Go Back   Toyota Tundra Forums : Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Interior & Exterior
Old 02-01-2008, 12:04 PM
Dealer : Miller Toyota
2005 Toyota Tundra DC Phantom Gray
Last Online: Yesterday 06:24 PM
Images: 11
dibble9012 will become famous soon enough.
dibble9012's Photo Albums
Default My sound deadening project
Well I started sound deadening last night. Wow, it's a big job, but it should make a huge difference. Anyways, since I am helping a friend move this weekend, I didn't totally gut the truck. All I did was the back wall and window access panel. I have seen some people just deaden right over the window access panel, but was hesitant to do it that way, just in case anything ever went wrong.
The materials I am using are raamat and esolite, with the raamat spray glue. That glue is better than anything I've ever used, there are no spray particles that go in the air, it's a steady stream of glue onto the surface.
Here are some pictures! The back window access panel was good practice. Inside the window cavity (no pictures yet) was a HUGE pain! I put about 2 layers of raamat on the acces panel with ensolite on the front and back. Only two layers on some of the less reinforced parts on the access panel.
What it looks like from Toyota. Two little pieces of sound deadening.
Started sound deadening access panel
Finished the raamat on the access panel.
Inside window compartment from Toyota, no sound deadening.
Old 02-02-2008, 02:27 PM
Images: 11
Default Re: My sound deadening project
Next on to the passenger door. I did the passenger door first because I was installing an automatic lock module at the same time. It locks the doors when speed is at about 15 mph and unlocks when the ignition is turned off.
Removed discarded the factory moisture barrier. Put about 2-3 layers on the outside door skin, with an extra layer behind the speaker. The third layer was only in the center of the door where there was the least support. I also put a small square of ensolite behind the speaker. On the interior door skin I put about 2 layers, and covered the holes in the door too. I did not need any sheet metal or filler, the raamat was sturdy enough to cover the holes. They I put a layer of ensolite over the raamat.
All cleaned up and ready for sound deadening.
Closer look inside the holes.
Done with the raamat
Ensolite
Old 02-04-2008, 01:09 AM
Images: 11
Here are some pictures of the floor. I went for a drive afterwards, I need to do the rest of the doors. It sounds like I have a window open behind me without them done. Other than that, like others have said, engine noise is more noticeable. I may eventually do the firewall (inside, not in the engine bay). The problem I ran into was that Toyota put a huge foam pad that covers the entire firewall, so in order to raamat behind it, I would need to remove the entire dash to remove the pad.
Everything fit back together fine except the seat mount covers won't snap on (may be able to rotozip them so they will).
Finished raamat, started ensolite
Ensolite
Old 02-07-2008, 12:08 PM
Tundradrenalin's Avatar
Assistant Administrator
Last Online: Today 07:59 AM
Images: 205
Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family.
Great log. Thanks for the contri, added to Install section of the http://www.tundrasolutions.com/forum...lf/#post908479 Gen1 forum.
Under the Hood: AMSOIL Synthetic Lubes all around, AMSOIL Ea Air Filter, Doug Thorley Headers, Magnaflow Exhaust, Semi-RAMair airbox mod
Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, 1.5" Wheeler's blocks, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear]
Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES
Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full LED Conversion
Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead
Cosmetic: Line-X Bedliner, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve, Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
Old 02-07-2008, 12:59 PM
Images: 11
Well I guess now I'm gonna have to do a more detailed post on the process, hahahah. Thanks for adding me though! I didn't get any pictures of the roof, but it's really easy to do once the headliner is removed.
I'll see if I can do a short how-to on the automatic door locks as well, they're really great to have.
More pictures and details to come soon. I am waiting on another shipment of raamat that should arrive Wednesday.
Old 02-15-2008, 12:06 PM
Dealer : Toyota Scion of Santa Monica
Last Online: 05-11-2008 01:15 AM
wag91 is on a distinguished road.
wag91's Photo Albums
Dibble,
How is the smell with the RAAmat? I bought some with the foam and it smells in the package. A little shy to put it on if it will smell. With the work that you have already done, does it still smell?
Old 02-15-2008, 12:13 PM
Images: 11
Maybe a bit of a smell at first. I was out with friends and they didn't notice anything, they even went as far as, "it smells good in here". Anyways, for the most part, no smell at all. The only thing that smells is the spray glue, and that goes away in one to two days if you leave your windows cracked, and drive around with all the windows down for the first minute or so while driving. Down to the point, no smell after two or three days.
I just got my second shipment of raamat, so thats going to be my weekend project, finishing the doors.
Old 02-15-2008, 05:31 PM
TundraSurfBum's Avatar
Dealer : Wesley Chapel Toyota
Last Online: 03-09-2009 07:27 AM
Images: 5
TundraSurfBum is on a distinguished road.
TundraSurfBum's Photo Albums
so the big question.... any noticeable difference?
Old 02-15-2008, 06:21 PM
Images: 205
yes, definitely yes. And for the religious in the crowd, God yes.
Old 02-15-2008, 06:32 PM
Images: 11
I hear a big difference. The main noises I hear are the tire and engine noise. I have revo's and they get louder as they get older. I was driving the other day in heavy rain and its amazing, the only rain noise is from the windshield.
Old 02-17-2008, 02:38 AM
lsturbointeg's Avatar
Dealer : Toyota of Temecula Valley
Last Online: 10-04-2009 03:32 AM
lsturbointeg is on a distinguished road.
lsturbointeg's Photo Albums
So pretty much you eliminate the outside noise coming in except for the engine and tire noise that's even louder?
2006 Toyota Tundra SR5
RCD 6" lift / 5100 bilstein rear shocks / 3" custom body lift / 17x9 Pro Comp 6001 chrome finish / RhinoLining / Husky Black Tool Box / Leer Ladder Rack / 35/12.50r17 Pro Comp Xterrains / Valor IDA-700W 7" WideScreen / AVE AV-1520 15.2" TFT/LCD Flip Down Monitor / 8" Infinity Reference 850w subs / Custom Fiberglass sealed enclosure / MB Quartz DSD216 Discus Components front and rear / Kenwood KAC819 Mono Amp / PPI5440 5 Channel Amp / Power Converter w/ audio/video input
Old 02-17-2008, 12:47 PM
Images: 11
Yea, outside noise is a lot quieter. You can still hear the "woosh" of cars going past if you're at a light. The engine and tire noise is not louder, just a bit more noticeable, but that could be attributed to the brand and type of tires I have installed.
Old 02-21-2008, 01:14 PM
Images: 11
More pictures of the doors:
Front Driver Door
Rear Passenger Door
Old 02-21-2008, 01:53 PM
ThirdHorseman's Avatar
Apocalyptic Wit
Dealer : Toyota Of Turnersville
Images: 14
ThirdHorseman has blessed us with their presence. ThirdHorseman has blessed us with their presence. ThirdHorseman has blessed us with their presence. ThirdHorseman has blessed us with their presence.
ThirdHorseman's Photo Albums
Great job!
Old 02-23-2008, 11:14 AM
Dealer : Laurel Toyota
- Other -
Last Online: 09-03-2008 12:37 PM
50esnatit is on a distinguished road.
50esnatit's Photo Albums
Nice work!
LinkBack to this Thread: http://www.tundrasolutions.com/forums/interior-and-exterior/123677-my-sound-deadening-project/
Posted By For Type Date
DIY (Do-It-Yourself) & User Knowledgebase - Tundra Geeks :: The Toyota Tundra Enthusiast Forum This thread Refback 09-24-2009 06:57 AM
