    28
    Default JBA headers on stock studs
    I installed my JBAs on the stock studs without any problems to date (installed approx. 6 mo. ago). I periodically check the torque (when the engine is cold only) and haven't had any loosen up. The kit came with new bolts, so I saved them just in case. I also have a problem with removing studs from aluminum (for fear of cross-threading/stripping) so if it's not broken...
  9. #8
    Join Date
    Feb 2002
    Location
    Bend, OR
    Posts
    92
    Liked
    0 times
    Rep Power
    14
    Thread Starter
    Default JBA's
    Tundrafire,
    I am thinking about installing some JBA's and wanted to ask you if you notice any true horsepower gain ie. low-end, high-end, all around horsepower performance? Just need some input before I pull the trigger! Also, what kind of exhaust system do you have on your Tundra? The JBA's that I want to install will be working with my Bassani system.
  10. #9
    Join Date
    Feb 2000
    Location
    Northern Oregon
    Age
    69
    Posts
    1,462
    Liked
    6 times
    Rep Power
    1078
    Has anybody used the JBA headers, JBA gaskets, stock studs, and stock locking nuts? Will that work? That's what I'm thinking about trying if the studs are the right length, and the nuts seem to match up to the header flanges OK. Tried to get some gaskets from the Toyota dealer and they had only one in stock. They said that the Tundra doesn't have a problem with cracked manifolds. Also told me that the supercharger should be out in a month and that they would sell me a set of TRD headers for $996.00 (carry out price) Real helpful guys, huh?
  11. #10
    Join Date
    Feb 2000
    Location
    Northern Oregon
    Age
    69
    Posts
    1,462
    Liked
    6 times
    Rep Power
    1078
    Does anyone have JBA's and hasn't put them on yet? Put a straight edge across your header flanges and see how far out they are. Mine are like a 1/16" out, or a bit more. The bolts will probably pull them up to where they would seal, but I'm a bit worried about leaks. Anyone else have this problem? Headers flanges not as flat as they should be.
    Dude
  12. #11
    Join Date
    Feb 2000
    Location
    Twin Cities, MN
    Posts
    1,475
    Liked
    42 times
    Images
    4
    Rep Power
    4574
    Mine are on my truck already. But before I installed them I did wonder the same thing. Mine too has a gap of whhat you mentioned. I have a slight leak, not at the block but at the collector and stock exhaust.
    '00 tundra
    '06 sequoia
    '98 forester
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
