Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Interior & Exterior
Old 09-05-2007, 05:05 PM
Last Online: 07-14-2009 12:56 PM
sgooseman is on a distinguished road.
sgooseman's Photo Albums
Default Bed bolts & Line-x spray in Liners
I am getting a spray in liner (Line-x) this upcoming Friday. When I called to setup an appointment I asked 2 questions. 1- Do you remove the Bed Bolts and 2- Do you remove bolts from inside the Tailgate.
His Replies:
1- From his experience with the new Tundra's, he has had trouble getting the bolts back in as they are short to start with and after the liner is sprayed it makes them even shorter. He also stated that even if he did get them back in and if the bolts became scratched they would start rusting.
On Fords he does remove them. He didn't mention Chevys. But a co-worker of mine said the bolts are underneath the bed on Chevys
2-He does remove the bolts on the tailgate.
Anyone here in the forum have any first hand experience with this???
Thanks in advance.
Old 09-05-2007, 05:16 PM
Banned
Dealer : Gray Daniels Toyota
Last Online: 07-01-2008 09:44 PM
blanksb is on a distinguished road.
blanksb's Photo Albums
Default Re: Bed bolts & Line-x spray in Liners
His Replies:
Thanks in advance.
My linex dealer removed the bed bolts or the bolts attaching the bed to the frame. They also removed the tailgate bolts with no problems.
They did however have serious problems getting the bolts or screws that hold the bed rail system in place off to spray the truck. They worked on it for about 3 hours and had 2 screws that stripped out. They eventually ended up having to drill them out. Long story short (probably too late) if you own an 07 Tundra, they will not spray your truck unless YOU remove the screws to the bed rail system before bringing it in.
Old 09-05-2007, 05:47 PM
slackjaw07's Avatar
Last Online: 11-21-2009 01:09 PM
slackjaw07 will become famous soon enough. slackjaw07 will become famous soon enough.
slackjaw07's Photo Albums
His Replies:
Thanks in advance.
Make sure he pulls the bed bolts, access panel screws on the tailgate and the bolts that attach your tie down hooks....if you ever need to remove them you'll have a heck of a time getting them out if he sprays over them. Make sure he also masks the inside of the access opening before he sprays, others have had problems with the mechanism sticking due to overspray. Also, you may have to shave down the rubber stoppers to allow for the build up if the tailgate sticks or does not open properly (I did...about 1/8"). Finally, when you pick up your truck, make sure the bed is bolted back down tight and straight with the body.
Search for Line-X on this forum and you will find more info and pictures.
2007 Toyota Tundra CrewMax SR5 5.7L w/ TRD Package, Blue Streak Metallic/Graphite, FormulaOne Pinnacle Ceramic Tint (15%), auto-dimming mirror, Line-X Bedliner (under the rail), RS3200 alarm/GBS/hood switch, brushed stainless steel running boards, bed extender, door sill protectors, TRD rear sway bar, TRD CAI, Corsa Touring exhaust.
"Never underestimate how much people are willing to spend on their kids, their pets or their trucks!"
Old 09-05-2007, 08:42 PM
jross's Avatar
Dealer : Courtesy Toyota Scion of Brandon
2006 Toyota Tundra SR5 Doublecab-Black
Last Online: 10-28-2009 02:11 PM
jross is on a distinguished road.
jross's Photo Albums
PM 123GONE, as he IS Line-X.
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
EXTERIOR:
Line-X Xtra; Bridgestone Revo 265/70/17; Daystar 2'' Leveling kit.
INTERIOR:
Alpine head unit; WeatherTech front floor liners; Coverking Neoprene seat covers.
Old 09-05-2007, 09:00 PM
Dealer : World Toyota Chamblee
2009 Toyota Tacoma SR5, TRD, CREW CAB,
2007 Toyota Tundra RCLB -- TRADED
Last Online: Today 12:22 AM
SOSHeloPilot has done just about everything. SOSHeloPilot has done just about everything. SOSHeloPilot has done just about everything. SOSHeloPilot has done just about everything. SOSHeloPilot has done just about everything. SOSHeloPilot has done just about everything. SOSHeloPilot has done just about everything. SOSHeloPilot has done just about everything. SOSHeloPilot has done just about everything. SOSHeloPilot has done just about everything. SOSHeloPilot has done just about everything.
SOSHeloPilot's Photo Albums
I had a great Line-X dealer (Lawrenceville Line-X) and he took ALL the bolts and fasteners out & the tailgate off. ..
Most importantly .. He also spent a lot of time on the prep work too. ..
SOS
PS .. If you have tow mirrors .. be careful .. sometimes other drivers (at service shops) do not realize how far out they extend. ..
Old 09-05-2007, 11:54 PM
Thanks for all the replies everyone. I will try PM 123GONE as suggested. I will at the very least have my installer remove one of the bed bolts to show me what he is talking about.
Old 09-06-2007, 11:36 AM
123Gone's Avatar
Dealer : Toyota Of Fort Worth
2005 Toyota Tundra
Last Online: Yesterday 02:23 PM
123Gone will become famous soon enough.
