Thats a big 10-4 boone. I install decals/stickers sometimes when i help my brother, (he cuts decals for a living) and when we're not confident we can do it without water, we get some soap and water, put it in a spray bottle, shake it up and spray on the sticky side of the decal before i apply it. Be sure to clean the surface you are about to apply the decal to, with denatured alcohol, or some other wax/dirt removing solvent. As for the soap/ water mixture, you can put a squeeze or two of dish soap in a spray bottle and fill the rest up with water. then once the decal is in the desired location, use a squegee to squeeze out most of the water under the surface. hope this helps.