123Gone's Photo Albums
Bed bolts on new Tundras: We have not experienced any problems at all with the bed bolts and we have now applied LINE-X to many many new Tundras. The other dealer may have had a bad experience and now is "spooked". About the rusting, it's really not an issue. I've never seen nor ever heard of a problem with rusted bolts due to a LINE-X application on any model truck. Yes, GM trucks do not have bed bolts showing in the bed and the tie downs are welded in and are not removeable.
Tailgate access panel screws: Typically, the dealer removes the screws, covers the latch guts with paper inside the tailgate, sets the cover on something that raises it up about an inch above the tailgate, sprays the tailgate, lowers the panel onto the tailgate, and reinstalls the screws. So, if you have a latch problem, the screws and access panel are easily removeable without having to dig into the bedliner material.
Rail system screws: Well, I'll admit that the very first time on the very first new Tundra, we striped two screws using hand tools. Since then, we've figured out how to remove/reinstall them with no problems whatsoever. We use a LOW TORQUE air impact wrench. If you don't know what an "impact wrench" is (the name is a little misleading), it's like an air powered drill. I bought one a Sears for like, $20 or $30.
Hope that helps!
Old 09-06-2007, 01:52 PM
conTundra's Avatar
Dealer : Kendall Toyota Scion
Last Online: 11-05-2009 05:43 PM
conTundra is on a distinguished road.
conTundra's Photo Albums
How about telling them to ensure they don't spray around the tailgate closing area to prevent so many issues with the tailgate not opening later?
2007 5.7L 2WD Tundra SR5
Super White
TRD Package
Cold Kit
Tow Package
A.R.E. LSII tonneau cover
Bed Rug
Rear view camera and monitor
Under rear seat storage
Infinity 9613i front, 6022si rear, 3012cf dash. Profile AP1040 amp
Super White Dash LED's
Old 09-06-2007, 02:13 PM
123Gone's Avatar
2005 Toyota Tundra
OK
There are two rubber stops on the truck and the tailgate closes against those stops. If the bedliner is too thick on the a opposing tailgate areas and/or if the stops are raised due to LINE-X being applied underneath them, it's possible that the tailgate won't close all the way. Some dealer fixes include trimming the stops, not spraying LINE-X on the opposing tailgate areas, not spraying underneath the stops. At my shop about 1/2 of the stop has LINE-X underneath it, we do not trim the stop, and we are careful to not spray the opposing area too thick. Also, when reinstalling the tailgate latch hoops, they need to be pressed away from the truck before tightening the bolts.
Old 10-06-2008, 07:07 PM
Dealer : Toyota of Yakima
Last Online: 10-16-2008 05:14 PM
cubijim is on a distinguished road.
cubijim's Photo Albums
I had Line-X sprayed in July 2007 and two of my bed bolts just recently started to rust. The bolts that secure the cargo tie downs (near the tailgate) are rusting too. I am not sure if the rust problem is related to the sprayed liner. Anybody else having this problem?
Old 10-06-2008, 10:31 PM
Dealer : Newbold Toyota - Scion
2005 Toyota Tundra
Last Online: 10-23-2009 04:05 PM
batnav is on a distinguished road.
batnav's Photo Albums
One of my bedbolts is rusting out...had linex ultra sprayed in..not sure if it can be attributed to the the liner though.
Old 10-07-2008, 09:16 AM
123Gone's Avatar
2005 Toyota Tundra
A spray-on bedliner application should have absolutely nothing to do with rust formation on those bolts.
Old 05-18-2009, 12:49 AM
Banned
Last Online: 09-29-2009 01:56 AM
psmith01 is on a distinguished road.
psmith01's Photo Albums
Thumbs up Re: Bed bolts & Line-x spray in Liners
I think line-x name will be changed 123 Gone line-x ha ha ha ha.............?how much posting in favour of line-x.Do posting and earn money from line-x.
Old 05-18-2009, 02:10 AM
Gutz's Avatar
Diplomacy is dead!!!
Dealer : Fletcher Jones Toyota
2007 Toyota Tundra 5.7 RC/SB
Last Online: Yesterday 01:47 AM
Images: 15
Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything.
Gutz's Photo Albums
I just tape them off, the bolts. Always looked fine and never had any complaints. My dads which I did over three yeras ago on his Titan still looks sweet...
iF57 Tundra Racing Club
Bed liner: Spray on or Plastic ? OCTundraTRD Interior & Exterior 16 10-22-2007 08:40 PM
Question for the guys with spray on bed liners Wht06Tundra 1Gen-Tundra 10 02-28-2007 05:25 PM
Bed liners rx7vert Interior & Exterior 24 11-15-2004 05:13 PM
Bed Liner or Spray in ???? wHITEY Interior & Exterior 22 10-22-2002 03:05 PM
Bed Liner - Spray in or Underrail plastic? SMUAlien Interior & Exterior 21 09-11-2002 10:49 PM
